from HABApp.openhab import transformations
TEST_MAP = transformations.map['test.map'] # load the transformation, can be used anywhere
print(TEST_MAP['test_key']) # It's a normal dict with keys as str and values as str
# if all keys or values are numbers they are automatically casted to an int
NUMBERS = transformations.map['numbers.map']
print(NUMBERS[1]) # Note that the key is an int
Sending scheduler datetimes to an item:
job = self.run.on_sunrise(self.my_function)
job.to_item('item_name') # can be openHAB item or HABApp internal item
@Spaceman_Spiff - Thank you! I’ve got it loaded on my test system. On the road right now but working as I can during time off. I had to take about a month off so I may not be totally up to speed on the state of HABApp affairs, but noticed that there is now Transformation support, which is great. Guessing that Actions are not yet available, or did I miss that update? Your work is incredible.
Its great to have search available in the docs! Also, what does this mean: Support sending scheduler datetimes to an item
I must be really missing something because I am not aware of scheduler datetimes?
If you use the scheduler and want the next execution date in an item there is now an easy way for it.
This code snipped will run the my_function every day on sunrise and additionally post the next time of execution to an item.
# Scheduler as usual
# This is new
Very nice. I need to figure out how I’d use that in my current setup.
On the last flight I was on (somewhere over the Mediterranean or Sinai) I got a custom logger working that I will post code example for soon. I know there have been some questions about making one of those, and I’d like to know if I did it correctly.
I have a rule in place that prevents from moving the shutters up when they would close anyway in 30 mins. I’ve implement it a long time ago but this new function makes it much easier.
Just an hour ago stopped my 1.1.2 docker container and started the new 23.09.1 image.
Amazingly everything is working perfectly as before.
Have to spend some time to see what’s everything new in this release.
Nice job done @Spaceman_Spiff
Very nice. Would you care to show it as an example as I am about to take the switch from DSL to HABApp and my first target is a cool automation of my window blinds…
One question.
Ich found this link to a widget for controlling a rollershuter card
There they use a rule to control When the shutter has to move down.
The rule looks to act exactly to The determined time hh:mm
Is there something possible with habap?
So a rule that runs every minute, an hits then the chooses time?
I know that I can run a rule every minute. But will this then hit the time?
i also was searching for a solution but i did not want a rule that triggers regularly and always check if the condition mets.
so i realized it in a different way, with the (habapp) self.run.on_every_day(time...
i only use the basic_ui, but i can set different times for each shutter, and depending if it is a holiday or a workday, looks like
for example the item i defined for a workday looks like:
Number iBuero_Fenster_Ro_opentime_work "Werktag auf[JS(numberToClock.js):%s]" <office>
(i do not mind but the only disatvantage could be that i only have one arrow to increase or decrease the time and so i set the steps to 15 minutes)
in habapp i have a rule that triggers when the time changes, if the listener already exists it will be cancelled and a new one will be created:
def create_listener_morning(self):
Erstellt den Trigger zum Öffnen am Morgen, immer passend ob Werktag oder Feiertag
if self.listener_morning is not None: # (ist nur beim 1. Aufruf noch None)
self.listener_morning.cancel()
open_at = 'opentime_work' if SwitchItem.get_item('iHeuteFeiertag').is_off() \
else 'opentime_holiday'
numeric_time = NumberItem.get_item(self.get_item_name(open_at)).value
hour = int(numeric_time / 60)
minute = int(numeric_time % 60)
self.listener_morning = self.run.on_every_day(time(hour=hour, minute=minute),
self.morning_open)
self.log.debug(f'Open {self.shutter_name} at {hour}:{minute}')
so i only have one trigger with the exact time to open the corresponding shutter
Ok, that would be also enough for me.
But never used these with listeners.
So I need to read about this things.
So your rule just watch the time items. If they change they trigger this python function, creates a new listener, and then if the time is reached the action happens?
yes, thats how i realized it for me to open my shutters in the morning. i didnt want to trigger a rule in timegaps 24/7 and always check if the time is reached to do the action. my rule only triggers to the desired time and then runs the action. the listener is only needed to be able to cancel, for exampke the desired time was 8:00 and you change your item to 8:30. without cancelling you would create a second listener and the action would run at 8:30 but also still at 8:00
