I’m trying to port my JSR223/Python rules to HABApp (because I’m missing some python packages running only with python 3.x). It is basically working and I like HABApp (thanks!), but now I’m stuck.
Background: when I dial a number on my old rotary phone, a Number item is updated with the value I dialed (e.g. 3 when I dial the number 3). Of course I can dial the same number multiple times in a row and want to trigger a rule every time (even if the number doesn’t change).
In my old Jython2.7 rules I have something like the following:
@rule("Handle dial codes", description="", tags=["DIAL"])
@when("Item wallPhone_dialPlate received update")
def processRuleDialCodes(event):
if event.itemState.intValue() == 1:
# do something
# and so on...
In HABApp I tried the following. But the rule is not called.
import HABApp
from HABApp.openhab.items import SwitchItem, NumberItem
from HABApp.openhab.events import ItemStateUpdatedEventFilter, ItemStateChangedEventFilter
class DialCodes(HABApp.Rule):
def __init__(self):
super().__init__()
self.alarmPhone = NumberItem.get_item('alarmPhone_dialPlate')
self.alarmPhone.listen_event(self.handle_dial_code, ItemStateUpdatedEventFilter())
self.wallPhone = NumberItem.get_item('wallPhone_dialPlate')
self.wallPhone.listen_event(self.handle_dial_code, ItemStateUpdatedEventFilter())
self.actions = {
1: self.toggle_lights_in_living_room,
2: DialCodes.none,
3: self.toggle_power_of_espresso_machine,
4: self.toggle_lights_in_bathroom,
5: self.toggle_power_switch,
6: self.toggle_surveillance_state,
7: self.ring_bell,
8: DialCodes.none,
9: DialCodes.none,
0: DialCodes.none
def handle_dial_code(self, event):
print(f'Dial Code: {event.value}')
self.actions[event.value]()
@staticmethod
def toggle_switch(switch_item_name):
switch = SwitchItem.get_item(switch_item_name)
if switch.is_on():
switch.off()
else:
switch.on()
@staticmethod
def none():
pass
def toggle_lights_in_living_room(self):
self.toggle_switch('hue_switch_livingroom_lights')
def toggle_power_of_espresso_machine(self):
self.toggle_switch('hm_powerSwitch_espressoMachine')
def toggle_lights_in_bathroom(self):
self.toggle_switch('hm_powerSwitch_light')
def toggle_power_switch(self):
self.toggle_switch('hm_powerSwitch')
def toggle_surveillance_state(self):
self.toggle_switch('surveillance_enabled')
def ring_bell(self):
self.mqtt.publish('wallPhone/bell', '2')
DialCodes()
If I use ItemStateChangedEventFilter (not …Updated…) and dial different numbers, it works. But I don’t want to get an event on changes only.
How do I have to use the ItemStateUpdatedEventFilter on a NumberItem?
Thanks!
Sebastian
