I aim to use the HABApp functionality as much as possible but sometimes I need to define my own little helper functions. I’ve put all those into a file named myutils.py
that resides in the habapp/lib
folder:
import json
import logging
import subprocess
from datetime import date, datetime
from typing import Dict, Optional, Union
from HABApp import DictParameter
from HABApp.mqtt.items import MqttItem
from HABApp.openhab.definitions import OnOffValue, OpenClosedValue, UpDownValue
from HABApp.openhab.items import NumberItem, StringItem
configuration = DictParameter('my_config', 'configuration', default_value=None).value
lighting_configuration = DictParameter('lighting_config', 'configuration', default_value=None).value
LIGHT_LEVEL = lighting_configuration["lighting"]["LIGHT_LEVEL"]
SOLAR_TIME_OF_DAY = configuration["time_of_day"]["SOLAR_TIME_OF_DAY"]
CLOCK_TIME_OF_DAY = configuration["time_of_day"]["CLOCK_TIME_OF_DAY"]
lametric_configuration = configuration["lametric"]
customItemNames = configuration["custom_item_names"]
sonos = configuration["sonos"]
log = logging.getLogger(f'{configuration["system"]["MY_LOGGER_NAME"]}.myutils')
log.setLevel(logging.INFO)
# Some useful constants
ON = OnOffValue.ON
OFF = OnOffValue.OFF
OPEN = OpenClosedValue.OPEN
CLOSED = OpenClosedValue.CLOSED
UP = UpDownValue.UP
DOWN = UpDownValue.DOWN
SPC_AREA_MODE = {'unset': 0, 'partset_a': 1, 'partset_b': 2, 'set': 3}
PRIO = {'LOW': 0, 'MODERATE': 1, 'HIGH': 2, 'EMERGENCY': 3}
def calendar_days_between(start_date_or_datetime: Union[date, datetime], end_date_or_datetime: Union[date, datetime]) -> int:
Get the number of calendar days between two dates or datetimes.
start_date = start_date_or_datetime.date() if isinstance(start_date_or_datetime, datetime) else start_date_or_datetime
end_date = end_date_or_datetime.date() if isinstance(end_date_or_datetime, datetime) else end_date_or_datetime
num_days_between = (start_date - end_date).days
return num_days_between
def get_key_for_value(dictionary: Dict[str, str], value: str) -> Optional[str]:
In a given dictionary, get the first key that has a value matching the one provided.
Args:
dictionary (dict): the dictionary to search
value (str): the value to match to a key
Returns:
str or None: string representing the first key with a matching value, or
None if the value is not found
return next((k for k, v in dictionary.items() if v == value), None)
def spc_area_is_set():
Returns True if the SPC alarm area 1 is either partial or fully set otherwise returns False
item_value = StringItem.get_item('SPC_Area_1_Mode').value
if item_value is not None:
return SPC_AREA_MODE.get(item_value, 0) > 0
else:
return False
def spc_area_is_fully_set():
Returns True if the SPC alarm area 1 is fully set otherwise returns False
return SPC_AREA_MODE.get(item_value, 0) == 3
else:
return False
def spc_area_is_partially_set():
return SPC_AREA_MODE.get(item_value, 0) == 1
else:
return False
def get_compass_direction(degrees):
Returns the compass direction abbreviation (Swedish) for the given compass degree
COMPASS_DIRECTIONS = {
(0, 22.5): 'N',
(22.5, 67.5): 'NNO',
(67.5, 112.5): 'O',
(112.5, 157.5): 'OSO',
(157.5, 202.5): 'S',
(202.5, 247.5): 'SSO',
(247.5, 292.5): 'V',
(292.5, 337.5): 'VNV',
(337.5, 360): 'N'
for degree_range, direction in COMPASS_DIRECTIONS.items():
if degree_range[0] <= degrees < degree_range[1]:
return direction
def is_light_level_bright() -> bool:
"""Checks if the light level is bright."""
light_level_item = NumberItem.get_item(customItemNames['sysLightLevel'])
return light_level_item.value == LIGHT_LEVEL['BRIGHT'] if light_level_item.value is not None else False
def is_light_level_shady() -> bool:
"""Checks if the light level is shady."""
return light_level_item.value <= LIGHT_LEVEL['SHADY'] if light_level_item.value is not None else False
def is_light_level_dark() -> bool:
"""Checks if the light level is dark."""
return light_level_item.value <= LIGHT_LEVEL['DARK'] if light_level_item.value is not None else False
def is_light_level_black() -> bool:
"""Checks if the light level is black."""
return light_level_item.value <= LIGHT_LEVEL['BLACK'] if light_level_item.value is not None else False
def is_clock_night() -> bool:
"""Checks if the clock indicates night."""
clock_time_item = StringItem.get_item(customItemNames['clock_time_of_day_item'])
return clock_time_item.value == CLOCK_TIME_OF_DAY[3] if clock_time_item.value is not None else False
def is_solar_night() -> bool:
"""Checks if the solar position indicates night."""
solar_time_item = StringItem.get_item(customItemNames['solar_time_of_day_item'])
return solar_time_item.value == SOLAR_TIME_OF_DAY[3] if solar_time_item.value is not None else False
def calculate_speech_time_secs(text: str) -> int:
'''Calculates the delay required for speaking a text string based on the character length and speaking speed.'''
CHARACTERS_PER_SECOND = 6
ADDITIONAL_DELAY_SECONDS = 3
CHARACTER_LENGTH_ADJUSTMENT_FACTOR = 1.2
character_count = len(text)
return int((character_count / CHARACTERS_PER_SECOND) * CHARACTER_LENGTH_ADJUSTMENT_FACTOR + ADDITIONAL_DELAY_SECONDS)
NOTIFICATION_DEFAULT_LANGUAGE = "sv-SE"
NOTIFICATION_DEFAULT_ENGINE = "neural"
NOTIFICATION_DEFAULT_ROOM = "Vardagsrummet"
NOTIFICATION_DEFAULT_GENDER = "female"
NOTIFICATION_DEFAULT_VOICE = "Elin"
NOTIFICATION_DEFAULT_ONLY_WHEN_PLAYING = False
NOTIFICATION_DEFAULT_TIMEOUT = 0
NOTIFICATION_DEFAULT_MP3_TIMEOUT = 15
class Notification:
def __init__(self, notification_or_url, priority=PRIO['MODERATE'], **kwargs):
self.notification_or_url = notification_or_url
self.priority = priority
self.room = kwargs.get('tts_room', NOTIFICATION_DEFAULT_ROOM)
self.volume = kwargs.get('tts_volume', None)
self.language = kwargs.get('tts_lang', sonos.get("rooms", {}).get(self.room, {}).get("tts_lang", NOTIFICATION_DEFAULT_LANGUAGE)) # Use param if exist, else config, else default
self.voice = kwargs.get('tts_voice', sonos.get("rooms", {}).get(self.room, {}).get("tts_voice", NOTIFICATION_DEFAULT_VOICE))
self.gender = kwargs.get('tts_gender', sonos.get("rooms", {}).get(self.room, {}).get("tts_gender", NOTIFICATION_DEFAULT_GENDER))
self.engine = kwargs.get('tts_engine', sonos.get("rooms", {}).get(self.room, {}).get("tts_engine", NOTIFICATION_DEFAULT_ENGINE))
self.only_when_playing = kwargs.get('only_when_palying', NOTIFICATION_DEFAULT_ONLY_WHEN_PLAYING)
self.delay_ms = kwargs.get('delay_ms', 0) if 1 <= kwargs.get('delay_ms', 0) <= 1000 else 500
self.timeout = kwargs.get('timeout', NOTIFICATION_DEFAULT_TIMEOUT)
self.mp3_timeout = NOTIFICATION_DEFAULT_MP3_TIMEOUT
self.language_server = f'http://{sonos["TTS_HOST"]}:5601/api/generate'
self.mqtt_topic = ""
self.payload = ""
@property
def volume(self):
if not self._volume or self._volume >= 70:
if self.priority == PRIO['LOW']:
return 30
elif self.priority == PRIO['MODERATE']:
return 40
elif self.priority == PRIO['HIGH']:
return 60
elif self.priority == PRIO['EMERGENCY']:
return 70
else:
return 50
return self._volume
@volume.setter
def volume(self, value):
self._volume = value
def should_play(self):
# Get current hour
current_hour = datetime.now().hour
# Check if current hour is outside the range of 7 AM to 9 PM
is_outside_range = current_hour < 7 or current_hour > 21
# Check if outside range or if the SPC alarm is set and priority level is low
if (is_outside_range or spc_area_is_set()) and self.priority <= PRIO['MODERATE']:
log_message = f"Message priority [{get_key_for_value(PRIO, self.priority)}] is too low to play the notification '{self.notification_or_url}' at this moment."
log.info(log_message)
return False
return True
def play_mp3(self):
# Get current hour
return self.notification_or_url.lower().endswith('.mp3')
@property
def mqtt_topic(self):
# Get the the mqtt topic
return self._mqtt_topic
@mqtt_topic.setter
def mqtt_topic(self, value):
if self.play_mp3():
self._mqtt_topic = 'sonos/set/notify' if self.room == "All" else f'sonos/set/{self.room}/notify'
else:
self._mqtt_topic = "sonos/set/speak" if self.room == "All" else f'sonos/set/{self.room}/speak'
@property
def payload(self):
# Get the payload
return self._payload
@payload.setter
def payload(self, value):
if self.play_mp3():
track_uri = f'http://{sonos["TTS_HOST"]}:5601/cache/sounds/{self.notification_or_url}'
self._payload = { "trackUri": track_uri, "volume": self.volume, "timeout": self.mp3_timeout, "onlyWhenPlaying": self.only_when_playing }
if self.delay_ms and 0 < self.delay_ms < 2001:
self._payload['delayMs'] = self.delay_ms
if self.timeout and 0 < self.timeout < 250:
self._payload['timeout'] = self.timeout
else:
self._payload = { "text": self.notification_or_url, "endpoint": self.language_server, "lang": self.language, "gender": self.gender, "engine": self.engine, "volume": self.volume, "onlyWhenPlaying": self.only_when_playing }
if self.voice is not None:
self._payload['name'] = self.voice
def play(self):
# Play the notification
if not self.should_play():
return False
mqtt_pub(self.mqtt_topic, json.dumps(self.payload))
return True
def play_notification(notification_or_url, priority=PRIO['MODERATE'], **kwargs):
Plays a notification on the Sonos system.
The notification can be either a text string or an URL to an mp3 file.
notification = Notification(notification_or_url, priority, **kwargs)
return notification.play()
def speak_text(text_to_speak, priority=PRIO['MODERATE'], **keywords):
Text To Speak function. First argument is positional and mandatory.
Remaining arguments are optionally keyword arguments.
Example: speak_text("Hello")
Example: speak_text("Hello", PRIO['HIGH'], tts_room='Kitchen', tts_volume=42, tts_lang='en-GB', tts_voice='Brian')
@param param1: Text to speak (positional argument)
@param param2: priority as defined by PRIO. Defaults to PRIO['MODERATE']
@param tts_room: Room to speak in. Defaults to "TV-Rummet".
@return: this is a description of what is returned
return play_notification(text_to_speak, priority, **keywords)
def play_sound(play_file, ttsPrio=PRIO['MODERATE'], **keywords):
To play a short sound file as a notification
return play_notification(play_file, ttsPrio, **keywords)
def mqtt_pub(topic, payload):
Publishes a MQTT message on the default brooker
log.debug('%s <- %s', topic, payload)
MqttItem.get_create_item(topic).publish(payload)
def send_notification_to_lametric(notification_text: str = 'HELLO!', notification_prio: int = PRIO['MODERATE'], **keywords: Dict) -> bool:
Sends a notification to the LaMetric device.
Documentation @ https://lametric-documentation.readthedocs.io/en/latest/reference-docs/device-notifications.html
Possible keywords: sound, icon, autoDismiss, lifeTime, iconType
log.debug('Sending a notification to LaMetric')
def is_quiet_hours(start_hour, end_hour):
"""Returns True if the current time is within the quiet hours."""
now_hour = datetime.now().hour
return ((now_hour < start_hour) or (now_hour > end_hour))
def should_play_sound(notification_prio):
"""Returns True if a sound should be played with the notification."""
if notification_prio <= PRIO['MODERATE'] and spc_area_is_set():
return False
if is_quiet_hours(7, 21):
return False
return True
sound = lametric_configuration.get('DEFAULT_NOTIFICATION_SOUND') if 'sound' not in keywords else keywords['sound']
icon = lametric_configuration.get('DEFAULT_ICON') if 'icon' not in keywords else keywords['icon']
auto_dismiss = True if 'autoDismiss' not in keywords else keywords['autoDismiss']
life_time = lametric_configuration.get('DEFAULT_LIFETIME') if 'lifeTime' not in keywords else keywords['lifeTime']
icon_type = 'info' if 'iconType' not in keywords else keywords['iconType'] # [none|info|alert]
url = f'https://{lametric_configuration["HOST"]}:{lametric_configuration["PORT"]}/api/v2/device/notifications'
priority = 'critical' #"priority": "[info|warning|critical]" Must be critical to break through the app
#"icon_type":"[none|info|alert]",
#"lifeTime":<milliseconds>,
# cycles – the number of times message should be displayed. If cycles is set to 0, notification will stay on the screen until user dismisses it manually or you can dismiss it via the API (DELETE /api/v2/device/notifications/:id). By default it is set to 1.
cycles = 1 if auto_dismiss else 0 # cycles – the number of times message should be displayed. If cycles is set to 0, notification will stay on the screen until user dismisses it manually or you can dismiss it via the API (DELETE /api/v2/device/notifications/:id). By default it is set to 1.
payload = { 'priority': priority, 'icon_type': icon_type, 'lifeTime': life_time, 'model': { 'frames': [ { 'icon': icon, 'text': notification_text} ], 'cycles': cycles } }
if should_play_sound(notification_prio):
payload['model']['sound'] = { 'category': 'notifications', 'id': sound, 'repeat': 1 }
else:
log.info(f"The notification_prio argument {notification_prio} is too low to play a sound together with the notification at this moment")
args_list = [
'curl',
'-X',
'POST',
'-u',
f'dev:{lametric_configuration["API_KEY"]}',
'-H',
'Content-Type: application/json',
'-d',
json.dumps(payload),
url,
'--insecure'
result = subprocess.run(args_list, capture_output=True)
if result.returncode != 0:
log.error(f"Error executing command: {result.returncode}")
return False
return True
def greeting():
return f'God{StringItem.get_item(customItemNames["clock_time_of_day_item"]).value.lower()}'
r'''
Safety pig has arrived!
_._ _..._ .-', _.._(`))
'-. ` ' /-._.-' ',/
/ _ _ | \
| a a / |
| 7 .__ _.-\ \
/,_| | /,_/ /
/,_/ '`-'
I keep my configuration and settings in a separate file that I’ve put in the param
directory.File name is my_configuration.yml
Just a small excerpt from that file:
pushover:
PUSHOVER_PRIO:
LOWEST: -2
LOW: -1
NORMAL: 0
HIGH: 1
EMERGENCY: 2
PUSHOVER_DEF_DEV: 'XXXXX'
user_token: 'CCCCCCCCCCCCCCXXXXXXXXXXXXXX'
api_token: 'aXXXXXXXXXXXXXXXXXXX364'
riksbanken:
SWEA_API_LATEST_OBSERVATIONS_URL: 'https://api-test.riksbank.se/swea/v1/Observations/Latest/SEKEURPMI'
OCP_APIM_SUBSCRIPTION_KEY: 'XXXXXXXXXXXXXXX'
I get access ro the configuration parameters through the DictParameter objec.
# HABApp:
# depends on:
# - rules/001_init.py
# - params/my_config.yml
# reloads on:
import json
import logging
import math
from HABApp import DictParameter, Rule
from HABApp.core.events import (EventFilter, ValueChangeEventFilter,
ValueUpdateEventFilter)
from HABApp.core.events.habapp_events import HABAppException
from HABApp.core.items import Item
from HABApp.openhab.events import ItemStateChangedEventFilter
from HABApp.openhab.items import (ContactItem, DatetimeItem, DimmerItem, GroupItem,
NumberItem, OpenhabItem, StringItem,
SwitchItem)
... ... ... ... some code removed
# Get the configurations parameters stored in the my_config.yml file
autoremote_configuration = configuration["autoremote"]
robonect_configuration = configuration["robonect"]
riksbanken_configuration = configuration["riksbanken"]
surveillance_configuration = configuration["surveillance"]
Here goes my first script
It fetches the exchange rate for EUR to SEK and stores it in an OpenHAB Item. I haven’t included all the imports that I’m doing in the beginning of the file but you’ll probably figure that out anyway.
class EuroExchangeRate(Rule):
Gets the latest exchange rate for EUR to SEK from Riksbanken
HOURS_BETWEEN_REQUESTS = 1
def __init__(self):
super().__init__()
self.log = logging.getLogger(f'{configuration["system"]["MY_LOGGER_NAME"]}.{self.rule_name}')
self.log.setLevel(logging.DEBUG)
self.eur_to_sek_exchange_rate_item = NumberItem.get_item('EurToSekExchangeRate')
self.eur_to_sek_exchange_rate_last_request_item = DatetimeItem.get_item('EurToSekExchangeRateLastRequest')
self.run.every(timedelta(minutes=1), timedelta(hours=1), self.process_changes)
self.run.soon(self.process_changes)
def _on_subprocess_finished(self, process_output: str):
try:
# Parse the JSON response string into a Python dictionary
response_dict = json.loads(process_output)
except Exception as e:
self.log.error(f"(Ο_Ο) Failed converting the response from Riksbanken to json when requesting latest exchange rate for EUR to SEK: {e}")
self.log.error(process_output)
return
# Check if the 'success' variable is set to True
if 'value' in response_dict:
# Extract the 'SEK' value as a float
sek_value = float(response_dict['value'])
self.log.info(f'-------------------> Latest exchange rate for 1 EUR to SEK is {round(sek_value, 2)}')
self.eur_to_sek_exchange_rate_item.oh_send_command(sek_value)
self.eur_to_sek_exchange_rate_last_request_item.oh_post_update(self.datetime_now)
else:
self.log.error('(Ο_Ο) Requesting latest exchange rate for EUR to SEK from Riksbanken was not successful.')
def process_changes(self, event=None):
Go get the exchange rate for Euro to SEK from Riksbanken.
# Read the time stamp value stored in item (Which might not be the same as the items last update time)
self.datetime_now = datetime.now()
last_request_made = self.eur_to_sek_exchange_rate_last_request_item.get_value(self.datetime_now - timedelta(hours=self.HOURS_BETWEEN_REQUESTS))
if not (int((self.datetime_now - last_request_made).total_seconds()) > self.HOURS_BETWEEN_REQUESTS * 3600):
#self.log.debug('Do not risk spamming the Riksbanken Exchange Rate API')
return
url = f"{riksbanken_configuration['SWEA_API_LATEST_OBSERVATIONS_URL']}?seriesID=SEKEURPMI"
args_list = [
#'echo',
'-X',
'GET',
url,
'-H',
'Cache-Control: no-cache',
'-H',
'Accept: application/json',
'-H',
f'Ocp-Apim-Subscription-Key: {riksbanken_configuration["OCP_APIM_SUBSCRIPTION_KEY"]}',
self.execute_subprocess(self._on_subprocess_finished, 'curl', *args_list, capture_output=True) # type: ignore
EuroExchangeRate()
The API key can be obtained from: https://developer.api-test.riksbank.se/
