- Platform information:
- Hardware: Raspberry Pi 4
- openHAB version: 4.0.2
- Issue of the topic: Adding a Group Item with NOR/NAND aggregation function doesn’t seem to work anymore from UI?
I’m using mainUI extensively, but when bulk-adding/modifying items, I prefer pasting Items from textual definitions …
I haven’t used NAND/NOR Group aggregates for sometime … but when I do now, I’m getting an error message:
Group:Switch:NOR(ON,OFF) _OccupancyPlanned "Planned House Occupancy" (_Plans)
yields in
Error: Syntax error at line 1 col 17:
Group:Switch:NOR(
Unexpected lparen token: "(". Instead, I was expecting to see one of the following:
while pasting
Group:Switch:OR(ON,OFF) _OccupancyPlanned "Planned House Occupancy" (_Plans)
works perfectly fine…
I can also subsequently edit the Item definition yaml and change the OR to NOR, which works:
label: Planned House Occupancy
type: Group
category: ""
groupNames:
- _Plans
tags:
- Occupancy
- Planned
groupType: Switch
function:
name: NOR (was OR)
params:
- ON
- OFF
yielding:
So why I can I not (anymore) use NOR (or NAND) when pasting the Item’s textual definition in MainUI?
On a side note, I think it would to clarity in MainUI to spell out the logical functions in the options popup:
All ON then ON else OFF (logical AND)
All ON then OFF else ON (logical NAND)
but that’s really another point.
