with knx-binding, I accidentally broke my knx-things-configuration,
by typing in a not valid channel type ID in the code section and saving it.
Now I can’t get rid of this invalid channel anymore.
Deleting the channel in the code section and saving afterwards did not help.
The invalid channel no longer appears in the channels section,
but it shows up in the code section again, when I switch back to the code section.
Changing the channel type ID to a valid one didn’t help either.
After saving, then switching to the channel section and then back to the code section, the channel type ID is “QuantityType” again.
Because of this mistake all my knx channels no longer work.
How can I get rid of the invalid channel?
My setup:
openHAB 4.1.1 Release Build
openHABian
Raspberry Pi 3 Model B Rev 1.2
How does the code look like?
Please be aware that you can edit the code.
EDIT: just realized, openHAB refuses to change channelTypeUID back to a valid value.
So either delete the thing or shutdown openHAB, then open $OPENHAB_USERDATA/jsondb/org.openhab.core.thing.Thing.json
, search for knx:QuantityType
and change it to knx:number
DON’T CHANGE ANY OTHER PART
You have to edit the file with extended permissions:
sudo nano $OPENHAB_USERDATA/jsondb/org.openhab.core.thing.Thing.json
If you mess something up, there are some backups of the file in $OPENHAB_USERDATA/jsondb/backup/
and it’s a good idea to create one by yourself before changing anything.
openHAB will read the file only at startup, so first stop openHAB, then edit, then start openHAB.
Thank you so much for your help!
You saved my day.
Here are a few tips for beginners who also want to correct the entry in jsondb.
After a shutdown, I couldn’t access the Raspberry with puTTY.
That’s why I did not shut down Raspberry. I stopped openhab with the command
sudo systemctl stop openhab.service
and then started it after the change with the command
sudo systemctl start openhab.service
I also couldn’t find the file $OPENHAB_USERDATA/jsondb/org.openhab.core.thing.Thing.json in WinSCP straight away.
The directory $OPENHAB_USERDATA is the directory
/var/lib/openhab/jsondb
in my installation (openhabian and Raspberry Pi).
I edited the file with VS-Code because this is slightly easier to me than using nano.
Now everything is fine again.
