During system reboot habapp is started before openhab is up and running. When connected to openhab habapp gets all stored values of items. The Doorbell_PressedImage throws an error:
When I comment out the Doorbell_PressedImage item restart is fine without any of the ERROR messages.
The same happens with the 24.02.0 version
Any idea what the cause is?
openhab:
connection:
buffer: 256kib # try to fix boot error "ValueError: Chunk too big"
url: <MY_URL> # Connect to this url. Empty string ("") disables the connection.
user: <MY_USER>
password: <MY_PW>
verify_ssl: true # Check certificates when using https
general:
listen_only: false # If True HABApp does not change anything on the openHAB instance.
wait_for_openhab: true # If True HABApp will wait for a successful openHAB connection before loading any rules on startup
min_start_level: 100 # Wait for openHAB
