since the last update of OpenHAB i’m having also problems with buttonpress commands.
Log shows:
21:06:37.273 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Beamer' received command PowerToggle
21:06:37.275 [WARN ] [internal.profiles.ProfileCallbackImpl] - Cannot delegate update 'PowerToggle' for item 'Beamer' to handler for channel 'harmonyhub:device:Wohnzimmer:28148559:buttonPress', because no handler is assigned. Maybe the binding is not installed or not propertly initialized.
Here are some more Infos about my setup:
openHAB 2.2.0-SNAPSHOT Build #1080
bundle:list |grep HarmonyHub 21:15:09
220 │ Active │ 80 │ 2.2.0.201711121147 │ HarmonyHub Binding
String Beamer { channel="harmonyhub:device:Wohnzimmer:28148559:buttonPress" }
Thing:
Bridge harmonyhub:hub:Wohnzimmer [ host="192.168.0.127"]
Bridge harmonyhub:hub:Wohnzimmer [ name="Beamer"] {
device Beamer [ id=28148559]
rule "Beamer Power"
Item BeamerPowerSwitch changed
if (BeamerPowerSwitch.state == ON)
Beamer.sendCommand("PowerToggle")
BeamerLamp1.sendCommand(ON)
BeamerLamp2.sendCommand(ON)
BeamerLamp3.sendCommand(ON)
if (BeamerPowerSwitch.state == OFF){Beamer.sendCommand("PowerToggle")}
This happens when i reload the Thing file:
21:05:43.470 [INFO ] [del.core.internal.ModelRepositoryImpl] - Refreshing model 'harmony.things'
21:05:43.710 [DEBUG] [.harmonyhub.handler.HarmonyHubHandler] - Connecting: host 192.168.0.127
21:05:44.760 [DEBUG] [.harmonyhub.handler.HarmonyHubHandler] - Updating current activity to PowerOff
21:05:44.816 [DEBUG] [.harmonyhub.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
21:05:44.868 [DEBUG] [.harmonyhub.handler.HarmonyHubHandler] - Refreshing conf cache
21:05:48.561 [ERROR] [home.core.thing.internal.ThingManager] - Exception occurred while calling thing updated at ThingHandler 'org.openhab.binding.harmonyhub.handler.HarmonyHubHandler@16ba6e8': null
java.util.concurrent.TimeoutException: null
at java.util.concurrent.FutureTask.get(FutureTask.java:205) ~[?:?]
at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:194) ~[?:?]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:83) ~[?:?]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:67) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManager.thingUpdated(ThingManager.java:423) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyTrackers(ThingRegistryImpl.java:217) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutUpdatedElement(ThingRegistryImpl.java:140) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutUpdatedElement(ThingRegistryImpl.java:1) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:183) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:1) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:57) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListenersAboutUpdatedElement(AbstractProvider.java:81) ~[?:?]
at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.lambda$21(GenericThingProvider.java:894) ~[?:?]
at java.util.ArrayList.forEach(ArrayList.java:1255) ~[?:?]
at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.createThingsFromModelForThingHandlerFactory(GenericThingProvider.java:901) ~[?:?]
at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.lambda$3(GenericThingProvider.java:294) ~[?:?]
at java.lang.Iterable.forEach(Iterable.java:75) [?:?]
at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.createThingsFromModel(GenericThingProvider.java:296) [134:org.eclipse.smarthome.model.thing:0.9.0.201711101643]
at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.modelChanged(GenericThingProvider.java:736) [134:org.eclipse.smarthome.model.thing:0.9.0.201711101643]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:309) [123:org.eclipse.smarthome.model.core:0.9.0.201711101643]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:138) [123:org.eclipse.smarthome.model.core:0.9.0.201711101643]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:242) [123:org.eclipse.smarthome.model.core:0.9.0.201711101643]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:306) [123:org.eclipse.smarthome.model.core:0.9.0.201711101643]
at org.eclipse.smarthome.core.service.WatchQueueReader.run(WatchQueueReader.java:204) [98:org.eclipse.smarthome.core:0.9.0.201711101643]
21:05:49.863 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'harmonyhub:hub:Wohnzimmer' has been updated.
I also tried reinstalling the binding:
21:03:12.490 [DEBUG] [.discovery.HarmonyHubDiscoveryService] - Start Harmony Hub background discovery
21:03:12.613 [DEBUG] [.discovery.HarmonyHubDiscoveryService] - Start Scan
21:03:12.696 [DEBUG] [.discovery.HarmonyHubDiscoveryService] - StartScan called
21:03:12.705 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={component.name=org.openhab.binding.harmonyhub.internal.discovery, component.id=261, service.id=399, service.bundleid=220, service.scope=bundle} - org.openhab.binding.harmonyhub
21:03:12.746 [DEBUG] [.discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 33444
21:03:12.988 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'harmonyhub:device:Wohnzimmer:28148559' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
21:03:13.008 [DEBUG] [scovery.HarmonyDeviceDiscoveryService] - HarmonyDeviceDiscoveryService org.openhab.binding.harmonyhub.handler.HarmonyHubHandler@16ba6e8
21:03:13.076 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'harmonyhub:device:Wohnzimmer:28148560' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
21:03:13.230 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=401, service.bundleid=220, service.scope=singleton} - org.openhab.binding.harmonyhub
21:03:13.312 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'harmonyhub:device:Wohnzimmer:37837612' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
21:03:13.628 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'harmonyhub:hub:Wohnzimmer' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
21:03:14.288 [DEBUG] [.harmonyhub.handler.HarmonyHubHandler] - Connecting: host 192.168.0.127
21:03:18.558 [WARN ] [home.core.thing.internal.ThingManager] - Initializing handler for thing 'harmonyhub:hub:Wohnzimmer' takes more than 5000ms.
21:03:18.951 [DEBUG] [.harmonyhub.handler.HarmonyHubHandler] - Updating current activity to PowerOff
21:03:19.009 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'harmonyhub:hub:Wohnzimmer' changed from INITIALIZING to ONLINE
21:03:19.009 [DEBUG] [.harmonyhub.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
21:03:19.082 [DEBUG] [rmonyhub.handler.HarmonyDeviceHandler] - initializing 28148560
21:03:19.125 [DEBUG] [.harmonyhub.handler.HarmonyHubHandler] - Refreshing conf cache
21:03:19.166 [DEBUG] [rmonyhub.handler.HarmonyDeviceHandler] - updateChannel for device 28148560
21:03:23.819 [ERROR] [home.core.thing.internal.ThingManager] - Exception occurred while calling thing updated at ThingHandler 'org.openhab.binding.harmonyhub.handler.HarmonyHubHandler@16ba6e8': null
at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.lambda$17(GenericThingProvider.java:824) ~[?:?]
at java.util.concurrent.ConcurrentHashMap$KeySetView.forEach(ConcurrentHashMap.java:4649) ~[?:?]
at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.thingHandlerFactoryAdded(GenericThingProvider.java:826) ~[?:?]
at org.eclipse.smarthome.model.thing.internal.GenericThingProvider.addThingHandlerFactory(GenericThingProvider.java:810) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) ~[?:?]
at org.apache.felix.scr.impl.inject.BindMethod.invoke(BindMethod.java:658) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1722) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1699) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:372) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:320) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:291) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) ~[?:?]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) ~[?:?]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) ~[?:?]
at org.apache.felix.utils.extender.AbstractExtender.addingBundle(AbstractExtender.java:187) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:415) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) ~[?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:470) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.start(ModuleContainer.java:736) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.applyDelta(ModuleContainer.java:727) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.resolveAndApply(ModuleContainer.java:497) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:443) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:433) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.resolveBundles(ModuleContainer.java:1299) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.resolveBundles(FeaturesServiceImpl.java:1425) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:877) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1233) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$0(FeaturesServiceImpl.java:1132) ~[?:?]
21:03:24.043 [WARN ] [home.core.thing.internal.ThingManager] - Initializing handler for thing 'harmonyhub:device:Wohnzimmer:28148560' takes more than 5000ms.
21:03:32.168 [DEBUG] [.harmonyhub.handler.HarmonyHubHandler] - Connecting: host 192.168.0.127
21:03:32.118 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory, org.eclipse.smarthome.core.thing.type.ChannelTypeProvider}={component.name=binding.harmonyhub, component.id=262, service.id=400, service.bundleid=220, service.scope=bundle} - org.openhab.binding.harmonyhub
21:03:32.107 [DEBUG] [rmonyhub.handler.HarmonyDeviceHandler] - initializing 37837612
21:03:32.218 [DEBUG] [rmonyhub.handler.HarmonyDeviceHandler] - initializing 28148559
21:03:32.653 [DEBUG] [rmonyhub.handler.HarmonyDeviceHandler] - updateChannel for device 37837612
21:03:32.718 [DEBUG] [rmonyhub.handler.HarmonyDeviceHandler] - updateChannel for device 28148559
21:03:33.364 [DEBUG] [.harmonyhub.handler.HarmonyHubHandler] - Updating current activity to PowerOff
21:03:33.420 [DEBUG] [.harmonyhub.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
21:03:33.566 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'harmonyhub:device:Wohnzimmer:28148560' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
21:03:33.575 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'harmonyhub:hub:Wohnzimmer' has been updated.
21:03:33.675 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'harmonyhub:device:Wohnzimmer:28148559' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
21:03:33.730 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'harmonyhub:device:Wohnzimmer:37837612' changed from INITIALIZING to ONLINE
21:03:33.814 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'harmonyhub:device:Wohnzimmer:37837612' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
21:03:33.865 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'harmonyhub:device:Wohnzimmer:37837612' has been updated.
21:03:33.941 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'harmonyhub:device:Wohnzimmer:28148560' changed from INITIALIZING to ONLINE
21:03:34.077 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'harmonyhub:device:Wohnzimmer:28148560' has been updated.
21:03:34.188 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'harmonyhub:device:Wohnzimmer:28148559' changed from INITIALIZING to ONLINE
21:03:34.314 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'harmonyhub:device:Wohnzimmer:28148559' has been updated.
21:03:34.336 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'harmonyhub:hub:Wohnzimmer' has been updated.
21:03:34.397 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'harmonyhub:hub:Wohnzimmer' has been updated.
21:03:34.437 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'binding-harmonyhub' has been installed.
Please help.
