I am having a problem with Guzzle in a Laravel-application (PHP), where there seems to be some kind of encoding problem. The weird thing is, that I can make a GET request with Guzzle to the API /things at get all things. But I cannot do it for /things/someUID, because it triggers an error:
GuzzleHttp\Exception\RequestException
cURL error 61: Unrecognized content encoding type. libcurl understands deflate, gzip content encodings. (see https://curl.haxx.se/libcurl/c/libcurl-errors.html)
Debug output from Guzzle:
* Found bundle for host 10.0.0.63: 0x7fafc9d7acb0 [can pipeline]
* Re-using existing connection! (#0) with host 10.0.0.63
* Connected to 10.0.0.63 (10.0.0.63) port 8080 (#0)
> GET /rest/things/zwave%3Adevice%3A23daaff0%3Anode7 HTTP/1.1
Host: 10.0.0.63:8080
User-Agent: GuzzleHttp/6.5.5 curl/7.64.1 PHP/7.3.11
Authorization: Basic Og==
< HTTP/1.1 200 OK
< Content-Type: application/json
< Content-Encoding: UTF-8
< Content-Length: 7386
< Server: Jetty(9.4.20.v20190813)
* Unrecognized content encoding type. libcurl understands deflate, gzip content encodings.
* Closing connection 0
The request works fine via the openHAB API web interface and Postman.
I have asked the question on Stackoverflow, but came to think that I may have a better chance here, because Guzzle and the openHAB API may be something others have played with?
