I use openHABian and after 10MB the logfiles get separated, but not gzipped. I think this is standard logrotation to zip old logs to .log.1.gz.
Can this be configured somewhere? Thanks!
I believe on raspbian it only gzips the .2 through .9 logs, leaving .1 unzipped. You can find the logrotate script in /etc/cron.daily/logrotate.
Hmm… I do already have ones up to .3 without gzip.
Thing is, the log4j is configured in /var/lib/openhab2/etc/org.ops4j.pax.logging.cfg
# File appender - openhab.log
log4j.appender.out=org.apache.log4j.RollingFileAppender
log4j.appender.out.layout=org.apache.log4j.PatternLayout
log4j.appender.out.layout.ConversionPattern=%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n
log4j.appender.out.file=${openhab.logdir}/openhab.log
log4j.appender.out.append=true
log4j.appender.out.maxFileSize=10MB
log4j.appender.out.maxBackupIndex=10
I understand gzipping a log file directly is possible with RollingFileAppender
(based on file size) using TimeBasedRollingPolicy
. Some research brought up, that Note that TimeBasedRollingPolicy can only be configured with xml, not log4j.properties
. I don’t want to rewrite the whole logging just to have it gzipped. I can live with 10*10MB backup of logs…
Thanks anyways!
That’s a pity, logback was able to do that in OH1…
Maybe this is a point to re-discuss the logger implementation of pax-logging to use. This was last discussed in https://github.com/openhab/openhab-distro/issues/14 - the outcome was to wait for Karaf 4.1.0 (which is due by the end of this year), which will bring log4j2 (that support gzipping!)
Sorry to lead you down the rabbit hole. I was thinking about logs in general, not openHAB in specific. I just figured that the openHAB logs were rotated when logrotate runs but a quick glance at the script shows that wouldn’t be the case.
Sorry about that.
OK, it’s worth waiting for, if you could just add gzip Support on your own.
don’t be - everything’s cool!
