Heatit Z-Water strange behavior
Hi experts,
I have a question regarding the HeatIT Z-Water Z-Wave device (home).
Manufacturer: 019B (ThermoFloor)
Type/ID: 0003:020A
Firmware version: 2.1
OpenHAB version: 2.5.4
The device was recognized by OH2, it was also added. It has 1+10 switch channels:
zwave:device:xxxxxxxxx:node18:switch_binary
zwave:device:xxxxxxxxx:node18:switch_binary1
zwave:device:xxxxxxxxx:node18:switch_binary2
zwave:device:xxxxxxxxx:node18:switch_binary10
The device has 10 relays, so I suppose each channel with the sequence number should be assigned to one relay. Channel without sequence number (switch_binary) should be the main switch which turns ON/OFF all other channels.
But what really happens is: the relays are not switched when I turn ON/OFF the switch_binary1-10. Strange is that the switch_binary turns ON/OFF the first relay on the device and also the switch_binary1 in the OH2. Maybe it’s not controlling directly the switch_binary1, but it turns OFF all relays and also restoring the previous state of the relays when I turn it ON.
Do you have any idea?
Thank you for your help!
Laci
Here is our database entry along with a copy f the manual.
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/886
I’m sorry, but I don’t understand. What should I do? Should I import somehow the configuration file into OH2?
The configuration should be already part of the binding. I thought the documentation & other settings might provide additional guidance until additional help arrives.
OK, thank you. I’ve seen the documentation, but nothing useful there. :cry:
Does anybody own this device?
Somebody must have in order for OH to have the data.
I’ve enabled z-wave debug logging. When I switch ON/OFF the 10th switch I get these messages:
2020-05-28 00:02:24.462 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 18: Command received zwave:device:8b76ba85:node18:switch_binary10 → ON [OnOffType]
2020-05-28 00:02:24.462 [DEBUG] [wave.internal.converter.ZWaveBinarySwitchConverter] - NODE 18: Command class class COMMAND_CLASS_SWITCH_BINARY for endpoint 10 not found
2020-05-28 00:02:24.464 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 18: No messages returned from converter
2020-05-28 00:02:25.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 18: Command received zwave:device:8b76ba85:node18:switch_binary10 → OFF [OnOffType]
2020-05-28 00:02:25.793 [DEBUG] [wave.internal.converter.ZWaveBinarySwitchConverter] - NODE 18: Command class class COMMAND_CLASS_SWITCH_BINARY for endpoint 10 not found
2020-05-28 00:02:25.793 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 18: No messages returned from converter
Is this information useful?
Thanks!
Laci
If you are running a common Linux install in /var/lib/openhab2/zwave there should be an xml file for that node. Posting it here could be helpful.
@chris our main developer ii in the UK so he may not respond this evening.
Sure, here is the XML file:
network_d9cd18a8__node_18.xml (43.1 KB)
Thank you!
I am trying to learn how to interpret the xml file but it looks to me like the other Endpoints before it. We will need to wait for Chris, I am afraid.
OK, thank you very much!
Hello friends! I’ve found and solved the problem. I’ve compared 2 xml config files (from a different node) and I realized that the COMMAND_CLASS_SWITCH_BINARY command class node is missing for binary_switch1-10. I’ve created that node and it started to work. I suppose this configuration file was generated based on definition file “/src/main/resources/ESH-INF/thing/thermofloor/zwater_0_0.xml”, so we should update the definition file instead of changing configuration.
I can’t see any problem in definition file, so maybe some bug in binding during configuration file generation?
The fixed configuration file:
network_d9cd18a8__node_18.xml (47.9 KB)
That xml file is generated from our database. did you try deleting (NOT excluding) and re-adding the node to get the latest binding settings?
What version are you running? That device was last updated 8 months ago and I see the channel defined for Endpoint 10.
Hi Bruce. I’ve deleted the device, stopped the Z-Wave binding, deleted the XML file and then re-added, but same result. Missing COMMAND_CLASS_SWITCH_BINARY.
OH2 was yesterday updated to version 2.5.5 (before update 2.5.4). The z-wave has the same version.
The xml file updated 3 months ago on Github looks OK to me. Do you see anything missing?
EDIT: There were no changes 3 months ago.
Where is this file in linux filesystem?
It is built into the binding jar file.
I have the same version here:
/var/lib/openhab2/tmp/kar/openhab-addons-2.5.5/org/openhab/addons/bundles/org.openhab.binding.zwave/2.5.5/org.openhab.binding.zwave-2.5.5.jar/ESH-INF/thing/thermofloor/zwater_0_0.xml
Hi! Any news? When I reinitialize the device the XML file is probably recreated, so after this action the switches are not working anymore. I have to manually fix the XML file.
