Is there no current means to have a group type and member base type of color picker? The purpose would be to control multiple colorpicker items at once. For example, a room has 5 items with a color picker. A group called Living Room Color would allow controlling all of them simultaneously and in sync.
Right now the only way I am seeing to do it is to make specific scenes using rules. OH 3.1.0 release if it matters.
No. There is no such Item type.
You may create Items of type Color, and Groups of type Color.
Note that putting a bunch of Items in a Group does not automatically synch them up.
Sending commands to the Group will pass commands to the member Items.
Adjusting individual members by command or local controls will not automatically be reflected in other members.
Not sure what you want here.
In theory, you can represent a Group on a UI with say a colorpicker cotrol, and when you click the control it will do as described above - pass the commands to all members.
But I think there are "gotcha"s here.
The colorpicker widget wonāt work without an initial HSV state.
Groups donāt have any state by default.
Groups can derive their state from members by choosing an aggegation function ā¦ but I donāt think any of the current available functions work to produce an HSV (what would an average colour look like?)
You could make a āmaster controlā with an extra dummy Color type Item.
Put that (not the Group) in your UI with a colopicker widget.
Have some rule of yours produce some worked out state for it by averaging the Group member Item states, so that it works with the widget.
Have another rule simply pass commands to the dummy onwards to the Group, which will in turn pass to members.
The former. For example, i have a ceiling light with two RGBW wifi bulbs in it. There are no circumstances where Iād ever want the two bulbs to do different things. Using a group to issue commands would be the best way to control them together.
But as youāve noted, the support for this is not there I guess. So Iām having to write scenes with scripts and triggers.
You mean I could use the group to distribute a command from a rule/script? Just not via the UI due to the lack of UI support? I hadnāt thought of trying that after I saw the UI not working.
Holy crap. I never realized you could do such a thing. That just accomplished exactly what I needed. Thank you!
Itās a bit of a kludge; obviously the Item can only show you the state of one device at a time - the last one to ācheck inā.
Should the devices not be exactly identical, you might find your Item state dithering between them.
Depending on the binding/technology, sometimes you can manage parallel devices better by making one channel write-only.
I do this using the master control @rossko57 mentions.
I have several rooms which have lights that are ācolorā capable and wanted to have them integrated with Alexa. In order to do this I started by creating a group that would mimic a single-bulb. As I use a naming convention I ended up with something like:
Note: whilst the last entry is named āGrpā it is actually an Item of Type Color.
Due to the fact I have many of these I then created a āSettings_ColorChangerā group so that I can place all the āGrp_Lights_XX_YY_ZZZ_ColorChangerā in. This allows the following rule:
triggers:
- id: "1"
configuration:
groupName: Settings_ColorChanger
type: core.GroupStateChangeTrigger
conditions: []
actions:
- inputs: {}
configuration:
type: application/vnd.openhab.dsl.rule
script: >
// remove the 'Changer' from the triggeringItemName
val groupName = triggeringItemName.toString.substring(0, triggeringItemName.toString.length - 7)
sendCommand(groupName, newState.toString)
type: script.ScriptAction
Now when I change the value of the Grp_Lights_FF_KI_Spots_ColorChanger the rule gets run and this in turn sends the command to the Grp_Lights_FF_KI_Spots_Color group.
The above works for my use case since I mostly use voice, but it should be noted that this wonāt sync a color change from one bulb.
As a side note, when I did set this up the Color Picker would not be displayed if the ColorChanger item did not have a value. I fixed this by running a rule on startup to set all members of the Settings_ColorChanger group to a default value.
