A UI for a heating system showing temperatures, electric heater status and pump status.
Screenshots
Resources
uid: heating_system
tags: []
props:
parameters:
- context: item
label: Heater temperature
required: false
type: TEXT
- context: item
label: Heater in temperature
required: false
type: TEXT
- context: item
label: Heating out temperature
required: false
type: TEXT
- context: item
label: Heating pump switch
required: false
type: TEXT
- context: item
label: Water temperature
required: false
type: TEXT
- context: item
label: Water in temperature
required: false
type: TEXT
- context: item
label: Water out temperature
required: false
type: TEXT
- context: item
label: Water heater switch
required: false
type: TEXT
- context: item
label: Water heater pump switch
required: false
type: TEXT
timestamp: Jan 4, 2025, 3:07:53 PM
component: f7-card
title: Heating System
slots:
default:
- component: f7-card-content
style:
height: 175px
slots:
default:
- component: f7-row
class:
- display-flex
- justify-content-center
- align-items-center
style:
width: 100%
slots:
default:
- component: f7-col
class:
- display-flex
- flex-direction-column
style:
height: 100%
width: 50px
slots:
default:
- component: Label
text: '=items[props.heatingInTemp].displayState == "" ?
items[props.heatingInTemp].state :
items[props.heatingInTemp].displayState'
- component: f7-block
slots:
default:
- component: f7-col
slots:
default:
- component: f7-col
slots:
default:
- component: f7-row
tag: svg
viewBox: 0 0 50 110
width: 50px
xmlns: http://www.w3.org/2000/svg
slots:
default:
- component: f7-row
d: M5 12 l20 0
stroke: rgb(230,74,25)
stroke-width: 5
tag: path
stroke-linecap: round
- component: f7-row
d: M25 12 l20 0
stroke-width: 5
tag: path
- component: f7-row
d: M5 30 l20 0
fill: none
stroke: rgb(33, 150, 243)
stroke-width: 5
tag: path
- component: f7-row
d: M25 30 l0 75
stroke-width: 5
tag: path
- component: f7-row
d: M25 105 l20 0
fill: none
stroke-width: 5
tag: path
- component: f7-row
fill: lightgray
r: 10
cx: 25
cy: 12
stroke-width: 2
tag: circle
- component: f7-row
d: M19 6 l12 12
fill: none
stroke-width: 2
tag: path
- component: f7-row
d: M19 18 l12 -12
fill: none
stroke-width: 2
tag: path
- component: f7-row
dur: 1
begin: 0
to: 360 25 12
repeatCount: indefinite
tag: animateTransform
type: rotate
attributeName: transform
attributeType: XML
xlink:href: '=(items[props.heatingPump].state === "ON") ? "#heatingPump1" :
"#heatingPump1_disable"'
- component: f7-row
dur: 1
begin: 0
to: 360 25 12
type: rotate
attributeType: XML
xlink:href: '=(items[props.heatingPump].state === "ON") ? "#heatingPump2" :
"#heatingPump2_disable"'
- component: Label
text: =items[props.heatingOutTemp].state
- component: f7-col
class:
- display-flex
- justify-content-space-evenly
style:
height: 100%
width: 90px
slots:
default:
- component: f7-col
class:
- display-flex
style:
background: lightgray
border: 2pt solid rgb(230,74,25)
border-radius: 5px 5px 5px 5px
height: 150px
width: 90px
slots:
default:
class:
- display-flex
- justify-content-flex-end
- flex-shrink-0
- no-margin
slots:
default:
- component: Label
style:
font-weight: bold
color: black
padding-top: 10px
padding-bottom: 20px
white-space: nowrap
text: '=items[props.heaterTemp].displayState == "" ?
items[props.heaterTemp].state :
items[props.heaterTemp].displayState'
class:
- display-flex
style:
border: '=(Number.parseFloat(items[props.heaterTemp].state) > 30) ? "4pt solid
rgb(230,74,25)" : "4pt solid darkgray"'
box-shadow: 0 0 10px 2px darkgray inset
height: 70px
margin-top: 7px
width: 70px
slots:
default:
- component: f7-icon
f7: flame_fill
style:
color: '=(Number.parseFloat(items[props.heaterTemp].state) > 30) ?
"rgb(230,74,25)" : "darkgray"'
- component: f7-col
class:
- display-flex
style:
height: 100%
width: 50px
slots:
default:
- component: f7-col
- component: Label
text: '=items[props.waterInTemp].displayState == "" ?
items[props.waterInTemp].state :
items[props.waterInTemp].displayState'
padding-bootom: 20px
slots:
default:
- component: f7-col
slots:
default:
- component: f7-row
tag: svg
viewBox: 0 0 50 110
width: 50px
slots:
default:
- component: f7-row
d: M5 11 l40 0
fill: none
stroke-width: 5
tag: path
vector-effect: non-scaling-stroke
- component: f7-row
fill: lightgray
r: 10
cx: 25
cy: 12
stroke-width: 2
tag: circle
- component: f7-row
d: M19 6 l12 12
fill: none
stroke-width: 2
tag: path
- component: f7-row
d: M19 18 l12 -12
fill: none
stroke-width: 2
tag: path
- component: f7-row
dur: 1
begin: 0
to: 360 25 12
type: rotate
attributeType: XML
xlink:href: '=items[props.waterHeaterPump].state === "ON" ? "#waterHeaterPump1"
: "#waterHeaterPump1_disable"'
- component: f7-row
dur: 1
begin: 0
to: 360 25 12
type: rotate
attributeType: XML
xlink:href: '=items[props.waterHeaterPump].state === "ON" ? "#waterHeaterPump2"
: "#waterHeaterPump2_disable"'
- component: f7-row
d: M5 105 l40 0
fill: none
stroke-width: 5
tag: path
- component: Label
text: '=items[props.waterOutTemp].displayState == "" ?
items[props.waterOutTemp].state :
items[props.waterOutTemp].displayState'
- component: f7-col
class:
- display-flex
style:
height: 100%
width: 60px
slots:
default:
- component: f7-col
class:
- display-flex
style:
border: 2pt solid rgb(33, 150, 243)
height: 150px
width: 60px
slots:
default:
class:
- display-flex
- flex-shrink-0
- no-margin
slots:
default:
- component: Label
style:
font-weight: bold
color: black
padding-top: 10px
padding-bottom: 10px
white-space: nowrap
text: '=items[props.waterTemp].displayState == "" ? items[props.waterTemp].state
: items[props.waterTemp].displayState'
class:
- display-flex
style:
height: 80px
margin-top: 7px
width: 70px
slots:
default:
- component: f7-col
slots:
default:
f7: '=(items[props.waterHeater].state === "ON") ? "bolt_circle_fill" :
"drop_fill"'
style:
color: '=(Number.parseFloat(items[props.waterTemp].state) > 40) ?
"rgb(230,74,25)" : "rgb(33, 150,
243)"'
f7: '=(items[props.waterHeater].state == "ON") ? "bolt_circle_fill" :
"bolt_slash"'
style:
color: '=(items[props.waterHeater].state === "ON") ? "rgb(33, 150, 243)" :
"darkgray"'
