To be realistic. Most new bindings in review will probably not be merged before the change to openHAB 3 branch becomes active. We’ll probably try to get as much as possible merged. But it also depends on the quality of the submitted new bindings. The more issues (that can be as simple as not having included the right files, or accidentally change unrelated files) the longer it takes, because the iteration process going back and forth between developer and review can take some time. In general if you write clean code and neat documentation your binding can be merged quickly.
