i want to connect a hama smart solution bulb to openhab. I connected it as shown in the manual with wifi and it works with the hama smart solution app. i tried to connect it via the Wifi LED binding (WiFi LED - Bindings | openHAB) by adding it manually, this worked as well, but i cant controll it. Even if i change the given protocol and driver, it doesnt work. does anyone know how to fix it or is there any other binding?
I’ve never heard of this brand. Just because a bulb uses wifi doesn’t mean that anything in OH knows how to talk to it. The WiFi LED Binding doc has a table listing those devices that are known to work. If this bulb isn’t one of those there is no reason to expect that it would work.
A quick search doesn’t reveal a published API.
So you will have to hope that the communication between the app and the bulb isn’t encrypted and then reverse engineer the API.
