I have the following widget I’m working on:
> <div class="row"> > <div class="col-xs-4"><span><widget-icon iconset="'smarthome-set'" icon="'temperature'" /></span>Current Temperature</div> > <div class="col-xs-4"><span><widget-icon iconset="'smarthome-set'" icon="'temperature'" /></span>Minimum</div> > <div class="col-xs-4"><span><widget-icon iconset="'smarthome-set'" icon="'temperature'" /></span>Maximum</div> > </div> > > <div class="row"> > <div class="col-xs-4"><span style="color: red; font-size: 28pt">{{itemValue('config.temperature_item').toString();}}°C</span></div> > <div class="col-xs-4"><span style="color: cyan; font-size: 28pt">{{itemValue('g_temperature_average_min')}}°C</span></div> > <div class="col-xs-4"><span style="color: green; font-size: 28pt">{{itemValue('weather_temperature_max')}}°C</span></div> > </div>
I have a setting defined as temperature_item of type item. I under stood that with the widget, that when I run the panel with this widget (and having set the setting of temperature item to a valid numerical item, that it would display. But I’m not seeing that.
