koboldmaki
(Sven Pithan)
February 1, 2020, 12:34pm
1
Hello everyone, I need your help. I have been using openHAB for several years and version ~ 2.1. The integration of switches, dimmers, shutters, simple rules is no problem.
Now I wanted to integrate my underfloor heating that is controlled with KNX. Unfortunately I can’t manage this and have tried a lot with googling and trying. I would be very grateful if you could help me, gladly with example items and things files.
I use MDT AKH-0400.01 heating actuators.
Here is a screenshot from ETS
things file
/* Heating */
Thing device AKH040001_KG "MDT AKH-0400.01 Kellergeschoss" @ "KNX" [ fetch=false, pingInterval=600, readInterval=0 ]
Type number : Ch_A_Technik_tempIs "Temperatur ist" [ ga="<2/1/0" ]
Type number : Ch_A_Technik_tempSet "Temperatur soll" [ ga="2/1/1+<2/1/4" ]
Type number : Ch_A_Technik_opMode "Betriebsart ist" [ ga="<2/1/7" ]
Type number : Ch_A_Technik_opSet "Betriebsart soll" [ ga="2/1/6" ]
items file
/* AKH040001_KG */
Number Ch_A_Technik_tempIs "tempIs Technik [%.1f °C]" (gC_Technik) { channel="knx:device:MDTSCNIP:AKH040001_KG:Ch_A_Technik_tempIs" }
Number Ch_A_Technik_tempSet "tempSet Technik [%.1f °C]" (gC_Technik) { channel="knx:device:MDTSCNIP:AKH040001_KG:Ch_A_Technik_tempSet" }
Number Ch_A_Technik_opMode "opMode Technik" (gC_Technik) { channel="knx:device:MDTSCNIP:AKH040001_KG:Ch_A_Technik_opMode" }
Number Ch_A_Technik_opSet "opSet Technik" (gC_Technik) { channel="knx:device:MDTSCNIP:AKH040001_KG:Ch_A_Technik_opSet" }
thank you in advance
crystollic
(Crystollic)
February 2, 2020, 10:47am
2
Maybe match GA types. I specify the dpt type for each ga to be sure.
koboldmaki
(Sven Pithan)
February 2, 2020, 5:44pm
3
Hi crystollic,
thanks for your quick answer. Is it possible to send me your items and things file so that i can use it as an example?
crystollic
(Crystollic)
February 2, 2020, 8:04pm
4
It would be something like this:
/* Heating */
Type number : Ch_A_Technik_tempIs "Temperatur ist" [ ga="9.001:<2/1/0" ]
Type number : Ch_A_Technik_tempSet "Temperatur soll" [ ga="9.001:2/1/1+<2/1/4" ]
ETS will show you the full list of datapoint types.
Hope that helps.
chrode
(pmc)
February 3, 2020, 9:10am
5
I am not an expert and most of the time I am in fighting mode with my knx set up as well,
but when I have a look atyour ETS settings and at your things it looks kind of strange to me:
GA 2/1/1 and 2/1/4 end up in the same thing
even though they have different data types
crystollic
(Crystollic)
February 3, 2020, 10:06am
6
Sorry, I missed the ets screen shot…
2/1/0 looks to be the actual temperature which should ga=“9.001:<2/1/0”
2/1/1 looks as if it is the PWM percentage for actuator this would be ga=“5.001:2/1/1”
2/1/4 is either your temp setpoint or delta and this would be ga=“9.001:<2/1/4”
You are right in that they have to be the same type.
koboldmaki
(Sven Pithan)
February 11, 2020, 8:17pm
7
My ITEM File
/* AKH-0800.01_EG */
Number Ch_A_Wohnraum1_tempIs "Wohnraum1 Istwert [%.1f °C]" <tempis> (GF_Heizung) { channel="knx:device:MDTSCNIP:AKH080001_EG:Ch_A_Wohnraum1_tempIs" }
Number Ch_A_Wohnraum1_tempSet "Wohnraum1 Setzwert [%.1f °C]" <tempset> (GF_Heizung) { channel="knx:device:MDTSCNIP:AKH080001_EG:Ch_A_Wohnraum1_tempSet" }
Number Ch_B_Wohnraum2_tempIs "Wohnraum2 Istwert [%.1f °C]" <ventil> (GF_Heizung) { channel="knx:device:MDTSCNIP:AKH080001_EG:Ch_B_Wohnraum2_tempIs" }
Number Ch_B_Wohnraum2_tempSet "Wohnraum2 Setzwert [%.1f °C]" <tempis> (GF_Heizung) { channel="knx:device:MDTSCNIP:AKH080001_EG:Ch_B_Wohnraum2_tempSet" }
Number Ch_C_Essbereich1_tempIs "Essbereich1 Istwert [%.1f °C]" <tempset> (GF_Heizung) { channel="knx:device:MDTSCNIP:AKH080001_EG:Ch_C_Essbereich1_tempIs" }
Number Ch_C_Essbereich1_tempSet "Essbereich1 Setzwert [%.1f °C]" <ventil> (GF_Heizung) { channel="knx:device:MDTSCNIP:AKH080001_EG:Ch_C_Essbereich1_tempSet" }
Number Ch_D_Essbereich2_tempIs "Essbereich2 Istwert [%.1f °C]" <tempis> (GF_Heizung) { channel="knx:device:MDTSCNIP:AKH080001_EG:Ch_D_Essbereich2_tempIs" }
Number Ch_D_Essbereich2_tempSet "Essbereich2 Setzwert [%.1f °C]" <tempset> (GF_Heizung) { channel="knx:device:MDTSCNIP:AKH080001_EG:Ch_D_Essbereich2_tempSet" }
Number Ch_E_Kueche_tempIs "Küche Istwert [%.1f °C]" <ventil> (GF_Heizung) { channel="knx:device:MDTSCNIP:AKH080001_EG:Ch_E_Kueche_tempIs" }
Number Ch_E_Kueche_tempSet "Küche Setzwert [%.1f °C]" <tempis> (GF_Heizung) { channel="knx:device:MDTSCNIP:AKH080001_EG:Ch_E_Kueche_tempSet" }
Number Ch_F_FlurEG_tempIs "Flur-EG Istwert [%.1f °C]" <tempset> (GF_Heizung) { channel="knx:device:MDTSCNIP:AKH080001_EG:Ch_F_FlurEG_tempIs" }
Number Ch_F_FlurEG_tempSet "Flur-EG Setzwert [%.1f °C]" <ventil> (GF_Heizung) { channel="knx:device:MDTSCNIP:AKH080001_EG:Ch_F_FlurEG_tempSet" }
Number Ch_F_WC_tempIs "WC Istwert [%.1f °C]" <tempis> (GF_Heizung) { channel="knx:device:MDTSCNIP:AKH080001_EG:Ch_F_WC_tempIs" }
Number Ch_F_WC_tempSet "WC Setzwert [%.1f °C]" <tempset> (GF_Heizung) { channel="knx:device:MDTSCNIP:AKH080001_EG:Ch_F_WC_tempSet" }
My THING File
/* Heating AKH 0800.01_EG */
Thing device AKH080001_EG "MDT AKH-0800.01 Erdgeschoss" @ "KNX" [ fetch=false, pingInterval=600, readInterval=0 ]
Type number : Ch_A_Wohnraum1_tempIs "Wohnraum1 Istwert [%.1f °C]" [ ga="<2/2/5" ]
Type number : Ch_A_Wohnraum1_tempSet "Wohnraum1 Setzwert [%.1f °C]" [ ga="2/2/3+<2/2/5" ]
Type number : Ch_B_Wohnraum2_tempIs "Wohnraum2 Istwert [%.1f °C]" [ ga="<2/2/25" ]
Type number : Ch_B_Wohnraum2_tempSet "Wohnraum2 Setzwert [%.1f °C]" [ ga="2/2/23+<2/2/25" ]
Type number : Ch_C_Essbereich1_tempIs "Essbereich1 Istwert [%.1f °C]" [ ga="<2/2/45" ]
Type number : Ch_C_Essbereich1_tempSet "Essbereich1 Setzwert [%.1f °C]" [ ga="2/2/43+<2/2/45" ]
Type number : Ch_D_Essbereich2_tempIs "Essbereich2 Istwert [%.1f °C]" [ ga="<2/2/65" ]
Type number : Ch_D_Essbereich2_tempSet "Essbereich2 Setzwert [%.1f °C]" [ ga="2/2/63+<2/2/65" ]
Type number : Ch_E_Kueche_tempIs "Küche Istwert [%.1f °C]" [ ga="<2/2/85" ]
Type number : Ch_E_Kueche_tempSet "Küche Setzwert [%.1f °C]" [ ga="2/2/83+<2/1/85" ]
Type number : Ch_F_FlurEG_tempIs "Flur-EG Istwert [%.1f °C]" [ ga="<2/2/105" ]
Type number : Ch_F_FlurEG_tempSet "Flur-EG Setzwert [%.1f °C]" [ ga="2/2/103+<2/1/105" ]
Type number : Ch_F_WC_tempIs "WC Istwert [%.1f °C]" [ ga="<2/2/125" ]
Type number : Ch_F_WC_tempSet "WC Setzwert [%.1f °C]" [ ga="2/2/123+<2/1/125" ]
It Works, but temp setpoint or delta and PWM percentage for actuator doesn’t work. I tried it with ga=“5.001: and ga=“9.001: but I get no information. It is not important for me. I can change the temperature that’s enough
@oelles here is my sitemap
Changing the heating mode is possible with switches, but it is bad to use.
I want to switch the heating operation modes with a mapping switch [Komfort | Nacht | Frost ] so that I can set the mode very easy an it looks good
.```csv
sitemap SmartHome label=“SmartHome 2.0”
Frame label=“Status” {
Group item=Klima label=“Hausklima” icon=“klima”
Text label="Heizung" icon="floorheating" {
Text label="Obergeschoss" icon="firstfloor" {
Default item=Ch_D_Eltern_Temperatur
Setpoint item=Ch_A_Eltern_tempSet label="Eltern (±0.5) [%.1f °C]" minValue=4.5 maxValue=30 step=0.5 icon="tempset"
Default item=Ch_A_Eltern_tempIs
Default item=Ch_C_Kind2_Temperatur
Setpoint item=Ch_B_Kind2_tempSet label="Kind2 (±0.5) [%.1f °C]" minValue=4.5 maxValue=30 step=0.5 icon="tempset"
Default item=Ch_B_Kind2_tempIs
Default item=Ch_B_Kind1_Temperatur
Setpoint item=Ch_C_Kind1_tempSet label="Kind1 (±0.5) [%.1f °C]" minValue=4.5 maxValue=30 step=0.5 icon="tempset"
Default item=Ch_C_Kind1_tempIs
Default item=Ch_A_Badezimmer_Temperatur
Setpoint item=Ch_D_Bad_tempSet label="Bad (±0.5) [%.1f °C]" minValue=4.5 maxValue=30 step=0.5 icon="tempset"
Default item=Ch_D_Bad_tempIs
Text label="Erdgeschoss" icon="groundfloor" {
Default item=Ch_C_Wohnraum_Temperatur
Setpoint item=Ch_A_Wohnraum1_tempSet label="Wohnraum1 (±0.5) [%.1f °C]" minValue=4.5 maxValue=30 step=0.5 icon="tempset"
Default item=Ch_A_Wohnraum1_tempIs
Setpoint item=Ch_B_Wohnraum2_tempSet label="Wohnraum2 (±0.5) [%.1f °C]" minValue=4.5 maxValue=30 step=0.5 icon="tempset"
Default item=Ch_B_Wohnraum2_tempIs
Setpoint item=Ch_C_Essbereich1_tempSet label="Essbereich1 (±0.5) [%.1f °C]" minValue=4.5 maxValue=30 step=0.5 icon="tempset"
Default item=Ch_C_Essbereich1_tempIs
Setpoint item=Ch_D_Essbereich2_tempSet label="Essbereich2 (±0.5) [%.1f °C]" minValue=4.5 maxValue=30 step=0.5 icon="tempset"
Default item=Ch_D_Essbereich2_tempIs
Setpoint item=Ch_E_Kueche_tempSet label="Küche (±0.5) [%.1f °C]" minValue=4.5 maxValue=30 step=0.5 icon="tempset"
Default item=Ch_E_Kueche_tempIs
Default item=Ch_B_FlurEG_Temperatur
Setpoint item=Ch_F_FlurEG_tempSet label="Flur-EG (±0.5) [%.1f °C]" minValue=4.5 maxValue=30 step=0.5 icon="tempset"
Default item=Ch_F_FlurEG_tempIs
Default item=Ch_A_WC_Temperatur
Setpoint item=Ch_F_WC_tempSet label="WC (±0.5) [%.1f °C]" minValue=4.5 maxValue=30 step=0.5 icon="tempset"
Default item=Ch_F_WC_tempIs
Text label="Kellergeschoss" icon="cellar" {
Default item=Ch_A_Buero_Temperatur
Setpoint item=Ch_A_Buero_tempSet label="Büro (±0.5) [%.1f °C]" minValue=4.5 maxValue=30 step=0.5 icon="tempset"
Default item=Ch_A_Buero_tempIs
Default item=Ch_B_FlurUG_Temperatur
Setpoint item=Ch_B_FlurUG_tempSet label="Flur-UG (±0.5) [%.1f °C]" minValue=4.5 maxValue=30 step=0.5 icon="tempset"
Default item=Ch_B_FlurUG_tempIs
Default item=Ch_C_Technik_Temperatur
Setpoint item=Ch_C_Technik_tempSet label="Technik (±0.5) [%.1f °C]" minValue=4.5 maxValue=30 step=0.5 icon="tempset"
Default item=Ch_C_Technik_tempIs
