I just startet with HABApp. Installation was easy. HAPApp is running normal.
● habapp.service - HABApp
Loaded: loaded (/etc/systemd/system/habapp.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2024-04-22 09:04:14 CEST; 12h ago
Docs: https://habapp.readthedocs.io
Main PID: 818 (habapp)
Tasks: 8 (limit: 2176)
CPU: 7.656s
CGroup: /system.slice/habapp.service
└─818 /opt/habapp/bin/python3 /opt/habapp/bin/habapp -c /etc/openhab/habapp
Apr 22 09:04:14 openhabian systemd[1]: Started HABApp.
On Startup I get the following log:
2024-04-22 09:04:28.266 [INFO ] [HABApp ] - HABApp Version 24.02.0
2024-04-22 09:04:28.455 [INFO ] [HABApp.Config ] - Parameters disabled! Folder /etc/openhab/habapp/params does not exist!
2024-04-22 09:04:28.466 [INFO ] [HABApp.Config ] - Manual thing configuration disabled! Folder /etc/openhab/habapp/config does not exist!
2024-04-22 09:04:28.634 [INFO ] [HABApp.connection.openhab ] - Connection disabled (user/password missing)!
2024-04-22 09:04:28.636 [INFO ] [HABApp.connection.mqtt ] - MQTT disabled
2024-04-22 09:04:29.640 [INFO ] [HABApp.EventBus ] - HABApp.Files: <RequestFileLoadEvent filename: rules/test.py>
2024-04-22 09:04:29.652 [INFO ] [HABApp.EventBus ] - HABApp.Files: <RequestFileLoadEvent filename: rules/test_import.py>
Rules are loaded instantly.
But I can’t get any OpenHab item.
I Tried
self.get_items(OpenhabItem)
and
OpenhabItem.get_item("Battery SOC")
Does I have to change something in the config.yaml?
Thank you!
Carsten
