- Platform information:
- Hardware: RPi 4B, 4 Gb
- OS: openhabian 4.0.1
- Issue of the topic:
dusk
event triggers different in HABApp and astro binding
i created a habapp rule to close my shutters at sun dusk
. actually i use the astro binding, i have defined an item
DateTime iRolloJaloZu "Rollos/Jalos schließen um[%1$tH:%1$tM Uhr]" <shutter> { channel="astro:sun:local:nauticDusk#start" }
and this item i display in sitemap to know when shutters will close.
in habapp i use this listener to start my rule
self.listen_event('astro:sun:local:nauticDusk#event', self.check_evening_close,
EventFilter(ChannelTriggeredEvent, event='START'))
and this works well.
now i found out that in habapp there is an easier way for the listener:
self.run.on_sun_dusk(self.check_evening_close)
but this triggers about 5 minutes later then the astro trigger.
i checked the location in habapp config.yml is the same values as in astro.things (lat, long and elev)
i saw in astro i can trigger not only nauticDusk but also civilDusk and astroDusk but there the time differs even more.
triggering 5 minutes later would not be a problem for me, but with the trigger .run.on_sun_dusk
i dont know how i could get the time to be able to display it in the sitemap.
perhaps somebody has an idea for me, thanks!
