Handling Shelly Button Press over MQTT
If someone needs to handle Shelly Button presses over MQTT here is the necessary info:
things file:
Type string : rpcevent [stateTopic="bridge/t15/wifi/gardenwestentranceswitch/events/rpc" ]
items file:
String GardenWestEntranceSwitchRpcEvent { channel="mqtt:topic:gardenwestentranceswitch:rpcevent" }
rules file:
rule "GardenWestEntranceSwitchRpcEvent received update"
  Item GardenWestEntranceSwitchRpcEvent received update
  val jsonstring = GardenWestEntranceSwitchRpcEvent.state.toString()
  val component = transform("JSONPATH", "$.params.events[0].component", jsonstring)
  val event = transform("JSONPATH", "$.params.events[0].event", jsonstring)
  if ((component != NULL) && (component == "bthomesensor:201") && (event != NULL)) {
    if (event == "single_push") {
      GardenDoor.sendCommand("ON")
    else if (event == "double_push") {
    else if (event == "triple_push") {
    else if (event == "long_push") {
    else {
      // unhandled push
Make sure to check the id of the Shelly Button in the Webinterface and replace bthomesensor:201 with the number that was assigned to the Shelly Button and replace GardenDoor.sendCommand(“ON”) with what you actually want to do.
