Is there an easy way to execute an command when pressing a button?
I would like to have a rollershutter with 3 Buttons. UP STOP DOWN.
When i click the button up it has to execute a command, when i click stop another, and when i click down it should execute the command for down.
Have you looked at the widget gallery? Plenty of roller shutter widgets there and if none of them do exactly what you want then they will likely only need a little modification.
Are you talking about ‘exec binding’ style execute a command? I suspect most of the widgets will result in a sendCommand style function or in widget style code ng-click sendCmd. If you want to do something different you can create your own item say RollerShutter as a String and then put a rule in place like this:
rule "Rollershutter change..."
Item Rollershutter changed
switch Rollershutter.state.toString {
case "UP": {
// exec bind command UP
case "STOP": {
// exec bind command STOP
case "DOWN": {
// exec bind command DOWN
Just change the widget you like to use sendCmd(RollerShutter, 'UP') when the appropriate button is pressed.
