Hi.
My items, things are discovered. But if run test rule nothing happened.
I see debug message, but no HurmonyHub reaction (led not blink).
Harmony_Activity - is showing right status.
Where is error?
Switch Test
String Harmony_Activity "Activity" <television> (gRemotes) { channel="harmonyhub:hub:HarmonyHub:currentActivity" }
// This line i copy from thing channel, from paper ui
String Harmony_Beeline "Beeline" <television> (gRemotes) { channel="harmonyhub:device:HarmonyHub:27762098:buttonPress" }
Rules:
rule "test"
Item Test received command ON
logWarn (" TEST", "harmonyPressButton" )
Harmony_Beeline.sendCommand("2")
You don’t show the definition for your Tesst Item. Is there a typo with that second “s” in the name or do you define it with “ss” in your Items file too?
