HABmin, zwave things, items, and dashboards
Your pics show that they are, but the plug appears to have two items linked to it. You should remove one.
Habmin is for administration, like PaperUI. Setup BasicUI or ClassicUI with a sitemap, or setup Habpanel, for daily usage.
I belive those features were experimental and not fully implemented. I’ve set them up, but you can build a much better floor plan with Habpanel
Read your manual and set the configuration parameters. There’s a copy of it in the device database. I believe you’ll need to set parameter 80. It also looks like the device may be missing some channels, which is odd since it’s been around a while. Is so, you may need to add them.
