Hi, I am working with OH2 and everything is fine so far. But the Auto Discovery of the Harmony Binding does not find the hub (as a thing). When I try to add the hub manually it doesn’t work also.
Do anybody have an idea? The hub works very well beside OH.
The events.log contains the following regarding the manually added Harmony Hub as a thing:
2017-03-05 10:14:34.701 [hingStatusInfoChangedEvent] - ‘harmonyhub:hub:HarmonayHub’ changed from UNINITIALIZED to INITIALIZING
2017-03-05 10:14:37.141 [hingStatusInfoChangedEvent] - ‘harmonyhub:hub:HarmonayHub’ changed from INITIALIZING to UNKNOWN
You need to use the name configured in your Harmony application.
But apart from that the autodiscovery should work right away, al least it did at mine.
Do you have the hub connected to a different switch? I remember reading somewhere that discovery does not work when hub and openHAB server are not connected directly to the router or to the same network switch …
[quote=“sihui, post:5, topic:24399”]Do you have the hub connected to a different switch? I remember reading somewhere that discovery does not work when hub and openHAB server are not connected directly to the router or to the same network switch …
[/quote]
Yes, I do. The server is directly connected to the router and the hub is connected via a WLAN access point, which is connected to a switch…
How should I configure the hub in that case? By PaperUI manually (what information do I have to enter exactly) or in a thing-file?
I don’t think a different/additional setup/config is possible …
I would, for testing purposes, connect the hub temporary to your router directly and see if that works.
The hub is connected via WLAN with the router (Fritzbox) and the (windows) OH server now wired with the Fritzbox. The harmony configuration software notes the hub as connected with the Fritzbox Router. But the OH thing discovery does not find any Harmony hub
Upps … I have not the slightest idea what needs to be done on a Windows machine.
Try to find something about the technology the hub is working with, maybe you need to open a specific port or enable UPNP on Windows or whatever.
Sorry, I’m not able to help with Windows …
You helped me a lot I turned off the firewall and the hub (incl. all it’s devices) was found. When I turn the firewall on again, the Hub is offline, but now I have to find out, which port (or whatever) needs to be open
can you let us know what you did to get the harmony hub discovered through the windows firewall? I’m having the same issue. hub was found fine on a linux VM i was testing with, but in windows it won’t find it. certain port needs to be opened?
