have you figured anything out about this yet? Or how to edit the source code to override? M5 broke one of my bindings and I’d like to go up to M7 instead of back to M4…
just to add that I’m also stuck. openHAB without habapp is now unthinkable for me…
Same here. My favorite tool for rules.
Yes - there was a recent change in openHAB 3.3 which causes this issue.
I’ll provide a fix in the next couple of weeks, in the meantime is it possible for you to just go back to 3.2?
I use multiple ItemNoChangeEvent of the same item. I think there is something else going on. Could you open another thread and tag it with HABApp so we can get to the bottom of this?
That is great news - thank you!
Could someone with docker knowledge head over to the beta thread and verify that the new docker image works as expected?
Using Visual Studio Code with remote SSH and python extensin with Habapp
I am trying to use VSC on my windows laptop remotely connected to my raspberry pi v4 (but i would also like to use my pi 3b).
I always get the error
Import "HABApp.core.events" could not be resolvedPylancereportMissingImports
It may be obvious but I am unable to find the right setting of python or pylance extension
(python.venvFolders?)
Can someone point me in the right direction?
Thank you
EDIT: I figured out myself, and I post here the solution.
The point is to set in VSC the “version” of the python interpreter, as explained at this link.
Then, in order to have also files contained in the habapp/lib directory the pylint setting
"python.analysis.extraPaths": [ "/srv/openhab-conf/habapp/lib"]
should be set
Good news everyone! HABApp 1.0 is out!
hello,
i have installed openhabian on a rpi4b an work on oh3.4.0.m3 with installed habapp 1.0.4
i suddenly realize lots of errors in the habapp.log that appear continuosly:
[2022-10-18 11:01:14,802] [ HABApp] INFO | HABApp Version 1.0.4
[2022-10-18 11:01:14,802] [ HABApp.Config] WARN | Replaced class for handler "HABApp_default" with HABApp.config.logging.MidnightRotatingFileHandler
[2022-10-18 11:01:14,802] [ HABApp.Config] WARN | Replaced class for handler "My_HABApp_default" with HABApp.config.logging.MidnightRotatingFileHandler
[2022-10-18 11:01:14,866] [ HABApp.mqtt.connection] INFO | MQTT disabled
[2022-10-18 11:01:14,992] [HABApp.openhab.connection] INFO | Connected to OpenHAB version 3.4.0.M3 (Milestone Build)
[2022-10-18 11:01:15,933] [ HABApp.openhab.items] INFO | Updated 584 Items
[2022-10-18 11:01:16,241] [ HABApp.openhab.items] INFO | Updated 257 Things
[2022-10-18 11:01:16,877] [ HABApp.EventBus] INFO | iSl_pac: <ItemStateEvent name: iSl_pac, value: 8560>
[2022-10-18 11:01:16,882] [ HABApp.EventBus] INFO | iSl_pac: <ItemStateChangedEvent name: iSl_pac, value: 8560, old_value: 8527>
[2022-10-18 11:01:16,885] [ HABApp.EventBus] INFO | iSl_yieldday: <ItemStateEvent name: iSl_yieldday, value: 11571>
[2022-10-18 11:01:16,887] [ HABApp.EventBus] INFO | solarlog:meter:pv: <ThingStatusInfoEvent name: solarlog:meter:pv, status: ONLINE, detail: None>
[2022-10-18 11:01:16,888] [ HABApp.EventBus] INFO | iSl_yieldday: <ItemStateChangedEvent name: iSl_yieldday, value: 11571, old_value: 11500>
[2022-10-18 11:01:23,654] [ HABApp] ERROR | Error 'topic' in on_sse_event:
[2022-10-18 11:01:23,654] [ HABApp] ERROR | File "/opt/habapp/lib/python3.9/site-packages/HABApp/openhab/connection_handler/sse_handler.py", line 31 in on_sse_event
[2022-10-18 11:01:23,654] [ HABApp] ERROR | --------------------------------------------------------------------------------
[2022-10-18 11:01:23,654] [ HABApp] ERROR | 28 | def on_sse_event(event_dict: dict):
[2022-10-18 11:01:23,654] [ HABApp] ERROR | 29 | try:
[2022-10-18 11:01:23,655] [ HABApp] ERROR | 30 | # Lookup corresponding OpenHAB event
[2022-10-18 11:01:23,655] [ HABApp] ERROR | --> 31 | event = get_event(event_dict)
[2022-10-18 11:01:23,655] [ HABApp] ERROR | 33 | # Update item in registry BEFORE posting to the event bus
[2022-10-18 11:01:23,655] [ HABApp] ERROR | 34 | # so the items have the correct state when we process the event in a rule
[2022-10-18 11:01:23,655] [ HABApp] ERROR | ------------------------------------------------------------
[2022-10-18 11:01:23,655] [ HABApp] ERROR | (ItemAddedEvent, ItemUpdatedEvent) = (<class 'HABApp.openhab.events.item_events.ItemAddedEvent'>, <class 'HABApp.openhab.events.item_events.ItemUpdatedEvent'>)
[2022-10-18 11:01:23,655] [ HABApp] ERROR | (ThingStatusInfoEvent, ThingUpdatedEvent) = (<class 'HABApp.openhab.events.thing_events.ThingStatusInfoEvent'>, <class 'HABApp.openhab.events.thing_events.ThingUpdatedEvent'>)
[2022-10-18 11:01:23,656] [ HABApp] ERROR | e = KeyError('topic')
[2022-10-18 11:01:23,656] [ HABApp] ERROR | event_dict = {'type': 'ALIVE', 'interval': 10}
[2022-10-18 11:01:23,656] [ HABApp] ERROR | log = <Logger HABApp.openhab.connection (INFO)>
[2022-10-18 11:01:23,656] [ HABApp] ERROR | TOPIC_ITEMS = 'openHAB.Items'
[2022-10-18 11:01:23,656] [ HABApp] ERROR | TOPIC_THINGS = 'openHAB.Things'
[2022-10-18 11:01:23,656] [ HABApp] ERROR | ------------------------------------------------------------
[2022-10-18 11:01:23,657] [ HABApp] ERROR | File "/opt/habapp/lib/python3.9/site-packages/HABApp/openhab/map_events.py", line 31 in get_event
[2022-10-18 11:01:23,657] [ HABApp] ERROR | --------------------------------------------------------------------------------
[2022-10-18 11:01:23,657] [ HABApp] ERROR | 29 | def get_event(_in_dict: dict) -> OpenhabEvent:
[2022-10-18 11:01:23,657] [ HABApp] ERROR | 30 | event_type: str = _in_dict['type']
[2022-10-18 11:01:23,657] [ HABApp] ERROR | --> 31 | topic: str = _in_dict['topic']
[2022-10-18 11:01:23,657] [ HABApp] ERROR | 33 | # Workaround for None values in the payload str
[2022-10-18 11:01:23,658] [ HABApp] ERROR | ------------------------------------------------------------
[2022-10-18 11:01:23,658] [ HABApp] ERROR | _events = {'ItemStateEvent': <class 'HABApp.openhab.events.item_events.ItemStateEvent'>, 'ItemStateChangedEvent': <class 'HABApp.openhab.events.item_events.ItemStateChangedEvent'>, 'ItemCommandEvent': <class 'HABApp.openhab.events.item_events.ItemCommandEvent'>, 'ItemAddedEvent': <class 'HABApp.openhab.events.item_events.ItemAddedEvent'>, 'ItemUpdatedEvent': <class 'HABApp.openhab.events.item_events.ItemUpdatedEvent'>, 'ItemRemovedEvent': <class 'HABApp.openhab.events.item_events.ItemRemovedEvent'>, 'ItemStatePredictedEvent': <class 'HABApp.openhab.events.item_events.ItemStatePredictedEvent'>, 'GroupItemStateChangedEvent': <class 'HABApp.openhab.events.item_events.GroupItemStateChangedEvent'>, 'ChannelTriggeredEvent': <class 'HABApp.openhab.events.channel_events.ChannelTriggeredEvent'>, 'ChannelDescriptionChangedEvent': <class 'HABApp.openhab.events.channel_events.ChannelDescriptionChangedEvent'>, 'ThingAddedEvent': <class 'HABApp.openhab.events.thing_events.ThingAddedEvent'>, 'ThingRemovedEvent': <class 'HABApp.openhab.events.thing_events.ThingRemovedEvent'>, 'ThingUpdatedEvent': <class 'HABApp.openhab.events.thing_events.ThingUpdatedEvent'>, 'ThingStatusInfoEvent': <class 'HABApp.openhab.events.thing_events.ThingStatusInfoEvent'>, 'ThingStatusInfoChangedEvent': <class 'HABApp.openhab.events.thing_events.ThingStatusInfoChangedEvent'>, 'ThingFirmwareStatusInfoEvent': <class 'HABApp.openhab.events.thing_events.ThingFirmwareStatusInfoEvent'>, 'FirmwareStatusInfoEvent': <class 'HABApp.openhab.events.thing_events.ThingFirmwareStatusInfoEvent'>}
[2022-10-18 11:01:23,658] [ HABApp] ERROR | _in_dict = {'type': 'ALIVE', 'interval': 10}
[2022-10-18 11:01:23,658] [ HABApp] ERROR | _in_dict['type'] = 'ALIVE'
[2022-10-18 11:01:23,658] [ HABApp] ERROR | event_type = 'ALIVE'
[2022-10-18 11:01:23,659] [ HABApp] ERROR |
[2022-10-18 11:01:23,659] [ HABApp] ERROR | --------------------------------------------------------------------------------
[2022-10-18 11:01:23,659] [ HABApp] ERROR | Traceback (most recent call last):
[2022-10-18 11:01:23,659] [ HABApp] ERROR | File "/opt/habapp/lib/python3.9/site-packages/HABApp/openhab/connection_handler/sse_handler.py", line 31, in on_sse_event
[2022-10-18 11:01:23,659] [ HABApp] ERROR | event = get_event(event_dict)
[2022-10-18 11:01:23,659] [ HABApp] ERROR | File "/opt/habapp/lib/python3.9/site-packages/HABApp/openhab/map_events.py", line 31, in get_event
[2022-10-18 11:01:23,659] [ HABApp] ERROR | topic: str = _in_dict['topic']
[2022-10-18 11:01:23,660] [ HABApp] ERROR | KeyError: 'topic'
[2022-10-18 11:01:23,660] [ HABApp.EventBus] INFO | HABApp.Errors: <HABAppException func_name: on_sse_event, exception: 'topic'>
[2022-10-18 11:01:33,536] [ HABApp] ERROR | Error 'topic' in on_sse_event:
[2022-10-18 11:01:33,536] [ HABApp] ERROR | File "/opt/habapp/lib/python3.9/site-packages/HABApp/openhab/connection_handler/sse_handler.py", line 31 in on_sse_event
[2022-10-18 11:01:33,536] [ HABApp] ERROR | --------------------------------------------------------------------------------
[2022-10-18 11:01:33,537] [ HABApp] ERROR | 28 | def on_sse_event(event_dict: dict):
[2022-10-18 11:01:33,537] [ HABApp] ERROR | 29 | try:
[2022-10-18 11:01:33,537] [ HABApp] ERROR | 30 | # Lookup corresponding OpenHAB event
[2022-10-18 11:01:33,537] [ HABApp] ERROR | --> 31 | event = get_event(event_dict)
[2022-10-18 11:01:33,537] [ HABApp] ERROR | 33 | # Update item in registry BEFORE posting to the event bus
[2022-10-18 11:01:33,537] [ HABApp] ERROR | 34 | # so the items have the correct state when we process the event in a rule
[2022-10-18 11:01:33,538] [ HABApp] ERROR | ------------------------------------------------------------
[2022-10-18 11:01:33,538] [ HABApp] ERROR | (ItemAddedEvent, ItemUpdatedEvent) = (<class 'HABApp.openhab.events.item_events.ItemAddedEvent'>, <class 'HABApp.openhab.events.item_events.ItemUpdatedEvent'>)
[2022-10-18 11:01:33,538] [ HABApp] ERROR | (ThingStatusInfoEvent, ThingUpdatedEvent) = (<class 'HABApp.openhab.events.thing_events.ThingStatusInfoEvent'>, <class 'HABApp.openhab.events.thing_events.ThingUpdatedEvent'>)
[2022-10-18 11:01:33,538] [ HABApp] ERROR | e = KeyError('topic')
[2022-10-18 11:01:33,538] [ HABApp] ERROR | event_dict = {'type': 'ALIVE', 'interval': 10}
[2022-10-18 11:01:33,538] [ HABApp] ERROR | log = <Logger HABApp.openhab.connection (INFO)>
[2022-10-18 11:01:33,538] [ HABApp] ERROR | TOPIC_ITEMS = 'openHAB.Items'
[2022-10-18 11:01:33,538] [ HABApp] ERROR | TOPIC_THINGS = 'openHAB.Things'
[2022-10-18 11:01:33,539] [ HABApp] ERROR | ------------------------------------------------------------
[2022-10-18 11:01:33,539] [ HABApp] ERROR | File "/opt/habapp/lib/python3.9/site-packages/HABApp/openhab/map_events.py", line 31 in get_event
[2022-10-18 11:01:33,539] [ HABApp] ERROR | --------------------------------------------------------------------------------
[2022-10-18 11:01:33,539] [ HABApp] ERROR | 29 | def get_event(_in_dict: dict) -> OpenhabEvent:
[2022-10-18 11:01:33,539] [ HABApp] ERROR | 30 | event_type: str = _in_dict['type']
[2022-10-18 11:01:33,539] [ HABApp] ERROR | --> 31 | topic: str = _in_dict['topic']
[2022-10-18 11:01:33,539] [ HABApp] ERROR | 33 | # Workaround for None values in the payload str
[2022-10-18 11:01:33,540] [ HABApp] ERROR | ------------------------------------------------------------
[2022-10-18 11:01:33,540] [ HABApp] ERROR | _events = {'ItemStateEvent': <class 'HABApp.openhab.events.item_events.ItemStateEvent'>, 'ItemStateChangedEvent': <class 'HABApp.openhab.events.item_events.ItemStateChangedEvent'>, 'ItemCommandEvent': <class 'HABApp.openhab.events.item_events.ItemCommandEvent'>, 'ItemAddedEvent': <class 'HABApp.openhab.events.item_events.ItemAddedEvent'>, 'ItemUpdatedEvent': <class 'HABApp.openhab.events.item_events.ItemUpdatedEvent'>, 'ItemRemovedEvent': <class 'HABApp.openhab.events.item_events.ItemRemovedEvent'>, 'ItemStatePredictedEvent': <class 'HABApp.openhab.events.item_events.ItemStatePredictedEvent'>, 'GroupItemStateChangedEvent': <class 'HABApp.openhab.events.item_events.GroupItemStateChangedEvent'>, 'ChannelTriggeredEvent': <class 'HABApp.openhab.events.channel_events.ChannelTriggeredEvent'>, 'ChannelDescriptionChangedEvent': <class 'HABApp.openhab.events.channel_events.ChannelDescriptionChangedEvent'>, 'ThingAddedEvent': <class 'HABApp.openhab.events.thing_events.ThingAddedEvent'>, 'ThingRemovedEvent': <class 'HABApp.openhab.events.thing_events.ThingRemovedEvent'>, 'ThingUpdatedEvent': <class 'HABApp.openhab.events.thing_events.ThingUpdatedEvent'>, 'ThingStatusInfoEvent': <class 'HABApp.openhab.events.thing_events.ThingStatusInfoEvent'>, 'ThingStatusInfoChangedEvent': <class 'HABApp.openhab.events.thing_events.ThingStatusInfoChangedEvent'>, 'ThingFirmwareStatusInfoEvent': <class 'HABApp.openhab.events.thing_events.ThingFirmwareStatusInfoEvent'>, 'FirmwareStatusInfoEvent': <class 'HABApp.openhab.events.thing_events.ThingFirmwareStatusInfoEvent'>}
[2022-10-18 11:01:33,540] [ HABApp] ERROR | _in_dict = {'type': 'ALIVE', 'interval': 10}
[2022-10-18 11:01:33,540] [ HABApp] ERROR | _in_dict['type'] = 'ALIVE'
[2022-10-18 11:01:33,540] [ HABApp] ERROR | event_type = 'ALIVE'
[2022-10-18 11:01:33,541] [ HABApp] ERROR | --------------------------------------------------------------------------------
[2022-10-18 11:01:33,541] [ HABApp] ERROR | Traceback (most recent call last):
[2022-10-18 11:01:33,541] [ HABApp] ERROR | File "/opt/habapp/lib/python3.9/site-packages/HABApp/openhab/connection_handler/sse_handler.py", line 31, in on_sse_event
[2022-10-18 11:01:33,541] [ HABApp] ERROR | event = get_event(event_dict)
[2022-10-18 11:01:33,541] [ HABApp] ERROR | File "/opt/habapp/lib/python3.9/site-packages/HABApp/openhab/map_events.py", line 31, in get_event
[2022-10-18 11:01:33,541] [ HABApp] ERROR | topic: str = _in_dict['topic']
[2022-10-18 11:01:33,541] [ HABApp] ERROR | KeyError: 'topic'
[2022-10-18 11:01:33,541] [ HABApp.EventBus] INFO | HABApp.Errors: <HABAppException func_name: on_sse_event, exception: 'topic'>
[2022-10-18 11:01:43,535] [ HABApp] ERROR | Error 'topic' in on_sse_event:
[2022-10-18 11:01:43,535] [ HABApp] ERROR | File "/opt/habapp/lib/python3.9/site-packages/HABApp/openhab/connection_handler/sse_handler.py", line 31 in on_sse_event
[2022-10-18 11:01:43,535] [ HABApp] ERROR | --------------------------------------------------------------------------------
[2022-10-18 11:01:43,536] [ HABApp] ERROR | 28 | def on_sse_event(event_dict: dict):
[2022-10-18 11:01:43,536] [ HABApp] ERROR | 29 | try:
[2022-10-18 11:01:43,536] [ HABApp] ERROR | 30 | # Lookup corresponding OpenHAB event
[2022-10-18 11:01:43,536] [ HABApp] ERROR | --> 31 | event = get_event(event_dict)
[2022-10-18 11:01:43,537] [ HABApp] ERROR | 33 | # Update item in registry BEFORE posting to the event bus
[2022-10-18 11:01:43,537] [ HABApp] ERROR | 34 | # so the items have the correct state when we process the event in a rule
[2022-10-18 11:01:43,537] [ HABApp] ERROR | ------------------------------------------------------------
[2022-10-18 11:01:43,537] [ HABApp] ERROR | (ItemAddedEvent, ItemUpdatedEvent) = (<class 'HABApp.openhab.events.item_events.ItemAddedEvent'>, <class 'HABApp.openhab.events.item_events.ItemUpdatedEvent'>)
[2022-10-18 11:01:43,537] [ HABApp] ERROR | (ThingStatusInfoEvent, ThingUpdatedEvent) = (<class 'HABApp.openhab.events.thing_events.ThingStatusInfoEvent'>, <class 'HABApp.openhab.events.thing_events.ThingUpdatedEvent'>)
[2022-10-18 11:01:43,538] [ HABApp] ERROR | e = KeyError('topic')
[2022-10-18 11:01:43,538] [ HABApp] ERROR | event_dict = {'type': 'ALIVE', 'interval': 10}
[2022-10-18 11:01:43,538] [ HABApp] ERROR | log = <Logger HABApp.openhab.connection (INFO)>
[2022-10-18 11:01:43,538] [ HABApp] ERROR | TOPIC_ITEMS = 'openHAB.Items'
[2022-10-18 11:01:43,538] [ HABApp] ERROR | TOPIC_THINGS = 'openHAB.Things'
[2022-10-18 11:01:43,538] [ HABApp] ERROR | ------------------------------------------------------------
[2022-10-18 11:01:43,539] [ HABApp] ERROR |
[2022-10-18 11:01:43,539] [ HABApp] ERROR | File "/opt/habapp/lib/python3.9/site-packages/HABApp/openhab/map_events.py", line 31 in get_event
[2022-10-18 11:01:43,539] [ HABApp] ERROR | --------------------------------------------------------------------------------
[2022-10-18 11:01:43,539] [ HABApp] ERROR | 29 | def get_event(_in_dict: dict) -> OpenhabEvent:
[2022-10-18 11:01:43,539] [ HABApp] ERROR | 30 | event_type: str = _in_dict['type']
[2022-10-18 11:01:43,539] [ HABApp] ERROR | --> 31 | topic: str = _in_dict['topic']
[2022-10-18 11:01:43,539] [ HABApp] ERROR | 33 | # Workaround for None values in the payload str
[2022-10-18 11:01:43,540] [ HABApp] ERROR | ------------------------------------------------------------
[2022-10-18 11:01:43,540] [ HABApp] ERROR | _events = {'ItemStateEvent': <class 'HABApp.openhab.events.item_events.ItemStateEvent'>, 'ItemStateChangedEvent': <class 'HABApp.openhab.events.item_events.ItemStateChangedEvent'>, 'ItemCommandEvent': <class 'HABApp.openhab.events.item_events.ItemCommandEvent'>, 'ItemAddedEvent': <class 'HABApp.openhab.events.item_events.ItemAddedEvent'>, 'ItemUpdatedEvent': <class 'HABApp.openhab.events.item_events.ItemUpdatedEvent'>, 'ItemRemovedEvent': <class 'HABApp.openhab.events.item_events.ItemRemovedEvent'>, 'ItemStatePredictedEvent': <class 'HABApp.openhab.events.item_events.ItemStatePredictedEvent'>, 'GroupItemStateChangedEvent': <class 'HABApp.openhab.events.item_events.GroupItemStateChangedEvent'>, 'ChannelTriggeredEvent': <class 'HABApp.openhab.events.channel_events.ChannelTriggeredEvent'>, 'ChannelDescriptionChangedEvent': <class 'HABApp.openhab.events.channel_events.ChannelDescriptionChangedEvent'>, 'ThingAddedEvent': <class 'HABApp.openhab.events.thing_events.ThingAddedEvent'>, 'ThingRemovedEvent': <class 'HABApp.openhab.events.thing_events.ThingRemovedEvent'>, 'ThingUpdatedEvent': <class 'HABApp.openhab.events.thing_events.ThingUpdatedEvent'>, 'ThingStatusInfoEvent': <class 'HABApp.openhab.events.thing_events.ThingStatusInfoEvent'>, 'ThingStatusInfoChangedEvent': <class 'HABApp.openhab.events.thing_events.ThingStatusInfoChangedEvent'>, 'ThingFirmwareStatusInfoEvent': <class 'HABApp.openhab.events.thing_events.ThingFirmwareStatusInfoEvent'>, 'FirmwareStatusInfoEvent': <class 'HABApp.openhab.events.thing_events.ThingFirmwareStatusInfoEvent'>}
[2022-10-18 11:01:43,540] [ HABApp] ERROR | _in_dict = {'type': 'ALIVE', 'interval': 10}
[2022-10-18 11:01:43,540] [ HABApp] ERROR | _in_dict['type'] = 'ALIVE'
[2022-10-18 11:01:43,540] [ HABApp] ERROR | event_type = 'ALIVE'
[2022-10-18 11:01:43,541] [ HABApp] ERROR |
[2022-10-18 11:01:43,541] [ HABApp] ERROR | --------------------------------------------------------------------------------
[2022-10-18 11:01:43,541] [ HABApp] ERROR | Traceback (most recent call last):
[2022-10-18 11:01:43,541] [ HABApp] ERROR | File "/opt/habapp/lib/python3.9/site-packages/HABApp/openhab/connection_handler/sse_handler.py", line 31, in on_sse_event
[2022-10-18 11:01:43,541] [ HABApp] ERROR | event = get_event(event_dict)
[2022-10-18 11:01:43,541] [ HABApp] ERROR | File "/opt/habapp/lib/python3.9/site-packages/HABApp/openhab/map_events.py", line 31, in get_event
[2022-10-18 11:01:43,541] [ HABApp] ERROR | topic: str = _in_dict['topic']
[2022-10-18 11:01:43,542] [ HABApp] ERROR | KeyError: 'topic'
[2022-10-18 11:01:43,542] [ HABApp.EventBus] INFO | HABApp.Errors: <HABAppException func_name: on_sse_event, exception: 'topic'>
[2022-10-18 11:01:46,946] [ HABApp.EventBus] INFO | iSl_pac: <ItemStateEvent name: iSl_pac, value: 8576>
[2022-10-18 11:01:46,951] [ HABApp.EventBus] INFO | iSl_yieldday: <ItemStateEvent name: iSl_yieldday, value: 11642>
[2022-10-18 11:01:46,953] [ HABApp.EventBus] INFO | iSl_pac: <ItemStateChangedEvent name: iSl_pac, value: 8576, old_value: 8560>
[2022-10-18 11:01:46,955] [ HABApp.EventBus] INFO | solarlog:meter:pv: <ThingStatusInfoEvent name: solarlog:meter:pv, status: ONLINE, detail: None>
[2022-10-18 11:01:46,956] [ HABApp.EventBus] INFO | iSl_yieldday: <ItemStateChangedEvent name: iSl_yieldday, value: 11642, old_value: 11571>
[2022-10-18 11:01:53,535] [ HABApp] ERROR | Error 'topic' in on_sse_event:
[2022-10-18 11:01:53,536] [ HABApp] ERROR | File "/opt/habapp/lib/python3.9/site-packages/HABApp/openhab/connection_handler/sse_handler.py", line 31 in on_sse_event
[2022-10-18 11:01:53,536] [ HABApp] ERROR | --------------------------------------------------------------------------------
[2022-10-18 11:01:53,536] [ HABApp] ERROR | 28 | def on_sse_event(event_dict: dict):
[2022-10-18 11:01:53,536] [ HABApp] ERROR | 29 | try:
[2022-10-18 11:01:53,537] [ HABApp] ERROR | 30 | # Lookup corresponding OpenHAB event
[2022-10-18 11:01:53,537] [ HABApp] ERROR | --> 31 | event = get_event(event_dict)
[2022-10-18 11:01:53,537] [ HABApp] ERROR | 33 | # Update item in registry BEFORE posting to the event bus
[2022-10-18 11:01:53,537] [ HABApp] ERROR | 34 | # so the items have the correct state when we process the event in a rule
[2022-10-18 11:01:53,538] [ HABApp] ERROR | ------------------------------------------------------------
[2022-10-18 11:01:53,538] [ HABApp] ERROR | (ItemAddedEvent, ItemUpdatedEvent) = (<class 'HABApp.openhab.events.item_events.ItemAddedEvent'>, <class 'HABApp.openhab.events.item_events.ItemUpdatedEvent'>)
[2022-10-18 11:01:53,538] [ HABApp] ERROR | (ThingStatusInfoEvent, ThingUpdatedEvent) = (<class 'HABApp.openhab.events.thing_events.ThingStatusInfoEvent'>, <class 'HABApp.openhab.events.thing_events.ThingUpdatedEvent'>)
[2022-10-18 11:01:53,538] [ HABApp] ERROR | e = KeyError('topic')
[2022-10-18 11:01:53,539] [ HABApp] ERROR | event_dict = {'type': 'ALIVE', 'interval': 10}
[2022-10-18 11:01:53,539] [ HABApp] ERROR | log = <Logger HABApp.openhab.connection (INFO)>
[2022-10-18 11:01:53,539] [ HABApp] ERROR | TOPIC_ITEMS = 'openHAB.Items'
[2022-10-18 11:01:53,539] [ HABApp] ERROR | TOPIC_THINGS = 'openHAB.Things'
[2022-10-18 11:01:53,539] [ HABApp] ERROR | ------------------------------------------------------------
[2022-10-18 11:01:53,540] [ HABApp] ERROR |
[2022-10-18 11:01:53,540] [ HABApp] ERROR | File "/opt/habapp/lib/python3.9/site-packages/HABApp/openhab/map_events.py", line 31 in get_event
[2022-10-18 11:01:53,540] [ HABApp] ERROR | --------------------------------------------------------------------------------
[2022-10-18 11:01:53,540] [ HABApp] ERROR | 29 | def get_event(_in_dict: dict) -> OpenhabEvent:
[2022-10-18 11:01:53,541] [ HABApp] ERROR | 30 | event_type: str = _in_dict['type']
[2022-10-18 11:01:53,541] [ HABApp] ERROR | --> 31 | topic: str = _in_dict['topic']
[2022-10-18 11:01:53,541] [ HABApp] ERROR | 33 | # Workaround for None values in the payload str
[2022-10-18 11:01:53,541] [ HABApp] ERROR | ------------------------------------------------------------
[2022-10-18 11:01:53,542] [ HABApp] ERROR | _events = {'ItemStateEvent': <class 'HABApp.openhab.events.item_events.ItemStateEvent'>, 'ItemStateChangedEvent': <class 'HABApp.openhab.events.item_events.ItemStateChangedEvent'>, 'ItemCommandEvent': <class 'HABApp.openhab.events.item_events.ItemCommandEvent'>, 'ItemAddedEvent': <class 'HABApp.openhab.events.item_events.ItemAddedEvent'>, 'ItemUpdatedEvent': <class 'HABApp.openhab.events.item_events.ItemUpdatedEvent'>, 'ItemRemovedEvent': <class 'HABApp.openhab.events.item_events.ItemRemovedEvent'>, 'ItemStatePredictedEvent': <class 'HABApp.openhab.events.item_events.ItemStatePredictedEvent'>, 'GroupItemStateChangedEvent': <class 'HABApp.openhab.events.item_events.GroupItemStateChangedEvent'>, 'ChannelTriggeredEvent': <class 'HABApp.openhab.events.channel_events.ChannelTriggeredEvent'>, 'ChannelDescriptionChangedEvent': <class 'HABApp.openhab.events.channel_events.ChannelDescriptionChangedEvent'>, 'ThingAddedEvent': <class 'HABApp.openhab.events.thing_events.ThingAddedEvent'>, 'ThingRemovedEvent': <class 'HABApp.openhab.events.thing_events.ThingRemovedEvent'>, 'ThingUpdatedEvent': <class 'HABApp.openhab.events.thing_events.ThingUpdatedEvent'>, 'ThingStatusInfoEvent': <class 'HABApp.openhab.events.thing_events.ThingStatusInfoEvent'>, 'ThingStatusInfoChangedEvent': <class 'HABApp.openhab.events.thing_events.ThingStatusInfoChangedEvent'>, 'ThingFirmwareStatusInfoEvent': <class 'HABApp.openhab.events.thing_events.ThingFirmwareStatusInfoEvent'>, 'FirmwareStatusInfoEvent': <class 'HABApp.openhab.events.thing_events.ThingFirmwareStatusInfoEvent'>}
[2022-10-18 11:01:53,542] [ HABApp] ERROR | _in_dict = {'type': 'ALIVE', 'interval': 10}
[2022-10-18 11:01:53,542] [ HABApp] ERROR | _in_dict['type'] = 'ALIVE'
[2022-10-18 11:01:53,542] [ HABApp] ERROR | event_type = 'ALIVE'
[2022-10-18 11:01:53,543] [ HABApp] ERROR | ------------------------------------------------------------
[2022-10-18 11:01:53,543] [ HABApp] ERROR | --------------------------------------------------------------------------------
[2022-10-18 11:01:53,543] [ HABApp] ERROR | Traceback (most recent call last):
[2022-10-18 11:01:53,544] [ HABApp] ERROR | File "/opt/habapp/lib/python3.9/site-packages/HABApp/openhab/connection_handler/sse_handler.py", line 31, in on_sse_event
[2022-10-18 11:01:53,544] [ HABApp] ERROR | event = get_event(event_dict)
[2022-10-18 11:01:53,544] [ HABApp] ERROR | File "/opt/habapp/lib/python3.9/site-packages/HABApp/openhab/map_events.py", line 31, in get_event
[2022-10-18 11:01:53,544] [ HABApp] ERROR | topic: str = _in_dict['topic']
[2022-10-18 11:01:53,544] [ HABApp] ERROR | KeyError: 'topic'
i tried without success:
- uninstalled habapp, deleted folder /opt/habapp and installed again
- disabled my mqtt-things and 1wire-things
- removed all rule files from habapp folder /rules and /lib
sorry i am lost with this error messages and would be glad if somebody could help me to eliminate them. thanks in advance
It’s a modified event type that came with 3.4.0 M3. Downgrading to 3.4 M2 will solve the issue.
The fix is already available in the dev branch. If you want to try it out you can install the dev branch.
Installation instruction can be found here. I’ll release the dev branch in the next 5 to 10 days.
this did the trick, thank you very much!
9 posts were split to a new topic: Dynamically create HABApp Rules with auto discovery
What would be the best way to get the dates of the (oldest/…/newest) min and max values?
And I (as in google) could not find any documentation for return type OpenhabPersistenceData as it seems there is also a .from_dict() method?
If there is only one maximum you can do this:
max_value = -999_999
max_time = None
min_value = 999_999
min_time = None
for timestamp, value in returned_obj.data.items():
if value > max_value:
max_value = value
max_time = timestamp
if value < min_value:
min_value = value
min_time = timestamp
Ah, I see, thx. This is even nicer than list comprehension and sorting. Takes only one pass.
Why I was asking was that in my OH1 xtext based rule I had
Min = (TempIn.minimumSince(now.minusHours(hoursBack), dataStore).state as DecimalType)
So I wondered, if there was something similar in HABApp.
If you create an issue where you properly describe what your goal is and what you like to achieve I might implement it in one of the upcoming versions.
If you are only interested in the value there is the .min(), .max(), and average() function on the OpenhabPersistenceData object.
If you want this value(s) to refresh automatically you can use the AggregationItem to do everything in memory.
Has anyone any experience using HABapp with openHAB 4.0.0.M1?
I ask in advance…
Nope - I am still on 3.4 and haven’t run any tests yet.
But for now I don’t expect any problems.
If you try it out it would be nice if you could let us know …
Hi all,
I am currently moving some of my rules to HABApp and it works great so far. Thank you very much for this!
The one thing I can not get my head around is testing my rules. Can someone share an example?
Can you post an example rule which you want to test via pytest / unittest?
