HABPanel as photo frame with weatherstaion
Hello
I would like to configure HABPanel as as Photoframe with some aditional Informations eg Weathersensors, door/window status and so on. For this I plan to use a old Android-Tablet with dokingstation. I have a motion detector witch should turn on the tablet. This idea generates a lot of questions:
  • Is there a way to display photos using HABPanel (an rotate every x minutes)
  • Is there a way to turn on a android-tablet using a http-request?
  • Ist there a chance to integrate iCloud photos?
  • Can I configure a default site in HABPanel whitch will be displayd after x minutes of idel?
Do you mean HABmin, or HABPanel?
You are right. I meen HABpanel
I found a solution for the second point: a app caled woli for Android. This app allows to remote control the tablet. It’s posible to turn on and of, call a URL or open a App on the tablet by using netcomand:
echo wolido:Display:1 | nc 192.168.10.45 6666 -q 1
Is there a way to do this comand using a rule?
HABPanel Viewer will have many of the things you are looking for. You might have to do a little coding for the icloud photos and some of the other feature like your last point, but it should be possible.
