Is /usr/local/lib/python3.5/dist-packages/cec a folder or the acutal executable? The executable shoud be named cec-client, not just cec. On my RPI the executable is here: /usr/local/bin/cec-client
Also check if the chmod of the file allows group users to execute the file.
ah, I assumed it was a folder because there was no mention of a file extension…
I can see the cec-client in the same folder as yours, however I now have 2 there because I built the new 3.5 version, while still having 2.7, I’ll need to purge it I guess… apparently I don’t make things easy on myself
I updated the settings, however it’s stuck on initializing… probably because there are 2 cec-client files in that destination?
I also have two files cecc-client-4.0.2 and cecc-client which points at the cecc-client-4.0.2 file. You can test if the cec port works if you just run “cec-client RPI”. If that works without problems you can enable the trace log for my addon to see whats the problem.
After adding the changes to the file (/var/lib/openhab2/etc/org.ops4j.pax.logging.cfg), I am not getting any seperate hdmi cec log file in /var/log/openhab2?
I’ve had some time today and tried this myself and had the same problems as you. (Except the logging, that worked perfectly on my installation) As it turns out the messages from the cec-client are slightly different on the Raspberry hdmi port.
I’m still getting “Communication Error - Process Ended” in paperUI, however I don’t get any errors when restarting openHab, infact there is no reference to HDMI CEC loading on restart, despite the bundle showing as active.
“Process Ended” means that the cec-client process ended. This means something during the initialization went wrong. If you can run the cec-client without problems as root this has to mean that the openhab user still doesn’t have the rights to access the hdmi hardware.
Sadly I don’t remember exactly which rights I had to give to run this on my installation, but my openhab user has the “video” group assigned. If I remember correctly this group was also necessary to access the hdmi device. If this doesn’t work, please also try to add the “dialout” and “tty” groups to the openhab user. And you will have to restart Openhab completely to receive the rights from the groups.
In this case I have no more ideas without the trace log of the addon. And I also don’t have an idea why the log isn’t working on your installation. When I tested this I immediateley got entries in the log when the addon started. There should be at least an “initialize client:” log message at startup.
