Hello Community,
My environment:
Raspberry Pi 4, 4GB RAM
openHABian 4.1.1
I have the issue that HABot does not take actions with items e.g. switches anymore.
I had the same configuration working on openHAB 2.5 and early 4.x
I explain the behaviour with screenshots.
Sorry for the german language, but here you can see, that HABot recognizes “test” as a switch but when you try to control it, it fails. I have tried all possible phrases like “ein(schalten)”, “aus(schalten)”, “on”, “off” etc. but none did work.
I am really sure that the item and semantic model are correct in this point:
As I already said, this was working a long time before.
This is the case for all switches.
Another example is the output of values:
If I just name the label of an item it shows the value but packed into a simple german sentence brings an error.
Also this was working before and I did not change anything to the configuration.
I also refreshd HABot with no effect.
What can be the problem?
Thanks for any kind of help
Kind regards
Edcrfv
