I’m running the nightly snapshots of Openhab2-offline on my Raspi. What I don’t understand is that my Habmin2 version still is Version: 0.1.7, 2016-09-06T22:11:44. Can this be the latest version, and is Habmin2 updated with an apt-get update/upgrade op Openhab2?
A
bundle:list
on the Karaf console shows me:
198 | Active | 80 | 2.0.0.201610121647 | HABmin User Interface
So that’s obviously a newer version. However I do not know from which console you c&p your version details, as I haven’t seen this format ever before.
I am also using the nighty snapshots, installed via apt-get. And I also “only” update my system with apt-get update/upgrade.
This is what I get in the console:
190 | Active | 80 | 2.0.0.201609062002 | HABmin User Interface
The version details in the previous post was from the front page of Habmin2.
Something must go wrong when I update. Can you help @chris?
From the list in the Karaf console it seems that no bindings have updated since sempember 6th. (when I made a fresh install of Openhab2)
I’m not 100% sure. This looks a little old - the last update of HABmin was nearly 4 weeks ago (15th Sept) as I’ve been travelling a lot for work. The version of 0.1.7 is an internal version of the webapp, so this is correct.
I’m not 100% sure when everything gets built with all the different build scenarios these days - in theory you should be able to simply update HABmin just like any other bundle.
You may want to check to make sure you don’t have a static .jar file located in your addons directory.
Only file in the addons directory is a readme file. Below is the ful contents of my bundles list in Karaf. My Openhabversion is:
dpkg -s openhab2-offline | grep Version
Version: 2.0.0~20161012185825
START LEVEL 100 , List Threshold: 50
ID | State | Lvl | Version | Name
10 | Active | 80 | 2.3.0.201506221200 | JAX-RS Gson Provider
11 | Active | 80 | 5.3.1.201602281253 | OSGi JAX-RS Connector
12 | Active | 80 | 2.3.1 | Gson
13 | Active | 80 | 18.0.0 | Guava: Google Core Libraries for Java
14 | Active | 80 | 3.0.0.v201312141243 | Google Guice (No AOP)
15 | Active | 80 | 1.5.8 | swagger-annotations
16 | Active | 80 | 3.19.0.GA | Javassist
18 | Active | 80 | 3.5.1 | JmDNS
21 | Active | 80 | 1.1.0.Final | Bean Validation API
23 | Active | 80 | 2.0.1 | javax.ws.rs-api
25 | Active | 80 | 3.2.0.v201101311130 | ANTLR Runtime
28 | Active | 80 | 1.6.0 | Commons Codec
29 | Active | 80 | 3.2.1 | Commons Collections
30 | Active | 80 | 1.1 | Commons Exec
31 | Active | 80 | 2.2.0 | Commons IO
32 | Active | 80 | 2.6 | Commons Lang
37 | Active | 80 | 4.2.3 | Apache HttpClient OSGi bundle
38 | Active | 80 | 4.2.3 | Apache HttpCore OSGi bundle
56 | Active | 80 | 4.0.4 | Apache Karaf :: Shell :: Core
59 | Active | 80 | 4.0.4 | Apache Karaf :: Wrapper :: Core
60 | Active | 80 | 3.1.0.7 | Apache ServiceMix :: Bundles :: commons-httpclient
62 | Active | 80 | 2.11.0.v20150805-0538 | EMF Common
63 | Active | 80 | 2.11.1.v20150805-0538 | EMF Ecore
64 | Active | 80 | 2.11.1.v20150805-0538 | EMF XML/XMI Persistence
65 | Active | 80 | 3.7.0.v20150402-1709 | Common Eclipse Runtime
66 | Active | 80 | 3.6.0.v20150318-1503 | Extension Registry Support
92 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Config Core
93 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Configuration Discovery
94 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Config Dispatcher
95 | Active | 75 | 0.9.0.201609061916 | Eclipse SmartHome Config XML
96 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Core
97 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome AutoUpdate Binding
98 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Core Binding XML
99 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Core ID
100 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Core Persistence
101 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Scheduler Service
102 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Core Thing
103 | Active | 75 | 0.9.0.201609061916 | Eclipse SmartHome Core Thing XML
104 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Transformation Service
105 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Core Voice
106 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Console
107 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Console for OSGi runtime Karaf
108 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Monitor
109 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Net I/O Bundle
110 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome REST Interface Bundle
111 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Core REST API
112 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome REST mDNS Announcer
113 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Sitemap REST API
114 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome SSE REST API
115 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Bonjour/MDS Service Discovery Bundle
116 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Model Core
117 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Item Model
118 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Item Model Runtime
119 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Persistence Model
120 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Persistence Runtime
121 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Rule Model
122 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Rule Runtime
123 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Script
124 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Script Runtime
125 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Sitemap Model
126 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Sitemap Runtime
127 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Thing Model
128 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Thing Model Runtime
129 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome MapDB Storage Service
130 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome UI
131 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome UI Icons
132 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Classic IconSet
133 | Active | 80 | 2.9.2 | Xtend Runtime Library
134 | Active | 80 | 2.9.2 | Xtend Macro Interfaces
135 | Active | 80 | 2.9.2 | Xtext
136 | Active | 80 | 2.9.2 | Xtext Common Types
137 | Active | 80 | 2.9.2 | JSR-45 Smap installer
138 | Active | 80 | 2.9.2 | Xtext Utility
139 | Active | 80 | 2.9.2.v20160428-1452 | Xbase Model
140 | Active | 80 | 2.9.2 | Xbase Runtime Library
156 | Active | 80 | 2.2.0 | JUPnP Library
157 | Active | 80 | 1.9.6 | MIME streaming extension
158 | Active | 80 | 1.0.9 | mapdb
159 | Active | 80 | 5.0.2 | Require-Bundle Fix :: org.objectweb.asm
161 | Active | 90 | 2.0.0.201609062002 | openHAB Core
162 | Active | 80 | 2.0.0.201609062002 | openHAB Karaf Integration
168 | Active | 80 | 1.1.1.201605111122 | Swagger Provider
169 | Active | 80 | 2.4.5 | Jackson-annotations
170 | Active | 80 | 2.4.5 | Jackson-core
171 | Active | 80 | 2.4.5 | jackson-databind
172 | Active | 80 | 2.4.5 | Jackson-dataformat-YAML
173 | Active | 80 | 1.5.8 | swagger-core
174 | Active | 80 | 1.5.8 | swagger-jaxrs
175 | Active | 80 | 1.5.8 | swagger-models
176 | Active | 80 | 3.4.0 | Apache Commons Lang
177 | Active | 80 | 3.2.0 | Commons Net
178 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Basic UI, Fragments: 182
179 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome WebApp UI
180 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Paper UI, Fragments: 185
181 | Active | 80 | 2.0.0.201609062002 | openHAB REST Documentation
182 | Resolved | 80 | 2.0.0.201609062002 | openHAB Basic UI Fragment, Hosts: 178
183 | Active | 80 | 2.0.0.201609062002 | openHAB Classic UI Fragment
184 | Active | 80 | 2.0.0.201609062002 | openHAB Dashboard UI
185 | Resolved | 80 | 2.0.0.201609062002 | openHAB Paper UI Theme Fragment, Hosts: 180
186 | Active | 80 | 0.9.10.v20160429-1435 | reflections (wrap)
187 | Active | 80 | 1.5.8.v20160511-1038 | swagger-jersey2-jaxrs (wrap)
188 | Active | 80 | 2.0.0.201609062002 | ZWave Binding
189 | Active | 80 | 2.0.0.201609062002 | openHAB Serial Transport Bundle
191 | Active | 80 | 1.9.0.201608310111 | openHAB Weather Binding
192 | Active | 80 | 2.0.0.201609062002 | openHAB 1.x Compatibility Layer
193 | Active | 80 | 1.9.0.201608310111 | openHAB Serial Binding
194 | Active | 80 | 2.0.0.201609062002 | Orvibo Binding
195 | Active | 80 | 0.9.0.201609061916 | ntp Binding
196 | Active | 80 | 1.9.0.201608310111 | openHAB MQTT Binding
197 | Active | 80 | 1.9.0.201608310111 | openHAB MQTT Transport Bundle
198 | Active | 80 | 1.9.0.201608310111 | openHAB IHC/ELKO LS Binding
199 | Active | 80 | 1.9.0.201608310111 | openHAB HTTP Binding
200 | Active | 80 | 1.9.0.201608310111 | openHAB RRD4j Persistence Bundle
201 | Active | 80 | 0.9.0.201609061916 | Eclipse SmartHome Xslt Transformation Service
202 | Active | 80 | 0.9.0.201609061916 | YahooWeather Binding
It looks like the packages are not cleaning up after themselves, or not restarting after install, or both. I think I saw another thread where changes were made to the installer, so you may want to try again with a fresh install. Certainly the versions of the modules reported in openhab should be much closer to the version of the package installed with apt.
