Budo
(Tom Araya)
January 22, 2017, 4:03am
#1
Since a few hours I only see a black browser window when accessing HABpanel. No panels, no widgets and even no controls. I tried different browsers and devices. An uninstall and reinstall via the PaperUI didn’t work either. When I use the static URL (http://openhab.fritz.box:8080/static/habpanel/index.html#/settings ) instead of the dynamic (http://openhab.fritz.box:8080/habpanel/index.html#/ ) I get a non up-to-date version, but all looks good.
Yesterday I switched to the new snapshot repository (as described here Replacement of the Apt Snapshot Repository ) and the latest build, but all worked fine.
I have exports of my panels and controls, but I can’t import anything, because there are no controls at all.
Any ideas?!
would this be the case ? i am not sure if it applies to your case or not
All,
Just a short notice for all HABPanel users: When testing the RC1, I noticed that the internal configuration id was not in sync with the other add-ons, I therefore corrected it - todays snapshot (not RC1!) contains this fix. This means that if you upgrade to it, your HABPanel won't find your configurations anymore (if you stored it on the server and not only in the browser). It is easy to make it find it again, though: Shutdown your openHAB and then simply move the file ${OPENHAB_USERDATA}…
Budo
(Tom Araya)
January 24, 2017, 7:05am
#3
Thanks a lot for your reply. Moving the config file hasn’t solved the problem.
After upgrading to the new repo my config was overwritten by the demopanel and later I got the problem that I described. What I am really wondering about is that I have only a black screen without controls - nothing …
Budo
(Tom Araya)
January 31, 2017, 11:21pm
#4
I did a new installation of the raspi …
Thanks anyway!
RGB73
(Cesare Arigliano)
November 28, 2017, 2:54pm
#5
the same problem to me any help ?
