Haas Sohn Pellet Stove Binding
The binding for Haassohnpelletstove communicates with a Haas and Sohn Pelletstove through the optional WIFI module. More information about the WIFI module can be found here.
Supported Things
Things | Description | Thing Type |
haassohnpelletstove | Control of a Haas & Sohn Pellet Stove | oven |
Thing Configuration
In general two parameters are required. The IP-Address of the WIFI-Modul of the Stove in the local Network and the Access PIN of the Stove. The PIN can be found directly at the stove under the Menue/Network/WLAN-PIN.
Thing haassohnpelletstove:oven:myOven “Pelletstove” [ hostIP=“192.168.0.23”, hostPIN=“1234”]
Channels
The following channels are yet supported:
Channel | Type | Access | Description |
power | Switch | read/write | Turn the stove on/off |
channelIsTemp | Number:Temperature | read | Receives the actual temperature of the stove |
channelSpTemp | Number:Temperature | read/write | Receives and sets the target temperature of the stove |
channelMode | String | read | Receives the actual mode the stove is in like heating, cooling, error, … |
channelEcoMode | Switch | read/write | Turn the eco mode of the stove on/off |
channelIngitions | Number | read | Amount of ignitions of the stove |
channelMaintenanceIn | Number:Mass | read | States the next maintenance in kg |
channelCleaningIn | String | read | States the next cleaning window in hours:minutes as string |
channelConsumption | Number:Mass | read | Total consumption of the stove |
channelOnTime | Number | read | Operation hours of the stove |
Full Example
demo.items:
Number:Temperature isTemp { channel=“oven:channelIsTemp” } Number:Temperature spTemp { channel=“oven:channelSpTemp” } String mode { channel=“oven:channelMode” } Switch power { channel=“oven:power” }
Google Assistant configuration
See also: Google Assistant | openHAB
googleassistantdemo.items
Group g_FeuerThermostat “FeuerThermostat” {ga=“Thermostat” } Number StatusFeuer “Status Feuer” (g_FeuerThermostat) { ga=“thermostatMode” } Number ZieltemperaturFeuer “ZieltemperaturFeuer” (g_FeuerThermostat) {ga=“thermostatTemperatureSetpoint”} Number TemperaturFeuer “TemperaturFeuer” (g_FeuerThermostat) {ga=“thermostatTemperatureAmbient”}
Tested Hardware
The binding was successfully tested with the following ovens:
- HSP 7 DIANA
- HSP6 434.08
Changelog
Version 2.0rc1 (Minimum OH Version 4.3.0 required)
- added: A reconnection rate in case of weak wifi signal. Still in beta testing.
Version 1.0
- initial release
Resources
Latest Release JAR:
Latest JarFile V2.0rc2
Source Code is merged here (pull request created):
Github repository
New Pull Request:
Pull Request
Author
This binding was developed by @Christian_Feininger
