GrowBuddy v1.0
GrowBuddy v1.0 is intended to help you automate growing your plants indoor.
It takes care of :
- growlight automation
- automated watering
- circular air
- ventilation
Requirements:
- JSScripting (ECMA2021) enabled for the additional Rule which interacts with the widget (or you can write your own rule in your preferred Rule-language)
- Additional items for storing several values (startTime, endTime, wateringInterval, wateringDuration, growPhase etc…)
- Four Smartplugs for the devices you want to control (growlight, circular-air, air-ventilation, watering-pump)
…and of course the physical equipment to connect it to your Smartplugs ;)…
After following this guide…
you should be able to relax and enjoy your automated grow experience, the widget takes care of enabling and disabling your GrowLight - you only have to adjust your desired StartTime and the widget automatically chooses the EndTime according to the selected GrowPhase (18 hours for Grow and 12 hours for Flowering period). You can choose a WateringInterval between 5 minutes and 1 day in certain steps and a WateringDuration between 5 and 90 seconds. The AirCirculation automatically starts with the GrowLight and stops when it turns off, the Ventilation runs 24/7 except the MainSwitch is turned off, which automatically disables all Smartplugs. You Only have to take care of your WaterReservoir ;)…
The Rules File (ECMA2021)
Save this file as growbuddy.js in the /automation/js/ folder.
const { items, rules, triggers } = require("openhab");
// timeouts
let wateringTimer;
const mainswitch = items.getItem("GrowbuddyMainSwitch");
const growbuddylight = items.getItem("SmartplugGrowlight");
const growbuddyventilation = items.getItem("SmartplugVentilation");
const growbuddyairfan = items.getItem("SmartplugCirculation");
const growbuddywater = items.getItem("SmartplugWatering");
const growbuddywatering = items.getItem("GrowbuddyWatering");
const growbuddywaterinterval = items.getItem("GrowbuddyWaterInterval");
const growbuddywaterdura = items.getItem("GrowbuddyWaterDuration");
const lightstart = items.getItem("GrowbuddyLightStart");
const lightstop = items.getItem("GrowbuddyLightStop");
const growphase = items.getItem("GrowbuddyGrowPhase");
rules.JSRule({
name: "GrowBuddy - Rule Disabler",
description: "disable rules when mainswitch is turned off",
triggers: [triggers.ItemStateChangeTrigger("GrowbuddyMainSwitch")],
execute: (data) => {
if (mainswitch.state === "OFF") {
growbuddylight.sendCommandIfDifferent("OFF");
growbuddyventilation.sendCommandIfDifferent("OFF");
growbuddyairfan.sendCommandIfDifferent("OFF");
rules.setEnabled(growbuddyTogglelight, false);
rules.setEnabled(growbuddyToggleairfan, false);
rules.setEnabled(growbuddyToggleventilation, false);
rules.setEnabled(growbuddyTogglewatering, false);
} else if (mainswitch.state === "ON") {
rules.setEnabled(growbuddyTogglelight, true);
rules.setEnabled(growbuddyToggleairfan, true);
rules.setEnabled(growbuddyToggleventilation, true);
rules.setEnabled(growbuddyTogglewatering, true);
tags: [],
rules.JSRule({
name: "Growbuddy - Toggle Light",
description: "schedule light for growbuddy",
triggers: [
triggers.ItemStateChangeTrigger("GrowbuddyMainSwitch"),
triggers.DateTimeTrigger("GrowbuddyLightStart", false),
triggers.DateTimeTrigger("GrowbuddyLightStop", false),
let now = time.ZonedDateTime.now();
let curr = now.isBetweenDateTimes(lightstart, lightstop) ? "ON" : "OFF";
if (growbuddylight.state !== curr) {
growbuddylight.sendCommandIfDifferent(curr);
console.log("Growbuddy - Switching Lights", curr);
tags: [],
rules.JSRule({
name: "GrowBuddy - Toggle Airfan",
description: "schedule airfan for growbuddy",
triggers: [
triggers.ItemStateChangeTrigger("SmartplugGrowlight"),
triggers.ItemStateChangeTrigger("GrowbuddyGrowPhase"),
if (growbuddylight.state === "ON") {
growbuddyairfan.sendCommandIfDifferent("ON");
} else growbuddyairfan.sendCommandIfDifferent("OFF");
tags: [],
rules.JSRule({
name: "GrowBuddy - Toggle Ventilation",
description: "schedule ventilation for growbuddy",
triggers: [
growbuddyventilation.sendCommandIfDifferent("ON");
tags: [],
rules.JSRule({
name: "Growbuddy - Schedule Watering",
description: "schedule watering for growbuddy",
triggers: [triggers.DateTimeTrigger("GrowbuddyWatering")],
const interval = time.toZDT(growbuddywaterinterval);
const duration = time.toZDT(growbuddywaterdura).getMillisFromNow();
if (wateringTimer) clearTimeout(wateringTimer);
wateringTimer = null;
growbuddywater.sendCommandIfDifferent("ON");
growbuddywatering.sendCommandIfDifferent(interval);
wateringTimer = setTimeout(fn_Watering, duration);
function fn_Watering() {
growbuddywater.sendCommandIfDifferent("OFF");
tags: [],
rules.JSRule({
name: "Growbuddy - Update Watering Time if MainSwitch was activated",
description: "update watering time when mainswitch is turned on",
triggers: [
triggers.ItemStateChangeTrigger("GrowbuddyMainSwitch", undefined, "ON"),
triggers.SystemStartlevelTrigger(100),
if (time.toZDT(growbuddywatering).isBefore(time.toZDT())) {
rules.runRule("growbuddy-watering");
tags: [],
rules.JSRule({
name: "Growbuddy - Toggle Grow Phase",
description: "change lightstop acording to growphase for growbuddy",
triggers: [
triggers.ItemStateChangeTrigger("GrowbuddyLightStart"),
const phasestop = time
.toZDT(lightstart.state)
.plus(time.Duration.ofHours(parseInt(growphase.state)));
lightstop.postUpdate(phasestop);
tags: [],
rules.JSRule({
name: "Growbuddy - Update LightStart",
description: "update lightstart according to daychange",
triggers: [triggers.GenericCronTrigger("0 0 0 * * ? *")],
const newlightstart = time
.toZDT(lightstart)
.plus(time.Duration.ofHours(24));
lightstart.sendCommand(newlightstart);
tags: [],
The Items
You need to create the following items with the exact names and item-types:
- SmartplugGrowlight (itemType: Switch)
- SmartplugVentilation (itemType: Switch)
- SmartplugCirculation (itemType: Switch)
- SmartplugWatering (itemType: Switch)
- GrowbuddyMainSwitch (itemType: Switch)
- GrowbuddyGrowPhase (itemType: Number:Time)
- GrowbuddyWaterInterval (itemType: Number:Time)
- GrowbuddyWaterDuration (itemType: Number:Time)
- GrowbuddyWatering (itemType: DateTime)
- GrowbuddyLightStart (itemType: DateTime)
- GrowbuddyLightStop (itemType: DateTime)
If you’re too lazy to add this items by hand, you can import the growbuddy.items to your MainUI or textual config. To import to Main UI navigate to the items section click on the + sign to add an item and choose “Add Item from Textual Definition” and paste the following code.
Switch SmartplugGrowlight "Grow Light" <switch>
Switch SmartplugVentilation "Air Ventilation" <switch>
Switch SmartplugCirculation "Air Circulation" <switch>
Switch SmartplugWatering "Watering Pump" <switch>
Switch GrowbuddyMainSwitch "Main Switch" <switch>
Number:Time GrowbuddyGrowPhase "Grow Phase Selector" <time>
Number:Time GrowbuddyWaterInterval "Watering Interval" <time>
Number:Time GrowbuddyWaterDuration "Watering Duration" <time>
DateTime GrowbuddyWatering "Watering Time" <time>
DateTime GrowbuddyLightStart "Grow Light Start Time" <time>
DateTime GrowbuddyLightStop "Grow Light Stop Time" <time>
Script to initialize DateTime Items (you only need that once)
add this script in MainUI in the scripts section (choose ECMA2021) and execute it.
items.getItem("GrowbuddyLightStart").sendCommand(now.minus(time.Duration.ofHours(4)));
items.getItem("GrowbuddyLightStop").sendCommand(now.plus(time.Duration.ofHours(8)));
items.getItem("GrowbuddyWatering").sendCommand(now.plus(time.Duration.ofMinutes(1)));
Screenshots
Changelog
Version 1.0
- initial release (stable version)
Resources
uid: GrowBuddy
tags: []
props:
parameters:
- defaultValue: 24h
description: Time format (12h|24h)
label: Format
required: true
type: TEXT
- context: item
defaultValue: GrowbuddyMainSwitch
description: Item to control
label: Main Switch Item
required: false
type: TEXT
- context: item
defaultValue: GrowbuddyLightStart
label: Starttime Item
required: false
type: TEXT
- context: item
defaultValue: GrowbuddyLightStop
label: Stoptime Item
required: false
type: TEXT
- context: item
defaultValue: SmartplugGrowlight
label: MainLight Item
required: false
type: TEXT
- context: item
defaultValue: GrowbuddyGrowPhase
label: GrowPhase Item
required: false
type: TEXT
- context: item
defaultValue: GrowbuddyWaterInterval
label: Watering Interval Item
required: false
type: TEXT
- context: item
defaultValue: GrowbuddyWaterDuration
label: Watering Duration Item
required: false
type: TEXT
- context: item
defaultValue: GrowbuddyWatering
label: Watering Toggle Item
required: false
type: TEXT
- context: item
defaultValue: SmartplugWatering
label: Watering Item
required: false
type: TEXT
- context: item
defaultValue: SmartplugCirculation
label: Circular Air Item
required: false
type: TEXT
- context: item
defaultValue: SmartplugVentilation
label: Air Ventilation Item
required: false
type: TEXT
parameterGroups: []
timestamp: Aug 30, 2023, 3:03:51 PM
component: f7-block
label: GrowBuddy
style:
max-width: 690px
slots:
default:
- component: f7-row
class:
- margin
slots:
default:
- component: f7-col
width: "100"
slots:
default:
- component: oh-block
title: GrowBuddy
slots: {}
- component: f7-col
width: "100"
slots:
default:
- component: oh-knob-cell
action: toggle
actionCommand: ON
actionCommandAlt: OFF
actionItem: =(props.mainswitch)
actionOptions: ON,OFF
color: "=(items[props.mainswitch].state === 'ON') ? 'green' : 'red'"
commandInterval: 500
expandable: false
footer: "=(items[props.mainswitch].state === 'ON') ? 'ACTIVE' : 'DISABLED'"
icon: "=(items[props.mainswitch].state === 'ON') ? 'iconify:mingcute:power-fill' : 'iconify:mingcute:power-line'"
iconColor: "=(items[props.mainswitch].state === 'ON') ? 'green' : 'red'"
releaseOnly: true
responsive: true
style:
text-shadow: 1px 1px black
title: Main Switch
- component: f7-row
class:
- margin
slots:
default:
- component: f7-col
width: "100"
slots:
default:
action: toggle
actionCommand: 18 h
actionCommandAlt: 12 h
actionItem: =(props.growphase)
actionOptions: 12,18
color: "=(items[props.light].state === 'ON') ? 'green' : 'red'"
expandable: false
footer: "=(items[props.growphase].state === '12 h') ? 'FLOWERING (12 HOURS)' : 'GROW (18 HOURS)'"
icon: "=(items[props.growphase].state === '12 h') ? 'iconify:ph:plant' : 'iconify:ph:plant-duotone'"
iconColor: "=(items[props.growphase].state === '12 h') ? 'orange' : 'green'"
releaseOnly: true
responsive: true
style:
title: Grow Phase
- component: f7-col
width: "100"
slots:
default:
title: Start
slots: {}
- component: f7-row
class:
- margin
slots:
default:
- component: f7-col
width: "100"
slots:
default:
- component: f7-row
config: {}
slots:
default:
- component: f7-col
style:
text-align: center
width: "45"
slots:
default:
- component: oh-button
action: command
actionCommand: =(dayjs(items[props.startitem].state).add(1, 'hour').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
actionItem: =(props.startitem)
style:
--f7-button-text-color: var(--f7-text-color)
font-family: u2400
font-size: 150%
text: ▲
- component: f7-col
width: "10"
- component: f7-col
style:
text-align: center
width: "45"
slots:
default:
action: command
actionCommand: =(dayjs(items[props.startitem].state).add(1, 'minute').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
style:
font-family: u2400
font-size: 150%
text: ▲
- component: f7-row
config: {}
slots:
default:
- component: f7-col
width: "45"
slots:
default:
- component: oh-label-card
label: "=(((items[props.startitem].state === 'NULL') || !props.startitem) ? '?': props.timeFormat == '12h' ? dayjs(items[props.startitem].state).format('hh'): dayjs(items[props.startitem].state).format('HH'))"
- component: f7-col
style:
margin: auto
text-align: center
width: "10"
slots:
default:
- component: Label
style:
font-size: 200%
text: ":"
- component: f7-col
width: "45"
slots:
default:
label: "=(((items[props.startitem].state === 'NULL') || !props.startitem) ? '?': dayjs(items[props.startitem].state).format('mm'))"
- component: f7-row
config: {}
slots:
default:
- component: f7-col
style:
text-align: center
width: "45"
slots:
default:
action: command
actionCommand: =(dayjs(items[props.startitem].state).add(-1, 'hour').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
style:
font-family: u2400
font-size: 150%
text: ▼
- component: f7-col
width: "10"
- component: f7-col
style:
text-align: center
width: "45"
slots:
default:
action: command
actionCommand: =(dayjs(items[props.startitem].state).add(-1, 'minute').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
style:
font-family: u2400
font-size: 150%
text: ▼
- component: f7-row
class:
- margin
slots:
default:
- component: f7-col
width: "100"
slots:
default:
title: Stop
slots: {}
- component: f7-row
class:
- margin
slots:
default:
- component: f7-col
width: "=(props.timeFormat === '12h') ? '70': '100'"
slots:
default:
- component: f7-row
config: {}
slots:
default:
- component: f7-col
width: "45"
slots:
default:
label: "=(((items[props.stopitem].state === 'NULL') || !props.stopitem) ? '?': props.timeFormat == '12h' ? dayjs(items[props.stopitem].state).format('hh'): dayjs(items[props.stopitem].state).format('HH'))"
- component: f7-col
style:
margin: auto
text-align: center
width: "10"
slots:
default:
- component: Label
style:
font-size: 200%
text: ":"
- component: f7-col
width: "45"
slots:
default:
label: "=(((items[props.stopitem].state === 'NULL') || !props.stopitem) ? '?': dayjs(items[props.stopitem].state).format('mm'))"
- component: f7-row
class:
- margin
slots:
default:
- component: f7-col
width: "100"
slots:
default:
action: toggle
actionCommand: ON
actionItem: =(props.light)
expandable: false
footer: "=(items[props.light].state === 'ON') ? 'RUNNING' : 'OFF'"
icon: "=(items[props.light].state === 'ON') ? 'iconify:tabler:bulb-filled' : 'iconify:tabler:bulb-off'"
iconColor: "=(items[props.light].state === 'ON') ? 'yellow' : 'gray'"
primaryColor: "#663311"
releaseOnly: true
responsive: true
secondaryColor: "#114455"
style:
background-color: rgba(100, 100, 100, 0.3)
title: Grow Light
- component: f7-col
width: "100"
slots:
defaultValue:
action: toggle
actionCommand: ON
actionItem: =(props.ventilation)
expandable: false
footer: "=(items[props.ventilation].state === 'ON') ? 'RUNNING' : 'OFF'"
icon: "=(items[props.ventilation].state === 'ON') ? 'iconify:mdi:ventilation' : 'iconify:mdi:ventilation-off'"
iconColor: "=(items[props.ventilation].state === 'ON') ? 'green' : 'gray'"
releaseOnly: true
responsive: true
style:
title: Air Ventilation
- component: f7-col
width: "100"
slots:
default:
action: toggle
actionCommand: ON
actionItem: =(props.circulation)
expandable: false
footer: "=(items[props.circulation].state === 'ON') ? 'RUNNING' : 'OFF'"
icon: "=(items[props.circulation].state === 'ON') ? 'iconify:material-symbols:mode-fan' : 'iconify:material-symbols:mode-fan-off-outline-rounded'"
iconColor: "=(items[props.circulation].state === 'ON') ? 'green' : 'gray'"
releaseOnly: true
responsive: true
style:
title: Air Circulation
- component: f7-col
width: "100"
slots:
default:
action: options
actionItem: =(props.interval)
actionOptions: 2 min,5 min,10 min,15 min,20 min,30 min,1 h,2 h,4 h,6 h,12 h,24 h
expandable: false
footer: =(items[props.interval].state)
icon: "=(items[props.watering].state === 'ON') ? 'iconify:mdi:watering-can' : 'iconify:mdi:watering-can-outline'"
iconColor: "=(items[props.watering].state === 'ON') ? 'green' : 'gray'"
releaseOnly: true
responsive: true
style:
title: Watering Interval
- component: f7-col
width: "100"
slots:
default:
action: options
actionItem: =(props.duration)
actionOptions: 5 s,10 s,15 s,20 s,30 s,60 s,90 s
expandable: false
footer: =(items[props.duration].state)
icon: "=(items[props.watering].state === 'ON') ? 'iconify:game-icons:duration' : 'iconify:game-icons:duration'"
releaseOnly: true
responsive: true
style:
title: Watering Duration
I hope this installation tutorial is complete… otherwise feel free to ask ;)…
