Hansi java.lang.UnsatisfiedLinkError is back
I have a fresh OH 4.0.1 install based on latest openHABian 32 bit on RPi4
When running openhab-cli console it shows
java.lang.UnsatisfiedLinkError: /var/lib/openhab/tmp/jansi-2.4.0-19244aa9ae09872a-libjansi.so: /var/lib/openhab/tmp/jansi-2.4.0-19244aa9ae09872a-libjansi.so: cannot open shared object file: No such file or directory
I found a thread for OH3, which indicates a permission. I already fixed permissions with openhabian-config.
Anything else to check?
What is the permission of /var/lib/openhab/tmp after fixing it ?
As which user do you start/run openhab-cli in case you get the error message ?
