GrowBuddy v1.0 - Grow Your Plants Indoor
see edit history if there is interest.
Ok fine, for me it seemed a little bit like disappointment from your side… I gave up on this rule, because it was to time-consuming to test and discuss something that is already working and the improvement is so minor and not part of the use case at all. And after failing and failing I decided to spend my time for more important things. In my eyes it is not important to optimize code, more like ā€œnice to haveā€ but not necesary if the code is not problematic - and overall my code had not a single problem. I think you shouldn’t act like the Code-Police just because you help people on the forums and my code wasn’t bad or problematic at all, just simple and not improved, even if someone would have copied some pieces of my code this wouldn’t lead to ā€œyou spending an outsized amount of time for fixingā€, there was nothing to fix!
Maybe I’ll have a look at your last posted code when I’m wanting to spend more time on this, but IMO I spent way more time on debugging this rule than it would improve anything…
Then I invite you to take over for me in helping people fix problem caused by copying code with problems that were not a problem where they copied it from but is a problem where they copied it to because it was brittle. I’d love to give that up. I’d have a lot more time to spend on other and more fun things. I didn’t use to have to spend that much time on it.
But your point is clear. I will no longer ā€œpoliceā€ your code and I’ll refer anyone who copies from it and has problems to you.
All ā€œpolicingā€ of code has been removed from this thread and your posts and replies hidden from me lest I forget in the future and ā€œpoliceā€ something from you again.
I’ll hand in my badge and gun and the end of my shift.
All the best of luck with OH and all the rest.
In my opinion my code wasn’t brittle or harmful at all. If you decide to spend your time doing all this for the community, you can decide if it is not what you expect from spending your time here. No front, but what I’m saying is consider doing less if this is too much for you to feel good with it. For me personally this effort you’re spending on the forums would be way too much. But it’s an individual decision how to spend the time one has.
Hopefully you don’t do more than you can handle - I wish you all the best for the future…
Have a nice day!
