Dear all,
I am trying to controll the functions PLAY, PAUSE, FASTFORWARD, REWIND, STOP of my Denon AVR X1100W. I am allready using the DENON/MARANZ Binding to control some functions - but for whatever reason, PLAY or PAUSE etc are not implemented as custom command (or am I wrong?)
This leads me to control these specific functions via logitech harmony binding. I registered an item for the button press function of my denon AVR
String HarmonyDenon "Kommando Denon" <receiver> (gHarmony) {channel="harmonyhub:device:HarmonyWohnzimmer:39913609:buttonPress"}
I am now trying to send commands to this item like
HarmonyDenon.sendCommand("Pause")
Unfortunately, it does not work, also not for the other actions mentioned. Weirdly, the “Mute” command does work - so in general, the item seems to work
from my harmony app on my android phone, PLAY, PAUSE, etc do work for the denon device. So in general, harmony is sending the correct commands and denon can interpret it.
The only “workaround” is, to link the player of the active device like
Player HarmonyPlayer "Harmony Player" <receiver> (gHarmony) {channel="harmonyhub:hub:HarmonyWohnzimmer:player"}
With this function, the Denon is controllable via openhab and harmony plugin.
Unfortunately, I want to use this function, when the receiver is startet by a command not sent by harmony (in my case a beginning stream from spotify). As the AVR isnt started from the harmony, harmony doesn’t know about the device to be running so it cannot control it by the current activity. Detecting and starting the activity after playback from spotify starts leads to turning off and on again…
Do you have any idea, how I can get Play and Pause up and running for the specific buttonPress of the harmony device - or even better, how to control it via denon/marantz binding?
Thanks a lot in advance,
Tamo
