UP/DOWN/STOP are not states, they are commands. I’m a little surprised this works at all and doesn’t just explode in a bunch of errors. A Rollershutter Item stores it’s state as a PercentType (integer between 0 and 100). Your aggregation function on the Group therefore needs to work with numbers between 0 and 100.
Honestly the events.log don’t make a whole lot of sense compared to what I would expect but ultimately it’s doing what it’s doing because your Group definition doesn’t make sense.
I can’t comment on the binding but even without the aggregation functions the events.log doesn’t make sense. A Rollershutter Item cannot change to DOWN. DOWN is not a state, it’s a command. And it definitely appears that the state is not sticking because it never actually changes from DOWN. So that means that the Item is never actually DOWN but remains 100.
I recommend not letting the default aggregation apply. Define it to something like MIN or MAX or AVG.
Well my zwave roller shutters also take commands UP/DOWN/STOP/0-100
But could very well be that the actual state is always a number. Thanks for the hints, I will try to group my roller shutters as well
Correct. Rollershutters only store a PercentType. They can receive UpDown and StopMove type commands, but those are only commands, not states. An Item can never be in the state of UP. And if it where, what would that even mean? UP is a request for the roller shutter to do something, not a state.
