Still using OH1 but have the latest snapshot of the zwave binding, and i’ve added the XML for the smoke detector from the database to the jar as I have with other devices.
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/530?layout=openhab1
Looks like initialization/node advancer gets stuck on MANUFACTURER_SPECIFIC_GET. Can upload full logs elsewhere if that helps, below is just some bits that may help. I’ve excluded and re-included the device many times, and after including have sat pressing the wakeup button over and over to try and get it to finish initialization. It has managed twice in maybe 30 attempts to get past MANUFACTURER, but the first time I’d not added the device XML to the database so it was unrecognised, and the second time something else went wrong and the initialization still didn’t complete.
Any help appreciated!
2018-06-13 23:07:19.518 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1162]- NODE 72: Wakeup during initialisation.
2018-06-13 23:07:19.519 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:277 ]- NODE 72: Node advancer - SECURITY_REPORT: queue length(1), free to send(false)
2018-06-13 23:07:19.519 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:342 ]- NODE 72: Node advancer: loop - SECURITY_REPORT try 1: stageAdvanced(false)
2018-06-13 23:07:19.519 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:509 ]- NODE 72: does not support SECURITY_REPORT, proceeding to next stage.
2018-06-13 23:07:19.519 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:994 ]- NODE 72: Node advancer - advancing to DETAILS
2018-06-13 23:07:19.519 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:342 ]- NODE 72: Node advancer: loop - DETAILS try 0: stageAdvanced(true)
2018-06-13 23:07:19.519 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:525 ]- NODE 72: Node advancer: received RequestNodeInfo
2018-06-13 23:07:19.519 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:994 ]- NODE 72: Node advancer - advancing to MANUFACTURER
2018-06-13 23:07:19.519 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:342 ]- NODE 72: Node advancer: loop - MANUFACTURER try 0: stageAdvanced(true)
2018-06-13 23:07:19.519 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:547 ]- NODE 72: Node advancer: MANUFACTURER - send ManufacturerSpecific
2018-06-13 23:07:19.519 [DEBUG] [nufacturerSpecificCommandClass:105 ]- NODE 72: Creating new message for command MANUFACTURER_SPECIFIC_GET
2018-06-13 23:07:19.519 [DEBUG] [o.b.z.i.protocol.SerialMessage:115 ]- NODE 72: Creating empty message of class = SendData (0x13), type = Request (0x00)
2018-06-13 23:07:19.519 [DEBUG] [b.z.i.protocol.ZWaveController:976 ]- Callback ID = 118
2018-06-13 23:07:19.519 [DEBUG] [b.z.i.protocol.ZWaveController:651 ]- Enqueueing message. Queue length = 29
2018-06-13 23:07:19.519 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:250 ]- NODE 72: Node advancer - queued packet. Queue length is 1
2018-06-13 23:07:20.519 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:544 ]- NODE 72: No more messages, go back to sleep
2018-06-13 23:07:20.519 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:218 ]- NODE 72: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2018-06-13 23:07:20.519 [DEBUG] [o.b.z.i.protocol.SerialMessage:115 ]- NODE 72: Creating empty message of class = SendData (0x13), type = Request (0x00)
2018-06-13 23:07:23.102 [DEBUG] [WaveController$ZWaveSendThread:1355]- NODE 72: Sending REQUEST Message = 01 09 00 13 48 02 84 08 25 74 72
2018-06-13 23:07:24.650 [DEBUG] [b.z.i.p.s.SendDataMessageClass:39 ]- NODE 72: Sent Data successfully placed on stack.
2018-06-13 23:07:25.182 [DEBUG] [ApplicationCommandMessageClass:122 ]- NODE 72: Transaction not completed: node address inconsistent. lastSent=72, incoming=255
2018-06-13 23:07:25.203 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ]- NODE 72: SendData Request. CallBack ID = 116, Status = Transmission complete, no ACK received(1)
2018-06-13 23:07:25.203 [DEBUG] [b.z.i.p.s.SendDataMessageClass:109 ]- NODE 72: WAKE_UP_NO_MORE_INFORMATION. Treated as ACK.
2018-06-13 23:07:25.203 [DEBUG] [b.z.i.protocol.ZWaveController:668 ]- NODE 72: Notifying event listeners: ZWaveTransactionCompletedEvent
2018-06-13 23:07:25.203 [DEBUG] [.z.internal.ZWaveActiveBinding:455 ]- ZwaveIncomingEvent
2018-06-13 23:07:25.203 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1138]- NODE 72: Node advancer - MANUFACTURER: Transaction complete (SendData:Request) success(true)
2018-06-13 23:07:25.203 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:208 ]- NODE 72: Node advancer - checking initialisation queue. Queue size 1.
2018-06-13 23:07:25.203 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:409 ]- NODE 72: Went to sleep
2018-06-13 23:07:25.203 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:472 ]- NODE 72: Is sleeping
2018-06-13 23:07:25.203 [DEBUG] [WaveController$ZWaveSendThread:1430]- NODE 72: Response processed for callback id 116 after 2101ms/4565ms.
2018-06-13 23:07:25.204 [DEBUG] [WaveController$ZWaveSendThread:1295]- Took message from queue for sending. Queue length = 29
2018-06-13 23:07:25.204 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:260 ]- NODE 72: Putting message SendData in wakeup queue.
2018-06-13 23:07:29.322 [DEBUG] [.z.internal.ZWaveActiveBinding:455 ]- ZwaveIncomingEvent
2018-06-13 23:07:29.322 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1186]- NODE 72: 6 NIF event during initialisation stage WAIT
2018-06-13 23:07:29.323 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1186]- NODE 72: 71 NIF event during initialisation stage MANUFACTURER
2018-06-13 23:07:29.323 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1186]- NODE 72: 41 NIF event during initialisation stage WAIT
2018-06-13 23:07:29.323 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1186]- NODE 72: 38 NIF event during initialisation stage WAIT
2018-06-13 23:07:29.323 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1186]- NODE 72: 2 NIF event during initialisation stage DYNAMIC_VALUES
2018-06-13 23:07:29.323 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1186]- NODE 72: 72 NIF event during initialisation stage MANUFACTURER
2018-06-13 23:07:29.323 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1196]- NODE 72: NIF event during initialisation stage MANUFACTURER
2018-06-13 23:07:29.323 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:277 ]- NODE 72: Node advancer - MANUFACTURER: queue length(1), free to send(false)
2018-06-13 23:07:29.323 [DEBUG] [b.z.i.protocol.ZWaveController:976 ]- Callback ID = 120
2018-06-13 23:07:29.323 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:260 ]- NODE 72: Putting message SendData in wakeup queue.
2018-06-13 23:07:29.323 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:250 ]- NODE 72: Node advancer - queued packet. Queue length is 1
2018-06-13 23:07:29.323 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:449 ]- NODE 72: Is awake with 2 messages in the wake-up queue.
2018-06-13 23:07:29.323 [DEBUG] [b.z.i.protocol.ZWaveController:668 ]- NODE 72: Notifying event listeners: ZWaveWakeUpEvent
2018-06-13 23:07:29.323 [DEBUG] [.z.internal.ZWaveActiveBinding:455 ]- ZwaveIncomingEvent
2018-06-13 23:07:29.323 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1162]- NODE 72: Wakeup during initialisation.
2018-06-13 23:07:29.324 [DEBUG] [b.z.i.protocol.ZWaveController:976 ]- Callback ID = 121
2018-06-13 23:07:29.324 [DEBUG] [b.z.i.protocol.ZWaveController:651 ]- Enqueueing message. Queue length = 27
2018-06-13 23:07:29.324 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:250 ]- NODE 72: Node advancer - queued packet. Queue length is 1
2018-06-13 23:07:39.299 [DEBUG] [.ApplicationUpdateMessageClass:49 ]- NODE 72: Application update request. Node information received.
2018-06-13 23:07:39.299 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:238 ]- NODE 72: Unsupported command class ZWAVE_PLUS_INFO
2018-06-13 23:07:39.299 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:238 ]- NODE 72: Unsupported command class ASSOCIATION_GROUP_INFO
2018-06-13 23:07:39.299 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:238 ]- NODE 72: Unsupported command class DEVICE_RESET_LOCALLY
2018-06-13 23:07:39.299 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:238 ]- NODE 72: Unsupported command class POWERLEVEL
2018-06-13 23:07:39.299 [DEBUG] [b.z.i.protocol.ZWaveController:668 ]- NODE 72: Notifying event listeners: ZWaveNodeInfoEvent
2018-06-13 23:07:39.299 [DEBUG] [.z.internal.ZWaveActiveBinding:455 ]- ZwaveIncomingEvent
2018-06-13 23:07:39.299 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1186]- NODE 72: 6 NIF event during initialisation stage WAIT
2018-06-13 23:07:39.299 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1186]- NODE 72: 71 NIF event during initialisation stage MANUFACTURER
2018-06-13 23:07:39.299 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1186]- NODE 72: 41 NIF event during initialisation stage WAIT
2018-06-13 23:07:39.299 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1186]- NODE 72: 38 NIF event during initialisation stage WAIT
2018-06-13 23:07:39.299 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1186]- NODE 72: 2 NIF event during initialisation stage DYNAMIC_VALUES
2018-06-13 23:07:39.300 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1186]- NODE 72: 71 NIF event during initialisation stage MANUFACTURER
2018-06-13 23:07:39.300 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1186]- NODE 72: 72 NIF event during initialisation stage MANUFACTURER
2018-06-13 23:07:39.300 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1196]- NODE 72: NIF event during initialisation stage MANUFACTURER
2018-06-13 23:07:39.300 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:277 ]- NODE 72: Node advancer - MANUFACTURER: queue length(1), free to send(false)
2018-06-13 23:07:39.300 [DEBUG] [b.z.i.protocol.ZWaveController:976 ]- Callback ID = 130
2018-06-13 23:07:39.300 [DEBUG] [b.z.i.protocol.ZWaveController:651 ]- Enqueueing message. Queue length = 34
2018-06-13 23:07:39.300 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:250 ]- NODE 72: Node advancer - queued packet. Queue length is 1
2018-06-13 23:07:39.300 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:449 ]- NODE 72: Is awake with 1 messages in the wake-up queue.
2018-06-13 23:07:39.300 [DEBUG] [b.z.i.protocol.ZWaveController:668 ]- NODE 72: Notifying event listeners: ZWaveWakeUpEvent
2018-06-13 23:07:39.300 [DEBUG] [.z.internal.ZWaveActiveBinding:455 ]- ZwaveIncomingEvent
2018-06-13 23:07:39.300 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1162]- NODE 72: Wakeup during initialisation.
2018-06-13 23:07:39.300 [DEBUG] [b.z.i.protocol.ZWaveController:976 ]- Callback ID = 131
2018-06-13 23:07:39.300 [DEBUG] [b.z.i.protocol.ZWaveController:651 ]- Enqueueing message. Queue length = 35
2018-06-13 23:07:49.200 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ]- NODE 72: SendData Request. CallBack ID = 132, Status = Transmission complete, no ACK received(1)
2018-06-13 23:07:49.200 [ERROR] [b.z.i.p.s.SendDataMessageClass:142 ]- NODE 72: Node is DEAD. Dropping message.
2018-06-13 23:07:49.200 [DEBUG] [b.z.i.protocol.ZWaveController:668 ]- NODE 72: Notifying event listeners: ZWaveTransactionCompletedEvent
2018-06-13 23:07:49.200 [DEBUG] [.z.internal.ZWaveActiveBinding:455 ]- ZwaveIncomingEvent
2018-06-13 23:07:49.200 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1138]- NODE 72: Node advancer - MANUFACTURER: Transaction complete (SendData:Request) success(false)
2018-06-13 23:07:49.200 [DEBUG] [WaveController$ZWaveSendThread:1430]- NODE 72: Response processed for callback id 132 after 4985ms/4985ms.
2018-06-13 23:07:49.200 [DEBUG] [WaveController$ZWaveSendThread:1295]- Took message from queue for sending. Queue length = 33
2018-06-13 23:07:49.200 [DEBUG] [o.b.z.i.protocol.SerialMessage:255 ]- Assembled message buffer = 01 09 00 13 48 02 72 04 25 84 78
2018-06-13 23:07:49.200 [DEBUG] [WaveController$ZWaveSendThread:1355]- NODE 72: Sending REQUEST Message = 01 09 00 13 48 02 72 04 25 84 78
2018-06-13 23:07:51.384 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ]- NODE 72: SendData Request. CallBack ID = 132, Status = Transmission complete, no ACK received(1)
2018-06-13 23:07:51.384 [ERROR] [b.z.i.p.s.SendDataMessageClass:142 ]- NODE 72: Node is DEAD. Dropping message.
2018-06-13 23:07:51.384 [DEBUG] [b.z.i.protocol.ZWaveController:668 ]- NODE 72: Notifying event listeners: ZWaveTransactionCompletedEvent
2018-06-13 23:07:51.384 [DEBUG] [.z.internal.ZWaveActiveBinding:455 ]- ZwaveIncomingEvent
2018-06-13 23:07:51.384 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1138]- NODE 72: Node advancer - MANUFACTURER: Transaction complete (SendData:Request) success(false)
2018-06-13 23:07:51.384 [DEBUG] [WaveController$ZWaveSendThread:1430]- NODE 72: Response processed for callback id 132 after 2184ms/4985ms.
2018-06-13 23:07:51.384 [DEBUG] [WaveController$ZWaveSendThread:1295]- Took message from queue for sending. Queue length = 32
2018-06-13 23:07:51.384 [DEBUG] [o.b.z.i.protocol.SerialMessage:255 ]- Assembled message buffer = 01 09 00 13 48 02 72 04 25 84 78
2018-06-13 23:07:51.384 [DEBUG] [WaveController$ZWaveSendThread:1355]- NODE 72: Sending REQUEST Message = 01 09 00 13 48 02 72 04 25 84 78
2018-06-13 23:07:52.932 [DEBUG] [eController$ZWaveReceiveThread:1601]- Receive Message = 01 04 01 13 01 E8
2018-06-13 23:07:52.932 [DEBUG] [eController$ZWaveReceiveThread:1517]- Receive queue ADD: Length=1
2018-06-13 23:07:52.932 [DEBUG] [b.z.i.protocol.ZWaveController:1244]- Receive queue TAKE: Length=0
2018-06-13 23:07:52.933 [DEBUG] [o.b.z.i.protocol.SerialMessage:255 ]- Assembled message buffer = 01 04 01 13 01 E8
2018-06-13 23:07:52.933 [DEBUG] [b.z.i.protocol.ZWaveController:1245]- Process Message = 01 04 01 13 01 E8
2018-06-13 23:07:52.933 [DEBUG] [b.z.i.protocol.ZWaveController:200 ]- Message: class = SendData (0x13), type = Response (0x01), payload = 01 , callbackid = 0
2018-06-13 23:07:52.933 [DEBUG] [b.z.i.p.s.SendDataMessageClass:39 ]- NODE 72: Sent Data successfully placed on stack.
