Hi all,
not sure if this is intented:
when using Habdroid to programm NFC tags I found that I cant program a switch.
Long press on the switch in Habdroid reveals only empty page “choose action of NFC tag”
So the way to go is to make a switch with mapping ON/OFF
Also is there another way to toggle a light switch? Right now I have an autoupdate=false item NFC_light which is triggering a rule where I send the http Toggle command
Switch NFC_light “NFC dummy” { autoupdate=“false” }
Item NFC_light received command ON
sendHttpGetRequest(“openhabIP”:8080/classicui/CMD?real_Light_item=TOGGLE)
end -
Is there any possibility to use the android nfc function when the screen is of without any custom roms/root?
