I am trying to investigate a problem, but I found that HABApp does not write any logs when running as a service. When started from the CLI, logs are written and also my custom messages appear. But it stops when I quit HABApp in the Terminal, only a final line is written into the logs:
[WARN ] [HABApp.Rule ] - /usr/lib/python3.9/logging/handlers.py:1361: ResourceWarning:unclosed file <_io.TextIOWrapper name='/var/log/openhab/HABApp_events.log' mode='a' encoding='utf-8'>
OpenHAB logs everything without problems.
Am I missing some configuration?
HABApp 0.31.2 installation running on OpenHAB 3.2.0.
