I’m having trouble getting the fibaro keyfob working. I’ve got it setup in the initial basic mode. The controller is getting the button press, but it isn’t processing it fully. Any suggestions?
keyfob.rules
rule “KeyFob2”
Item KeyFob1 received update
var swState = KeyFob1.state
var name = “KeyFob2Rule”
logInfo(name, "Update: " + swState)
switch swState {
case 1: {logInfo(name, "Square1xClick")
Light_LivingRoom_Oval.sendCommand(ON)
case 2: {logInfo(name, "Square2xClick")
Light_LivingRoom_Oval.sendCommand(OFF)
keyfob.items
Number KeyFob1 (div, remotes) { channel = “zwave:device:9901e9f5:node11:scene_number” }
Number KeyFobBatt1 (div, remotes) { channel = “zwave:device:9901e9f5:node11:battery-level” }
After a received Update the item’s state doesn’t change immediately. It takes time (5-40ms) depending on your system for the event bus to process the event.
Try changing the rule trigger to changed
rule “KeyFob2”
Item KeyFob1 changed
switch swState {
case 1: {
case 2: {
Since this keyfob, or something like an Aeon Minimote, using a ‘changed’ trigger doesn’t work, since you can send the same button press more than once. This is one of the rare occasions, using DSL rules, where separate rules work better.
This is also one of the areas where the new rule engine with scripted automation (JSR223) shines, since you have access to the update that was received when using a ‘received update’ trigger.
CentralScene gets formatted by the binding as scene.key, which from the following debug statement would be 1.0. I’m not sure if your case 1: will match.
22:03:22.410 [DEBUG] [ndclass.ZWaveCentralSceneCommandClass] - NODE 12: Received scene 1 at key 0 [Single Press]
But, possibly more fundamental, are you seeing any of the LogInfo statements logged in your log file. I’d be especially interested to know if the first log statement (i.e. logInfo(name, "Update: " + swState)) is being logged, as that will indicate whether the rule is being executed.
That’s definitely true for received command but is it for received update? I’ve never encountered a timing problem with that. If it is a problem then we need a receivedUpdate implicit variable too. I routinely code just like OP and haven’t had a problem. It has always behaved such that the Item processes the update before the Rule triggers.
OMG, I did it again… no more late night posts! I think Mark has the root cause… the device uses CENTRAL_SCENE, so the OP needs to modify the states in the switch/case, similar to…
this keyfob drives me absolutely nuts.
I have tried for days now to get it properly included, but it stills stays as an unknown device. the openhab log seems to indicate that it does never wake up …
Now after I do not know how many times of pushing the wake-up buttons, the damn thing always blinks red when I push a button … with one exception … the inclusion mode (3 klicks on any button) still works.
Tail the openhab.log file and watch what happens when you press the button(s) to wake it up. Is there a flurry of log activity, or is it silent? If the latter, then it’s not waking up.
Hell, yeah. I hate those Minimotes. I hope this device doesn’t follow in those same footsteps… LOL
Hmm. It’ll never initialize if it can’t be woken up.
According to the manual… Have you tried both methods to wake it up?
Waking up the device:
The KeyFob needs to be woken up to receive information about the
new configuration from the Z-Wave controller, like parameters and
associations. Use 1st menu position (white) or click o and + simultaneously to wake up the device.
If so, it might be time to exclude, factory reset, and re-include.
OK… This seems to be working in single click mode.
rule “KeyFob2”
var swState = KeyFob1.state as Number
logInfo(name, "Update: " + swState.toString)
switch swState {
Now to try to reconfigure the keyfob for multiple clicks.
Hmm. Ok - I reconfigure to add single click, double click and click/hold, in paper UI then ‘wake up’ the keyfob. I see the log entries for this happening.
Once done I then don’t get any lights when I press buttons, and I don’t get anything triggered in the log.
I’m going to try the reset cycle to get it back to single press mode.
I can report some progress … but still not where I want to be.
After numerous wake-ups, I got the device recognized by the controller with correct name etc. … but … the inclusion did not use security successfully. the device is marked as not using security.
I have “Security on” for all devices on the controller, and have had successful secure inclusion with switches and the likes already.
What do I need to do, to get the Fibaro Keyfob recognized as a secure device?
And specifically, what exactly do I need to do, now that the device is already included in non-secure mode?
