Harmony Hub - new activity causes "unhandled error" and hub to go offline
  • Platform information:
    • Hardware: ESXI 6.7.0
    • OS: Debian GNU/Linux 9 (stretch) VM
    • Java Runtime Environment: java version “1.8.0_201”
    • openHAB version: 2.5.0~S1558-1
    • Harmony Binding version: “2.5.0.201903220233 │ HarmonyHub Binding”
  • Issue of the topic: Created a new Harmony Activity, causes disconnect and unhandled error
Not certain if anyone else has encountered this…
Harmony Hub firmware is updated to 4.15.250 and XMPP is enabled.
Today I created a new activity using the Harmony App on my Chromebook, and when changing to this activity my Harmony Hub goes offline in openHAB and errors are present in frontail. Changing to Activities that I have been using for over a year does not generate an error.
The Activity I have created is exactly the same a previously existing one (only a different name), no additional devices or changes have been made. I have only noticed this as I am using a rule to watch for the Activity to change, and while watching frontail for debug info saw this happen.
Here is the error:
2019-04-14 17:20:17.312 [WARN ] [ny.HarmonyClient$MyWebSocketListener] - Unhandled Error (closing connection)
2019-04-14 17:20:32.316 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: null
2019-04-14 17:20:32.317 [hingStatusInfoChangedEvent] - 'harmonyhub:device:HarmonyHub:55559959' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-04-14 17:20:32.318 [hingStatusInfoChangedEvent] - 'harmonyhub:device:HarmonyHub:44169789' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-04-14 17:20:32.319 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
Has anyone else encountered this? Not certain if this is related to the updated Harmony Hub firmware or the Harmony Binding…
harmony.rules
rule "Activity changed"
    Item HarmonyHubHarmonyHub_Activity received update
    logInfo("Harmony", "Harmony Activity is now " + HarmonyHubHarmonyHub_Activity.state)
Any thoughts or suggestions?
Craig
Can you turn up the debugging on the harmony library and try again? In the openHAB console , the command would be:
log:set DEBUG com.digitaldan.harmony
see The Console | openHAB for how to access the console.
Thanks for responding Dan.
I’ve tried to set up a log file for this but made an error somewhere…
Here is a copy and paste from frontail:
2019-04-14 19:17:39.253 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - Sending: {"hbus":{"cmd":"vnd.logitech.connect/vnd.logitech.ping","id":"4635edf0-999c-4c0b-b02a-784f980023bf","params":{}}}
2019-04-14 19:17:47.680 [WARN ] [ny.HarmonyClient$MyWebSocketListener] - Unhandled Error (closing connection)
2019-04-14 19:17:47.681 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - onWebSocketError
2019-04-14 19:17:47.681 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - notifyClose null {}
2019-04-14 19:17:47.683 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - onWebSocketClose 1006 Disconnected
2019-04-14 19:17:47.683 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - notifyClose Disconnected {}
2019-04-14 19:18:02.683 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: null
2019-04-14 19:18:02.684 [hingStatusInfoChangedEvent] - 'harmonyhub:device:HarmonyHub:55559959' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-04-14 19:18:02.685 [hingStatusInfoChangedEvent] - 'harmonyhub:device:HarmonyHub:44169789' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-04-14 19:18:02.685 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-04-14 19:19:02.683 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.1.59
2019-04-14 19:19:02.797 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - onWebSocketConnect WebSocketSession[websocket=JettyListenerEventDriver[com.digitaldan.harmony.HarmonyClient$MyWebSocketListener],behavior=CLIENT,connection=WebSocketClientConnection@15146e0c::SocketChannelEndPoint@6c201de8{/192.168.1.59:8088<->/192.168.1.72:42560,OPEN,fill=-,flush=-,to=0/300000}{io=1/0,kio=1,kro=1}->WebSocketClientConnection@15146e0c[ios=IOState@29228e08[CONNECTED,!in,out],f=Flusher@ceb4102[queueSize=0,aggregateSize=-1,terminated=null],g=Generator[CLIENT,validating],p=Parser@18c162b0[ExtensionStack,s=START,c=0,len=0,f=null]],remote=WebSocketRemoteEndpoint@74e2f31d[batching=true],incoming=JettyListenerEventDriver[com.digitaldan.harmony.HarmonyClient$MyWebSocketListener],outgoing=ExtensionStack[queueSize=0,extensions=[],incoming=org.eclipse.jetty.websocket.common.WebSocketSession,outgoing=org.eclipse.jetty.websocket.client.io.WebSocketClientConnection]]
2019-04-14 19:19:02.800 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:HarmonyHub:55559959:buttonPress
2019-04-14 19:19:02.801 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from OFFLINE (COMMUNICATION_ERROR): Could not connect: null to ONLINE
2019-04-14 19:19:02.804 [hingStatusInfoChangedEvent] - 'harmonyhub:device:HarmonyHub:55559959' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
Craig
hmm, I think we need to set this to TRACE level, also I don’t see it switching to the new activity, can you make sure you thats in the next log you post ? The only send command i see there is the ping (unless the error is being thrown before this). So in the console, paste
log:set TRACE com.digitaldan.harmony
Also lets turn up the binding level as well:
log:set DEBUG org.openhab.binding.harmonyhub
When you are done you can set it back to WARN to avoid flooding your log files with
log:set WARN com.digitaldan.harmony
Both are set. I’ve Broken this into two copy and pastes.
This first is with an original activity “Shield TV” that did not have any errors.
2019-04-14 21:25:05.696 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"type":"connect.stateDigest?notify","data":{"sleepTimerId":-1,"runningZoneList":[],"sequence":false,"activityId":"34253132","errorCode":"200","syncStatus":0,"activitySetupState":false,"stateVersion":137,"tzOffset":"-14400","mode":3,"hubSwVersion":"4.15.250","deviceSetupState":[],"tzoffset":"-14400","isSetupComplete":true,"updates":{"106":"4.14.112","100":"4.14.112"},"discoveryServer":"https:\/\/svcs.myharmony.com\/Discovery\/Discovery.svc","configVersion":538,"activityStatus":1,"wifiStatus":1,"tz":"EST5EDT,M3.2.0,M11.1.0","runningActivityList":"24448571","time":1555291464,"hubUpdate":false,"contentVersion":142,"accountId":"7437024"}}
2019-04-14 21:25:05.697 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:25:05.697 [TRACE] [com.digitaldan.harmony.HarmonyClient] - DigestMessage 34253132
2019-04-14 21:25:05.697 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - status listener[org.openhab.binding.harmonyhub.internal.handler.HarmonyHubHandler@329dba9d] notified: Activity[34253132]:SHIELD TV - ACTIVITY_IS_STARTING
2019-04-14 21:25:05.697 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Received ACTIVITY_IS_STARTING activity status for SHIELD TV
2019-04-14 21:25:05.697 [vent.ChannelTriggeredEvent] - harmonyhub:hub:HarmonyHub:activityStarting triggered SHIELD_TV
2019-04-14 21:25:08.764 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"type":"connect.stateDigest?notify","data":{"sleepTimerId":-1,"runningZoneList":[],"sequence":false,"activityId":"34253132","errorCode":"200","syncStatus":0,"activitySetupState":false,"stateVersion":138,"tzOffset":"-14400","mode":3,"hubSwVersion":"4.15.250","deviceSetupState":[],"tzoffset":"-14400","isSetupComplete":true,"updates":{"106":"4.14.112","100":"4.14.112"},"discoveryServer":"https:\/\/svcs.myharmony.com\/Discovery\/Discovery.svc","configVersion":538,"activityStatus":2,"wifiStatus":1,"tz":"EST5EDT,M3.2.0,M11.1.0","runningActivityList":"24448571","time":1555291464,"hubUpdate":false,"contentVersion":142,"accountId":"7437024"}}
2019-04-14 21:25:08.764 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:25:08.764 [TRACE] [com.digitaldan.harmony.HarmonyClient] - DigestMessage 34253132
2019-04-14 21:25:08.764 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - status listener[org.openhab.binding.harmonyhub.internal.handler.HarmonyHubHandler@329dba9d] notified: Activity[34253132]:SHIELD TV - ACTIVITY_IS_STARTED
2019-04-14 21:25:08.764 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Received ACTIVITY_IS_STARTED activity status for SHIELD TV
2019-04-14 21:25:08.765 [vent.ChannelTriggeredEvent] - harmonyhub:hub:HarmonyHub:activityStarted triggered SHIELD_TV
2019-04-14 21:25:08.807 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"type":"harmony.engine?startActivityFinished","data":{"activityId":"34253132","errorCode":"200","errorString":"OK"}}
2019-04-14 21:25:08.807 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:25:08.807 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - ActivityFinishedMessage 34253132
2019-04-14 21:25:08.807 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating current activity to SHIELD TV
2019-04-14 21:25:08.809 [INFO ] [lipse.smarthome.model.script.Harmony] - Harmony Activity is now SHIELD TV
2019-04-14 21:25:08.809 [vent.ItemStateChangedEvent] - HarmonyHubHarmonyHub_Activity changed from Watch TV to SHIELD TV
2019-04-14 21:25:09.355 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"type":"connect.stateDigest?notify","data":{"sleepTimerId":-1,"runningZoneList":[],"sequence":false,"activityId":"34253132","errorCode":"200","syncStatus":0,"activitySetupState":false,"stateVersion":139,"tzOffset":"-14400","mode":3,"hubSwVersion":"4.15.250","deviceSetupState":[],"tzoffset":"-14400","isSetupComplete":true,"updates":{"106":"4.14.112","100":"4.14.112"},"discoveryServer":"https:\/\/svcs.myharmony.com\/Discovery\/Discovery.svc","configVersion":538,"activityStatus":2,"wifiStatus":1,"tz":"EST5EDT,M3.2.0,M11.1.0","runningActivityList":"34253132","time":1555291507,"hubUpdate":false,"contentVersion":142,"accountId":"7437024"}}
2019-04-14 21:25:09.355 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:25:09.355 [TRACE] [com.digitaldan.harmony.HarmonyClient] - DigestMessage 34253132
2019-04-14 21:25:24.932 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - Sending: {"hbus":{"cmd":"vnd.logitech.connect/vnd.logitech.ping","id":"65d5875c-cf54-4d4b-830a-13344e27a698","params":{}}}
2019-04-14 21:25:24.933 [TRACE] [com.digitaldan.harmony.HarmonyClient] - writeSuccess for id 65d5875c-cf54-4d4b-830a-13344e27a698
2019-04-14 21:25:24.960 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"cmd":"vnd.logitech.connect\/vnd.logitech.ping","code":200,"id":"65d5875c-cf54-4d4b-830a-13344e27a698","msg":"OK","data":{"status":"alive","uuid":"d74310697280ebfee21efec77dab438965d27ff3","susTrigger":"websocket","id":"65d5875c-cf54-4d4b-830a-13344e27a698"}}
2019-04-14 21:25:24.961 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:25:24.961 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Looking for future for ID 65d5875c-cf54-4d4b-830a-13344e27a698
2019-04-14 21:25:24.961 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Calling for future for ID 65d5875c-cf54-4d4b-830a-13344e27a698
2019-04-14 21:25:27.631 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defa359a:Main_Zone' has been updated.
2019-04-14 21:25:54.933 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - Sending: {"hbus":{"cmd":"vnd.logitech.connect/vnd.logitech.ping","id":"39af6b5b-6f02-49a7-b36f-661a0357ead9","params":{}}}
2019-04-14 21:25:54.933 [TRACE] [com.digitaldan.harmony.HarmonyClient] - writeSuccess for id 39af6b5b-6f02-49a7-b36f-661a0357ead9
2019-04-14 21:25:54.966 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"cmd":"vnd.logitech.connect\/vnd.logitech.ping","code":200,"id":"39af6b5b-6f02-49a7-b36f-661a0357ead9","msg":"OK","data":{"status":"alive","uuid":"d74310697280ebfee21efec77dab438965d27ff3","susTrigger":"websocket","id":"39af6b5b-6f02-49a7-b36f-661a0357ead9"}}
2019-04-14 21:25:54.966 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:25:54.966 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Looking for future for ID 39af6b5b-6f02-49a7-b36f-661a0357ead9
2019-04-14 21:25:54.966 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Calling for future for ID 39af6b5b-6f02-49a7-b36f-661a0357ead9
This is when I started the new activity “Kodi”. It is set up exactly like “Shield TV” in the Harmony app. I note it also never says it has changed to “Kodi”, and reports as being “Shield TV” at 21:27:20.731. PaperUI says it is “Shield TV” as well. This is the same for any activity I change from it reports it is the activity i was just using (eg. Watch TV, Use Computer…). Side note my Elite remote functions properly per the activity selected.
2019-04-14 21:26:05.603 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"type":"connect.stateDigest?notify","data":{"sleepTimerId":-1,"runningZoneList":[],"sequence":false,"activityId":"39339472","errorCode":"200","syncStatus":0,"activitySetupState":false,"stateVersion":140,"tzOffset":"-14400","mode":3,"hubSwVersion":"4.15.250","deviceSetupState":[],"tzoffset":"-14400","isSetupComplete":true,"updates":{"106":"4.14.112","100":"4.14.112"},"discoveryServer":"https:\/\/svcs.myharmony.com\/Discovery\/Discovery.svc","configVersion":538,"activityStatus":1,"wifiStatus":1,"tz":"EST5EDT,M3.2.0,M11.1.0","runningActivityList":"34253132","time":1555291507,"hubUpdate":false,"contentVersion":142,"accountId":"7437024"}}
2019-04-14 21:26:05.603 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:26:05.603 [WARN ] [ny.HarmonyClient$MyWebSocketListener] - Unhandled Error (closing connection)
	at com.digitaldan.harmony.HarmonyClient$MyWebSocketListener.onWebSocketText(HarmonyClient.java:510) ~[?:?]
2019-04-14 21:26:05.604 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - onWebSocketError
	at com.digitaldan.harmony.HarmonyClient$MyWebSocketListener.onWebSocketText(HarmonyClient.java:510) [243:org.openhab.binding.harmonyhub:2.5.0.201903220233]
2019-04-14 21:26:05.608 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - notifyClose null {}
2019-04-14 21:26:05.609 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - onWebSocketClose 1006 Disconnected
2019-04-14 21:26:05.609 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - notifyClose Disconnected {}
2019-04-14 21:26:20.609 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: null
2019-04-14 21:26:20.610 [hingStatusInfoChangedEvent] - 'harmonyhub:device:HarmonyHub:55559959' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-04-14 21:26:20.611 [hingStatusInfoChangedEvent] - 'harmonyhub:device:HarmonyHub:44169789' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-04-14 21:26:20.611 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-04-14 21:26:27.639 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defa359a:Main_Zone' has been updated.
2019-04-14 21:27:20.609 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.1.59
2019-04-14 21:27:20.617 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Sending {"cmd":"setup.account?getProvisionInfo","id":"c18791c8-3597-4789-950c-64ab228de5d2","params":{}}
2019-04-14 21:27:20.670 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Discovery response for hos 192.168.1.59 : {"id":"c18791c8-3597-4789-950c-64ab228de5d2","msg":"OK","data":{"email":"dummy@mail.com","username":"dummy@mail.com","activeRemoteId":7773856,"discoveryServer":"https:\/\/svcs.myharmony.com\/Discovery\/Discovery.svc","se":true,"susChannel":"production","mode":3,"language":"en-US","accountId":"7437024"},"code":"200"}
2019-04-14 21:27:20.726 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - onWebSocketConnect WebSocketSession[websocket=JettyListenerEventDriver[com.digitaldan.harmony.HarmonyClient$MyWebSocketListener],behavior=CLIENT,connection=WebSocketClientConnection@15149ef8::SocketChannelEndPoint@5fb385a5{/192.168.1.59:8088<->/192.168.1.72:42964,OPEN,fill=-,flush=-,to=0/300000}{io=1/0,kio=1,kro=1}->WebSocketClientConnection@15149ef8[ios=IOState@1ab11037[CONNECTED,!in,out],f=Flusher@108678f2[queueSize=0,aggregateSize=-1,terminated=null],g=Generator[CLIENT,validating],p=Parser@2b614c94[ExtensionStack,s=START,c=0,len=0,f=null]],remote=WebSocketRemoteEndpoint@68bc7af0[batching=true],incoming=JettyListenerEventDriver[com.digitaldan.harmony.HarmonyClient$MyWebSocketListener],outgoing=ExtensionStack[queueSize=0,extensions=[],incoming=org.eclipse.jetty.websocket.common.WebSocketSession,outgoing=org.eclipse.jetty.websocket.client.io.WebSocketClientConnection]]
2019-04-14 21:27:20.727 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from OFFLINE (COMMUNICATION_ERROR): Could not connect: null to ONLINE
2019-04-14 21:27:20.727 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:HarmonyHub:55559959:buttonPress
2019-04-14 21:27:20.728 [hingStatusInfoChangedEvent] - 'harmonyhub:device:HarmonyHub:55559959' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2019-04-14 21:27:20.728 [me.event.ThingUpdatedEvent] - Thing 'harmonyhub:device:HarmonyHub:55559959' has been updated.
2019-04-14 21:27:20.729 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:HarmonyHub:44169789:buttonPress
2019-04-14 21:27:20.730 [hingStatusInfoChangedEvent] - 'harmonyhub:device:HarmonyHub:44169789' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2019-04-14 21:27:20.730 [me.event.ThingUpdatedEvent] - Thing 'harmonyhub:device:HarmonyHub:44169789' has been updated.
2019-04-14 21:27:20.730 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-04-14 21:27:20.730 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating current activity to SHIELD TV
2019-04-14 21:27:20.731 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating harmonyhub:hub:HarmonyHub:currentActivity
2019-04-14 21:27:20.731 [INFO ] [lipse.smarthome.model.script.Harmony] - Harmony Activity is now SHIELD TV
2019-04-14 21:27:20.734 [me.event.ThingUpdatedEvent] - Thing 'harmonyhub:hub:HarmonyHub' has been updated.
2019-04-14 21:27:27.646 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defa359a:Main_Zone' has been updated.
2019-04-14 21:27:50.726 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - Sending: {"hbus":{"cmd":"vnd.logitech.connect/vnd.logitech.ping","id":"a70ef8f9-3864-43c8-9641-717ef40c085f","params":{}}}
2019-04-14 21:27:50.727 [TRACE] [com.digitaldan.harmony.HarmonyClient] - writeSuccess for id a70ef8f9-3864-43c8-9641-717ef40c085f
2019-04-14 21:27:50.749 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"cmd":"vnd.logitech.connect\/vnd.logitech.ping","code":200,"id":"a70ef8f9-3864-43c8-9641-717ef40c085f","msg":"OK","data":{"status":"alive","uuid":"d74310697280ebfee21efec77dab438965d27ff3","susTrigger":"websocket","id":"a70ef8f9-3864-43c8-9641-717ef40c085f"}}
2019-04-14 21:27:50.750 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:27:50.750 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Looking for future for ID a70ef8f9-3864-43c8-9641-717ef40c085f
2019-04-14 21:27:50.750 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Calling for future for ID a70ef8f9-3864-43c8-9641-717ef40c085f
2019-04-14 21:28:20.728 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - Sending: {"hbus":{"cmd":"vnd.logitech.connect/vnd.logitech.ping","id":"69077234-3791-4693-b1d4-ef4590b8f5d0","params":{}}}
2019-04-14 21:28:20.728 [TRACE] [com.digitaldan.harmony.HarmonyClient] - writeSuccess for id 69077234-3791-4693-b1d4-ef4590b8f5d0
2019-04-14 21:28:20.761 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"cmd":"vnd.logitech.connect\/vnd.logitech.ping","code":200,"id":"69077234-3791-4693-b1d4-ef4590b8f5d0","msg":"OK","data":{"status":"alive","uuid":"d74310697280ebfee21efec77dab438965d27ff3","susTrigger":"websocket","id":"69077234-3791-4693-b1d4-ef4590b8f5d0"}}
2019-04-14 21:28:20.762 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:28:20.776 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Looking for future for ID 69077234-3791-4693-b1d4-ef4590b8f5d0
2019-04-14 21:28:20.777 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Calling for future for ID 69077234-3791-4693-b1d4-ef4590b8f5d0
2019-04-14 21:28:27.654 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defa359a:Main_Zone' has been updated.
2019-04-14 21:28:50.728 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - Sending: {"hbus":{"cmd":"vnd.logitech.connect/vnd.logitech.ping","id":"a256bc19-0e31-486e-972f-1ff0d43aeb92","params":{}}}
2019-04-14 21:28:50.729 [TRACE] [com.digitaldan.harmony.HarmonyClient] - writeSuccess for id a256bc19-0e31-486e-972f-1ff0d43aeb92
2019-04-14 21:28:50.751 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"cmd":"vnd.logitech.connect\/vnd.logitech.ping","code":200,"id":"a256bc19-0e31-486e-972f-1ff0d43aeb92","msg":"OK","data":{"status":"alive","uuid":"d74310697280ebfee21efec77dab438965d27ff3","susTrigger":"websocket","id":"a256bc19-0e31-486e-972f-1ff0d43aeb92"}}
2019-04-14 21:28:50.751 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:28:50.751 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Looking for future for ID a256bc19-0e31-486e-972f-1ff0d43aeb92
2019-04-14 21:28:50.751 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Calling for future for ID a256bc19-0e31-486e-972f-1ff0d43aeb92
2019-04-14 21:29:20.730 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - Sending: {"hbus":{"cmd":"vnd.logitech.connect/vnd.logitech.ping","id":"f4bf8b3a-14c6-457c-a80c-cbe791273562","params":{}}}
2019-04-14 21:29:20.730 [TRACE] [com.digitaldan.harmony.HarmonyClient] - writeSuccess for id f4bf8b3a-14c6-457c-a80c-cbe791273562
2019-04-14 21:29:20.750 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"cmd":"vnd.logitech.connect\/vnd.logitech.ping","code":200,"id":"f4bf8b3a-14c6-457c-a80c-cbe791273562","msg":"OK","data":{"status":"alive","uuid":"d74310697280ebfee21efec77dab438965d27ff3","susTrigger":"websocket","id":"f4bf8b3a-14c6-457c-a80c-cbe791273562"}}
2019-04-14 21:29:20.750 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:29:20.751 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Looking for future for ID f4bf8b3a-14c6-457c-a80c-cbe791273562
2019-04-14 21:29:20.751 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Calling for future for ID f4bf8b3a-14c6-457c-a80c-cbe791273562
2019-04-14 21:29:27.662 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defa359a:Main_Zone' has been updated.
2019-04-14 21:29:50.730 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - Sending: {"hbus":{"cmd":"vnd.logitech.connect/vnd.logitech.ping","id":"d36f28f0-0c47-4a0d-814e-1e6401d8aa6a","params":{}}}
2019-04-14 21:29:50.731 [TRACE] [com.digitaldan.harmony.HarmonyClient] - writeSuccess for id d36f28f0-0c47-4a0d-814e-1e6401d8aa6a
2019-04-14 21:29:50.761 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"cmd":"vnd.logitech.connect\/vnd.logitech.ping","code":200,"id":"d36f28f0-0c47-4a0d-814e-1e6401d8aa6a","msg":"OK","data":{"status":"alive","uuid":"d74310697280ebfee21efec77dab438965d27ff3","susTrigger":"websocket","id":"d36f28f0-0c47-4a0d-814e-1e6401d8aa6a"}}
2019-04-14 21:29:50.761 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:29:50.761 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Looking for future for ID d36f28f0-0c47-4a0d-814e-1e6401d8aa6a
2019-04-14 21:29:50.761 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Calling for future for ID d36f28f0-0c47-4a0d-814e-1e6401d8aa6a
2019-04-14 21:30:20.731 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - Sending: {"hbus":{"cmd":"vnd.logitech.connect/vnd.logitech.ping","id":"1d17f9a3-cd3a-474f-9590-99d98cb1b40c","params":{}}}
2019-04-14 21:30:20.731 [TRACE] [com.digitaldan.harmony.HarmonyClient] - writeSuccess for id 1d17f9a3-cd3a-474f-9590-99d98cb1b40c
2019-04-14 21:30:20.768 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"cmd":"vnd.logitech.connect\/vnd.logitech.ping","code":200,"id":"1d17f9a3-cd3a-474f-9590-99d98cb1b40c","msg":"OK","data":{"status":"alive","uuid":"d74310697280ebfee21efec77dab438965d27ff3","susTrigger":"websocket","id":"1d17f9a3-cd3a-474f-9590-99d98cb1b40c"}}
2019-04-14 21:30:20.769 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:30:20.769 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Looking for future for ID 1d17f9a3-cd3a-474f-9590-99d98cb1b40c
2019-04-14 21:30:20.769 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Calling for future for ID 1d17f9a3-cd3a-474f-9590-99d98cb1b40c
2019-04-14 21:30:27.673 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defa359a:Main_Zone' has been updated.
2019-04-14 21:30:50.732 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - Sending: {"hbus":{"cmd":"vnd.logitech.connect/vnd.logitech.ping","id":"2ec8734d-e42c-4d67-a28d-e486668fe1e7","params":{}}}
2019-04-14 21:30:50.732 [TRACE] [com.digitaldan.harmony.HarmonyClient] - writeSuccess for id 2ec8734d-e42c-4d67-a28d-e486668fe1e7
2019-04-14 21:30:50.762 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"cmd":"vnd.logitech.connect\/vnd.logitech.ping","code":200,"id":"2ec8734d-e42c-4d67-a28d-e486668fe1e7","msg":"OK","data":{"status":"alive","uuid":"d74310697280ebfee21efec77dab438965d27ff3","susTrigger":"websocket","id":"2ec8734d-e42c-4d67-a28d-e486668fe1e7"}}
2019-04-14 21:30:50.762 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:30:50.762 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Looking for future for ID 2ec8734d-e42c-4d67-a28d-e486668fe1e7
2019-04-14 21:30:50.762 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Calling for future for ID 2ec8734d-e42c-4d67-a28d-e486668fe1e7
2019-04-14 21:31:20.732 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - Sending: {"hbus":{"cmd":"vnd.logitech.connect/vnd.logitech.ping","id":"827e1518-ed44-43a5-8668-eb100641afc9","params":{}}}
2019-04-14 21:31:20.732 [TRACE] [com.digitaldan.harmony.HarmonyClient] - writeSuccess for id 827e1518-ed44-43a5-8668-eb100641afc9
2019-04-14 21:31:20.763 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"cmd":"vnd.logitech.connect\/vnd.logitech.ping","code":200,"id":"827e1518-ed44-43a5-8668-eb100641afc9","msg":"OK","data":{"status":"alive","uuid":"d74310697280ebfee21efec77dab438965d27ff3","susTrigger":"websocket","id":"827e1518-ed44-43a5-8668-eb100641afc9"}}
2019-04-14 21:31:20.763 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:31:20.763 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Looking for future for ID 827e1518-ed44-43a5-8668-eb100641afc9
2019-04-14 21:31:20.763 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Calling for future for ID 827e1518-ed44-43a5-8668-eb100641afc9
2019-04-14 21:31:27.677 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defa359a:Main_Zone' has been updated.
2019-04-14 21:31:50.733 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - Sending: {"hbus":{"cmd":"vnd.logitech.connect/vnd.logitech.ping","id":"996c05be-d5be-48c4-84ac-948f9ae5b0b5","params":{}}}
2019-04-14 21:31:50.733 [TRACE] [com.digitaldan.harmony.HarmonyClient] - writeSuccess for id 996c05be-d5be-48c4-84ac-948f9ae5b0b5
2019-04-14 21:31:50.754 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"cmd":"vnd.logitech.connect\/vnd.logitech.ping","code":200,"id":"996c05be-d5be-48c4-84ac-948f9ae5b0b5","msg":"OK","data":{"status":"alive","uuid":"d74310697280ebfee21efec77dab438965d27ff3","susTrigger":"websocket","id":"996c05be-d5be-48c4-84ac-948f9ae5b0b5"}}
2019-04-14 21:31:50.754 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:31:50.754 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Looking for future for ID 996c05be-d5be-48c4-84ac-948f9ae5b0b5
2019-04-14 21:31:50.754 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Calling for future for ID 996c05be-d5be-48c4-84ac-948f9ae5b0b5
2019-04-14 21:32:20.734 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - Sending: {"hbus":{"cmd":"vnd.logitech.connect/vnd.logitech.ping","id":"0cc4ece1-83f0-4d33-891f-791fe3da746b","params":{}}}
2019-04-14 21:32:20.734 [TRACE] [com.digitaldan.harmony.HarmonyClient] - writeSuccess for id 0cc4ece1-83f0-4d33-891f-791fe3da746b
2019-04-14 21:32:20.760 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"cmd":"vnd.logitech.connect\/vnd.logitech.ping","code":200,"id":"0cc4ece1-83f0-4d33-891f-791fe3da746b","msg":"OK","data":{"status":"alive","uuid":"d74310697280ebfee21efec77dab438965d27ff3","susTrigger":"websocket","id":"0cc4ece1-83f0-4d33-891f-791fe3da746b"}}
2019-04-14 21:32:20.760 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:32:20.760 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Looking for future for ID 0cc4ece1-83f0-4d33-891f-791fe3da746b
2019-04-14 21:32:20.760 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Calling for future for ID 0cc4ece1-83f0-4d33-891f-791fe3da746b
2019-04-14 21:32:27.685 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defa359a:Main_Zone' has been updated.
2019-04-14 21:32:43.498 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-04-14 21:32:43.499 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 45941
2019-04-14 21:32:50.734 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - Sending: {"hbus":{"cmd":"vnd.logitech.connect/vnd.logitech.ping","id":"4cbe5992-eef0-4b3f-b79f-bad58de1e4db","params":{}}}
2019-04-14 21:32:50.734 [TRACE] [com.digitaldan.harmony.HarmonyClient] - writeSuccess for id 4cbe5992-eef0-4b3f-b79f-bad58de1e4db
2019-04-14 21:32:50.958 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"cmd":"vnd.logitech.connect\/vnd.logitech.ping","code":200,"id":"4cbe5992-eef0-4b3f-b79f-bad58de1e4db","msg":"OK","data":{"status":"alive","uuid":"d74310697280ebfee21efec77dab438965d27ff3","susTrigger":"websocket","id":"4cbe5992-eef0-4b3f-b79f-bad58de1e4db"}}
2019-04-14 21:32:50.958 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:32:50.958 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Looking for future for ID 4cbe5992-eef0-4b3f-b79f-bad58de1e4db
2019-04-14 21:32:50.958 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Calling for future for ID 4cbe5992-eef0-4b3f-b79f-bad58de1e4db
2019-04-14 21:33:20.735 [DEBUG] [com.digitaldan.harmony.HarmonyClient] - Sending: {"hbus":{"cmd":"vnd.logitech.connect/vnd.logitech.ping","id":"29e493be-78c3-487b-95e4-80843ccd1fa9","params":{}}}
2019-04-14 21:33:20.735 [TRACE] [com.digitaldan.harmony.HarmonyClient] - writeSuccess for id 29e493be-78c3-487b-95e4-80843ccd1fa9
2019-04-14 21:33:20.757 [TRACE] [com.digitaldan.harmony.HarmonyClient] - onWebSocketText {"cmd":"vnd.logitech.connect\/vnd.logitech.ping","code":200,"id":"29e493be-78c3-487b-95e4-80843ccd1fa9","msg":"OK","data":{"status":"alive","uuid":"d74310697280ebfee21efec77dab438965d27ff3","susTrigger":"websocket","id":"29e493be-78c3-487b-95e4-80843ccd1fa9"}}
2019-04-14 21:33:20.758 [TRACE] [harmony.messages.MessageDeserializer] - Calling fromJsonElement
2019-04-14 21:33:20.758 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Looking for future for ID 29e493be-78c3-487b-95e4-80843ccd1fa9
2019-04-14 21:33:20.758 [TRACE] [com.digitaldan.harmony.HarmonyClient] - Calling for future for ID 29e493be-78c3-487b-95e4-80843ccd1fa9
2019-04-14 21:33:27.694 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defa359a:Main_Zone' has been updated.
Craig
Hi Craig, fyi i have not forgotten about this, but i’m away on business for the week (and next). As soon as i can i i will take a look.
In the mean time, i believe in TRACE mode, when the binding starts up the harmony lib will output a huge JSON string to the log file which represents the entire harmony config ( all activities, devices, button presses). Can PM that to me ?
No worries Dan I appreciate your help.
PMing to you now.
Craig
In search of troubleshooting my issue with a new activity on my Harmony Hub, I came across this post.
I think I have the exact same issue as the OP. I had 3 activities active on my Hub and created another one. When I trigger that last activity, the hub goes offline in OH and after 1 minute it comes back.
EDIT: I did a reset of my hub and resynced everything. Now it works again.
Hi there,
I’m still seeing this behavior, it happens every few weeks.
Any chance we can re-open this and take a look?
Thanks,
Kent
