Guidance needed: Build docker container out of python script that connects bathroom body (fat) scales
Some time back, I found a nice little python script that listens for bluetooth information from a number of Medisana body (fat) bathroom scale and passes the information (weight, fat, bone mass, etc) over to various plugins for further processing (e.g. via MQTT) to openHAB.
The installation of this script, however, is a bit tricky (I once wrote a tutorial here). Plus, it’s not that nice that, even though almost all crucial home automation software can be deployed via Docker, this one needs to be installed manually. So I wanted to containerize the script.
Starting some days back, I tried to bring this script into a Docker container. I’m not a pro in this, so it took me a while to get the basics right (ChatGPT is great for things like that). Even though I managed to create a container that can e.g. run bluetoothctl from within the container (so Bluetooth via a container can work), I failed miserably to get the entire script running (not even test the bluetooth connection).
Now before I go into the details (why things aren’t working) is there anyone out there who has experience with that and can assist, and maybe letting me know whether I’m going into the right direction? The script is quite nice, and it would be nice making it available more easily.
Backup: The challenges I’m facing (summed up by chatGPT which assisted me along the way)
Bluetooth Hardware Access and Management:
  • The BS440 script (and pygatt) tries to manage Bluetooth (e.g., using sudo btmgmt le on and systemctl restart bluetooth), which works great if installed natively on the host system but fails in a container lacking a full init system.
Systemd and Init System Challenges:
  • Running a minimal container (e.g., based on python:3.9-slim or debian:bullseye-slim) without systemd causes errors like “System has not been booted with systemd as init system.”
  • Pygatt’s backend (via adapter.start()) triggers system-level commands that expect systemd and the Bluetooth management socket, resulting in errors such as “Unable to open mgmt_socket” and “Can’t open HCI socket.”
Cgroup and Filesystem Mount Issues:
  • Mounting the host’s /sys/fs/cgroup as read-only prevents systemd from creating the necessary control groups (e.g., /init.scope), causing systemd to exit with code 255.
Debugging Difficulties:
  • Attempts to run systemd in interactive debug mode revealed that the chosen base image sometimes lacked the expected binary paths (e.g., /sbin/init vs. /lib/systemd/systemd).
  • When running interactively, tools like journalctl or even ps were missing or not working as expected, complicating the debugging process.
All I can say is I’ve tried it and gave up. BT inside a container is theoretically possible and some report they even get it to work.. But I gave up and run my BT services and scripts like this on RPis instead of containers.
Thanks @rlkoshak. Somehow discouraging, but in line with my experience so far.
@rlkoshak, in case you‘re interested: I believe I got Bluetooth on docker working reliably. At least my current tests were successful.
If someone wants to have a look or contribute: GitHub - Boldfor/BS440-DOCKER: Python code as docker container to talk to Medisana BS440 bluetooth enabled bathroom scale
Fun fact: I created this entire project with cursor.ai without writing a single line of code myself, just by chatting with cursor. Pretty wild if I think about it…
Update: Made some tweaks here and there, and I‘d say v0.1 is done. Whoever wants to have a look: GitHub - Boldfor/BS440-DOCKER: Python code as docker container to talk to Medisana BS440 bluetooth enabled bathroom scale
