Harmony Hub binding stopped working
Hi, the Harmony Hub binding in OpenHAB 2.4.0 has stopped working for me.
The Hub is online with the same IP as configured in OpenHAB according to my network controller, and the remote works and can sync with Logitech servers.
The Paper UI Says “OFFLINE - COMMUNICATION_ERROR Could not connect: Failed communicating with Harmony Hub
And the OpenHAB log when i try sending a command:
2019-01-29 14:55:57.353 [ome.event.ItemCommandEvent] - Item 'HarmonyLivingRoomCurrentActivity' received command PC
2019-01-29 14:55:57.357 [nt.ItemStatePredictedEvent] - HarmonyLivingRoomCurrentActivity predicted to become PowerOff
2019-01-29 14:55:57.361 [ERROR] [b.internal.handler.HarmonyHubHandler] - Could not start activity
	at net.whistlingfish.harmony.protocol.OAReplyFilter.<init>(OAReplyFilter.java:30) ~[241:org.openhab.binding.harmonyhub:2.4.0]
	at net.whistlingfish.harmony.HarmonyClient.sendOAStanza(HarmonyClient.java:336) ~[241:org.openhab.binding.harmonyhub:2.4.0]
	at net.whistlingfish.harmony.HarmonyClient.sendOAStanza(HarmonyClient.java:331) ~[241:org.openhab.binding.harmonyhub:2.4.0]
	at net.whistlingfish.harmony.HarmonyClient.getConfig(HarmonyClient.java:390) ~[241:org.openhab.binding.harmonyhub:2.4.0]
	at net.whistlingfish.harmony.HarmonyClient.startActivityByName(HarmonyClient.java:443) ~[241:org.openhab.binding.harmonyhub:2.4.0]
	at org.openhab.binding.harmonyhub.internal.handler.HarmonyHubHandler.handleCommand(HarmonyHubHandler.java:122) [241:org.openhab.binding.harmonyhub:2.4.0]
	at com.sun.proxy.$Proxy143.handleCommand(Unknown Source) [241:org.openhab.binding.harmonyhub:2.4.0]
2019-01-29 15:05:56.977 [.ItemChannelLinkAddedEvent] - Link 'AVReceiverLivingRoomButtonPress-harmonyhub:device:Livingroom:46922548:buttonPress' has been added.
2019-01-29 15:05:56.989 [.ItemChannelLinkAddedEvent] - Link 'HarmonyLivingRoomCurrentActivity-harmonyhub:hub:Livingroom:currentActivity' has been added.
2019-01-29 15:05:57.003 [.ItemChannelLinkAddedEvent] - Link 'harmonyhub_device_Livingroom_47790709_buttonPress-harmonyhub:device:Livingroom:47790709:buttonPress' has been added.
2019-01-29 15:05:57.003 [.ItemChannelLinkAddedEvent] - Link 'harmonyhub_hub_Livingroom_activityStarted-harmonyhub:hub:Livingroom:activityStarted' has been added.
2019-01-29 15:05:57.004 [.ItemChannelLinkAddedEvent] - Link 'harmonyhub_device_Livingroom_46922548_buttonPress-harmonyhub:device:Livingroom:46922548:buttonPress' has been added.
2019-01-29 15:05:57.006 [.ItemChannelLinkAddedEvent] - Link 'harmonyhub_device_Livingroom_46922546_buttonPress-harmonyhub:device:Livingroom:46922546:buttonPress' has been added.
2019-01-29 15:05:57.008 [.ItemChannelLinkAddedEvent] - Link 'harmonyhub_device_Livingroom_46922547_buttonPress-harmonyhub:device:Livingroom:46922547:buttonPress' has been added.
2019-01-29 15:05:57.011 [.ItemChannelLinkAddedEvent] - Link 'harmonyhub_hub_Livingroom_activityStarting-harmonyhub:hub:Livingroom:activityStarting' has been added.
2019-01-29 15:05:57.069 [home.event.InboxAddedEvent] - Discovery Result with UID 'harmonyhub:hub:Livingroom' has been added.
2019-01-29 15:05:57.068 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'harmonyhub:hub:Livingroom' to inbox.
2019-01-29 15:05:57.103 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922548' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2019-01-29 15:05:57.106 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922604' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2019-01-29 15:05:57.107 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922546' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2019-01-29 15:05:57.109 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922547' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2019-01-29 15:05:57.144 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:53906587' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2019-01-29 15:05:57.152 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:47790709' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2019-01-29 15:05:57.197 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922551' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2019-01-29 15:05:57.198 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922552' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2019-01-29 15:05:57.198 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:49425328' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2019-01-29 15:05:57.240 [me.event.InboxRemovedEvent] - Discovery Result with UID 'harmonyhub:hub:Livingroom' has been removed.
2019-01-29 15:05:57.275 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:Livingroom' changed from UNINITIALIZED to INITIALIZING
2019-01-29 15:05:57.304 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:Livingroom' changed from INITIALIZING to UNKNOWN
2019-01-29 15:05:57.345 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922547' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-01-29 15:05:57.348 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922604' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-01-29 15:05:57.348 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922547' changed from INITIALIZING to UNKNOWN
2019-01-29 15:05:57.349 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922547' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2019-01-29 15:05:57.349 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922552' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-01-29 15:05:57.350 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922604' changed from INITIALIZING to UNKNOWN
2019-01-29 15:05:57.350 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922604' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2019-01-29 15:05:57.350 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922552' changed from INITIALIZING to UNKNOWN
2019-01-29 15:05:57.355 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922552' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2019-01-29 15:05:57.356 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:53906587' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-01-29 15:05:57.359 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:53906587' changed from INITIALIZING to UNKNOWN
2019-01-29 15:05:57.360 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:53906587' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2019-01-29 15:05:57.360 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:49425328' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-01-29 15:05:57.361 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:47790709' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-01-29 15:05:57.362 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:47790709' changed from INITIALIZING to UNKNOWN
2019-01-29 15:05:57.362 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:47790709' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2019-01-29 15:05:57.362 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:49425328' changed from INITIALIZING to UNKNOWN
2019-01-29 15:05:57.362 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:49425328' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2019-01-29 15:05:57.363 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922548' changed from INITIALIZING to UNKNOWN
2019-01-29 15:05:57.363 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922548' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2019-01-29 15:05:57.363 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922548' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-01-29 15:05:57.364 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922551' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-01-29 15:05:57.364 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922546' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-01-29 15:05:57.364 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922546' changed from INITIALIZING to UNKNOWN
2019-01-29 15:05:57.364 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922546' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2019-01-29 15:05:57.364 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922551' changed from INITIALIZING to UNKNOWN
2019-01-29 15:05:57.365 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922551' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2019-01-29 15:05:57.662 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:Livingroom' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Could not connect: Failed communicating with Harmony Hub
2019-01-29 15:06:00.561 [vent.ItemStateChangedEvent] - HarmonyLivingRoomCurrentActivityHomeKit changed from NULL to OFF
2019-01-29 15:06:00.588 [vent.ItemStateChangedEvent] - HarmonyLivingRoomCurrentActivity changed from NULL to PowerOff
2019-01-29 15:11:49.448 [ome.event.ItemCommandEvent] - Item 'HarmonyLivingRoomCurrentActivity' received command PC
2019-01-29 15:11:49.455 [nt.ItemStatePredictedEvent] - HarmonyLivingRoomCurrentActivity predicted to become PowerOff
2019-01-29 15:11:49.472 [ERROR] [b.internal.handler.HarmonyHubHandler] - Could not start activity
	at com.sun.proxy.$Proxy145.handleCommand(Unknown Source) [241:org.openhab.binding.harmonyhub:2.4.0]
2019-01-29 15:12:14.033 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:Livingroom' changed from OFFLINE (COMMUNICATION_ERROR): Could not connect: Failed communicating with Harmony Hub to REMOVING
2019-01-29 15:12:14.037 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:Livingroom' changed from REMOVING to REMOVED
2019-01-29 15:12:14.053 [temChannelLinkRemovedEvent] - Link 'harmonyhub_hub_Livingroom_activityStarting => harmonyhub:hub:Livingroom:activityStarting' has been removed.
2019-01-29 15:12:14.064 [temChannelLinkRemovedEvent] - Link 'harmonyhub_hub_Livingroom_activityStarted => harmonyhub:hub:Livingroom:activityStarted' has been removed.
2019-01-29 15:12:14.069 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922548' changed from OFFLINE (BRIDGE_OFFLINE) to UNINITIALIZED
2019-01-29 15:12:14.077 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922548' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-01-29 15:12:14.077 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922604' changed from OFFLINE (BRIDGE_OFFLINE) to UNINITIALIZED
2019-01-29 15:12:14.079 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922604' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-01-29 15:12:14.079 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922546' changed from OFFLINE (BRIDGE_OFFLINE) to UNINITIALIZED
2019-01-29 15:12:14.081 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922546' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-01-29 15:12:14.083 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922547' changed from OFFLINE (BRIDGE_OFFLINE) to UNINITIALIZED
2019-01-29 15:12:14.085 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922547' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-01-29 15:12:14.085 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922551' changed from OFFLINE (BRIDGE_OFFLINE) to UNINITIALIZED
2019-01-29 15:12:14.086 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922551' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-01-29 15:12:14.087 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922552' changed from OFFLINE (BRIDGE_OFFLINE) to UNINITIALIZED
2019-01-29 15:12:14.087 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922552' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-01-29 15:12:14.088 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:53906587' changed from OFFLINE (BRIDGE_OFFLINE) to UNINITIALIZED
2019-01-29 15:12:14.089 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:53906587' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-01-29 15:12:14.093 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:49425328' changed from OFFLINE (BRIDGE_OFFLINE) to UNINITIALIZED
2019-01-29 15:12:14.094 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:49425328' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-01-29 15:12:14.095 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:47790709' changed from OFFLINE (BRIDGE_OFFLINE) to UNINITIALIZED
2019-01-29 15:12:14.095 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:47790709' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-01-29 15:12:14.095 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:Livingroom' changed from REMOVED to UNINITIALIZED
2019-01-29 15:12:14.111 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:Livingroom' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-01-29 15:12:18.743 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'harmonyhub:hub:Livingroom' to inbox.
2019-01-29 15:12:18.745 [home.event.InboxAddedEvent] - Discovery Result with UID 'harmonyhub:hub:Livingroom' has been added.
2019-01-29 15:12:25.570 [.ItemChannelLinkAddedEvent] - Link 'harmonyhub_hub_Livingroom_currentActivity-harmonyhub:hub:Livingroom:currentActivity' has been added.
2019-01-29 15:12:25.578 [.ItemChannelLinkAddedEvent] - Link 'harmonyhub_hub_Livingroom_activityStarting-harmonyhub:hub:Livingroom:activityStarting' has been added.
2019-01-29 15:12:25.580 [.ItemChannelLinkAddedEvent] - Link 'harmonyhub_hub_Livingroom_activityStarted-harmonyhub:hub:Livingroom:activityStarted' has been added.
2019-01-29 15:12:25.593 [me.event.InboxRemovedEvent] - Discovery Result with UID 'harmonyhub:hub:Livingroom' has been removed.
2019-01-29 15:12:25.637 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:Livingroom' changed from UNINITIALIZED to INITIALIZING
2019-01-29 15:12:25.640 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:Livingroom' changed from INITIALIZING to UNKNOWN
2019-01-29 15:12:25.643 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922548' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-01-29 15:12:25.645 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922604' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-01-29 15:12:25.647 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922604' changed from INITIALIZING to UNKNOWN
2019-01-29 15:12:25.653 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922548' changed from INITIALIZING to UNKNOWN
2019-01-29 15:12:25.657 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922604' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2019-01-29 15:12:25.658 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922548' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2019-01-29 15:12:25.659 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922547' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-01-29 15:12:25.660 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:53906587' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-01-29 15:12:25.661 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922547' changed from INITIALIZING to UNKNOWN
2019-01-29 15:12:25.661 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922547' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2019-01-29 15:12:25.662 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922546' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-01-29 15:12:25.662 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:53906587' changed from INITIALIZING to UNKNOWN
2019-01-29 15:12:25.664 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922546' changed from INITIALIZING to UNKNOWN
2019-01-29 15:12:25.665 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922546' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2019-01-29 15:12:25.668 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:53906587' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2019-01-29 15:12:25.669 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922551' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-01-29 15:12:25.669 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:47790709' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-01-29 15:12:25.670 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922551' changed from INITIALIZING to UNKNOWN
2019-01-29 15:12:25.673 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922551' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2019-01-29 15:12:25.675 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:47790709' changed from INITIALIZING to UNKNOWN
2019-01-29 15:12:25.676 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:47790709' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2019-01-29 15:12:25.679 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:49425328' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-01-29 15:12:25.680 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:49425328' changed from INITIALIZING to UNKNOWN
2019-01-29 15:12:25.681 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:49425328' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2019-01-29 15:12:25.682 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922552' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-01-29 15:12:25.683 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922552' changed from INITIALIZING to UNKNOWN
2019-01-29 15:12:25.684 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Livingroom:46922552' changed from UNKNOWN to OFFLINE (BRIDGE_OFFLINE)
2019-01-29 15:12:25.698 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:Livingroom' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Could not connect: Failed communicating with Harmony Hub
2019-01-29 15:12:40.493 [ome.event.ItemCommandEvent] - Item 'HarmonyLivingRoomCurrentActivity' received command PC
2019-01-29 15:12:40.494 [nt.ItemStatePredictedEvent] - HarmonyLivingRoomCurrentActivity predicted to become PowerOff
2019-01-29 15:12:40.496 [ERROR] [b.internal.handler.HarmonyHubHandler] - Could not start activity
@maciekish When was the last time it worked?
Do you have Harmony Hub firmware v4.15.206?
If so, see here:
@Celaeno1 Hi and thanks for replying. I can’t tell exactly when it last worked because i just moved and had everything packed down in boxes for a long time. However the firmware is indeed 4.15.206.
@maciekish
Here is a manual to update to v4.15.210 developer firmware:
That fixed it, thank you very much!
@maciekish
Please tick the “solved” square. Maybe other users will find this helpful, too.
News: WARNING!!
Firmware 4.15.250 announced to be available: But it installs 4.15.206 without XMPP!
Do NOT upgrade!!
Mine was still on 4.15.201 because I’ve blocked internet access for hub.
Now I’ve updated firmware, but now it is 4.15.206
But I was able to switch on XMPP again via Harmony Hub App (5.6), but it IS NOT COMMUNICATING over XMPP!
@maciekish thanks for editing the title to indicate solved.:+1: Please take a few seconds to click the square box on the post that provided the solution as well.
Example:
DO NOT INSTALL IT YET!
Now they rolled out firmware update: 4.15.250
I activated XMPP again and using the latest official snapshot version.
  307 │ Active   │  80 │ 2.5.0.201902161217     │ HarmonyHub Binding
Now, they are telling the truth! :wink:
The Websocket implementation has been merged
https://github.com/openhab/openhab2-addons/pull/4926
There also was another issue, it has been merged , too.
https://github.com/openhab/openhab2-addons/pull/4938
beginner question: what does merged mean? the latest snapshot?
If there was an issue (e.g. error) or a pull request (=changes on program code, e.g. new functions) and after the changes were made and reviewed, the new program code has been merged into master code. After that a snapshot can be build from master.
One correct me if something is missing.
I’m still having trouble with my Harmony Binding…
  • Harmony Hub is on v4.15.250
  • XMPP has been activated via Android App
  • Harmony Bindings is on v2.5.0-SNAPSHOT (2019-02-20)
Yet, openHAB still shows the Hub as “OFFLINE - COMMUNICATION_ERROR” (Could not connect: Could not discover host 192.168.1.9).
I was under the impression that even with XMPP disabled the Binding should work via WebSocket now, shouldn’t it?
@couchtyp
Yes, it should run with Websocket now.
But I’m not sure if it has been merged before or after the latest snapshot build.
karaf console:
bundle:list |Grep Harmony
What is the reply?
Well, I’m feeling dumb now…
234 │ Active │ 80 │ 2.5.0.201902041209 │ HarmonyHub Binding
I updated to the current snapshot from JFrog and voilà, connected again.
235 │ Active │ 80 │ 2.5.0.201902200300 │ HarmonyHub Binding
Thanks for the hint and sorry for wasting your time!
