I’m working on a custom widget using an expandable f7-card component and having a bit of trouble with aligning an oh-button within the card header. Currently, I have the oh-button in the right-hand corner of the header, but I’d like it to stay visible and aligned even after the card expands. Right now, the button either shifts out of view or disappears entirely when the card is expanded.
If anyone has encountered this issue or has any tips for getting the button to stay visible in the expanded view, I’d really appreciate the help! Thanks!
The button disappears because you have given it the card-opened-fade-out class.
As for the alignment, by default, the f7-row is using display: flex. That makes keeping all of the child items on one row very simple, you just have to add flex-wrap: nowrap to the row’s styles.
On a more fundamental level, I suspect that one of the reason the elements are not staying on the same row to begin with is the additional f7-col components. I wouldn’t bother to include those myself. Those are most helpful when you have more than one row and you are trying to coordinate the columns between those row to get a grid appearance. Here you just have the one row, so let flexbox do it’s job and if you need more precise control over the size or position of the row’s child elements, then give the elements individual flex properties (for example, you don’t really want the button to grow or shrink so something like flex: 0 0 10% will make the button always 10% of the row with now reactive growth or shrinkage).
I’m working further on the layout using the following YAML configuration, and I noticed that the f7-block component has a gap between its top and the elements above it. Despite setting margin: 0 and padding: 0 in the relevant style sections, there’s still an unexplained space between the f7-block and the previous row or component.
Here’s a snippet of the YAML for the section in question:
uid: Cell_Wallplugnew
tags: []
props:
parameters:
- context: item
description: A actual power item to display
label: Item
required: false
type: TEXT
- context: item
description: A total power item to display
label: Item
required: false
type: TEXT
- context: item
description: A daily total power item to display
label: Item
required: false
type: TEXT
- context: item
description: the switch state
label: Item
required: false
type: TEXT
- description: URL to show in the frame
label: Source URL
required: true
type: TEXT
- default: from=now-6h&to=now;6h,from=now-12h&to=now;12h,from=now-1d&to=now;24h,from=now/d&to=now/d;Day,from=now-3d&to=now;Last
3 Days,from=now-7d&to=now;Last 7 Days,from=now-14d&to=now;Last 14 Days
description: Comma-separated List of options. Example
"from=now-6h&to=now;-6h,from=now-1d/d&to=now-1d/d;yesterday" for past
"6h" and "yesterday". First entry is default.
label: Time range options
required: true
type: TEXT
parameterGroups: []
timestamp: Nov 16, 2024, 12:46:50 PM
component: f7-card
expandable: true
style:
--f7-card-expandable-tablet-height: 75vh
--f7-card-expandable-tablet-width: 35vw
background-color: "=props.bgcolor ? props.bgcolor : ''"
box-shadow: 5px 5px 10px 1px rgba(0,0,0,0.1)
height: 150px
margin-left: 5px
margin-right: 5px
margin-top: 10px
noShadow: false
padding: 0px
swipeToClose: true
slots:
default:
- component: f7-row
class:
- align-items-center
- justify-content-space-between
style:
background-color: "#f0f0f0"
font-size: 18px
font-weight: bold
height: 20px
margin: 0 0 0 0
width: 100%
flex-wrap: nowrap
slots:
default:
- component: f7-col
style:
background-color: green
text-align: center
width: 80%
slots:
default:
- component: Label
text: Card Header
- component: f7-col
style:
width: 20%
slots:
default:
- component: oh-button
class:
- cell-open-button
- card-opened-fade-out
- card-open
color: black
iconF7: expand
iconSize: 20px
style:
text-align: right
- component: f7-card-content
style:
width: 100%
background-color: yellow
margin: 0 0 0 0
padding: 0 0 0 0
slots:
default:
- component: f7-row
class:
style:
font-size: 18px
font-weight: bold
height: 20px
margin: 0 0 0 0
width: 100%
flex-wrap: nowrap
slots:
default:
- component: f7-col
style:
text-align: center
width: 80%
slots:
default:
- component: Label
text: Card Header
- component: f7-col
style:
width: 20%
slots:
default:
class:
#- cell-open-button
#- card-opened-fade-out
#- card-open
color: black
iconF7: expand
iconSize: 20px
style:
text-align: right
- component: f7-row
class:
- justify-content-center
style:
font-size: 16px
margin: 0 0 0 0
padding: 0 0 0 0
slots:
default:
- component: f7-block
class:
- card-prevent-open
- card-content-padding
outline: false
style:
width: 100%
height: 115px
background-color: red
slots:
default:
- component: f7-list
config: {}
slots:
default:
- component: oh-toggle-item
class:
- card-prevent-open
outline: false
style:
width: 100%
slots:
default:
config: {}
slots:
default:
color: green
icon: oh:poweroutlet
item: =props.itemSwitch
title: Steckdose
- component: oh-label-item
color: blue
icon: f7:chart_bar_circle
item: =props.itemDailyTotalPower
title: Daily Totayl Power
color: blue
icon: f7:chart_bar
item: =props.itemActualPower
title: Actual Power
color: blue
icon: f7:chart_bar_square_fill
item: =props.itemTotalePower
title: Totale Power
- component: oh-webframe-card
borders: false
class:
- display-block
height: 240px
noBorder: false
noShadow: true
src: =props.URL.replace('{period}', vars.selectedPeriod ||
[props.timerange.split(',')[0].split(';')[0]])
- component: f7-segmented
class:
- padding-bottom-half
outline: false
round: false
style:
--f7-button-border-radius: 4px
--f7-button-font-size: 14px
--f7-button-font-weight: 300
--f7-button-outline-border-width: 1px
--f7-button-padding-horizontal: 0px
--f7-button-padding-vertical: 0px
--f7-button-text-color: "=themeOptions.dark === 'light' ? 'black' : 'white'"
--f7-button-text-transform: none
margin-left: 10px
margin-right: 10px
margin-top: 250px
slots:
default:
- component: oh-repeater
for: size
fragment: true
sourceType: range
slots:
default:
for: period
fragment: true
in: =[props.timerange.split(",")[loop.size].split(";")[1]]
slots:
default:
action: variable
actionVariable: selectedPeriod
actionVariableValue: =props.timerange.split(",")[loop.size].split(";")[0]
fill: "=(([props.timerange.split(',')[loop.size].split(';')[0]] ==
vars.selectedPeriod) ||
(props.timerange.split(',')[0].split(';\
')[1] === loop.period) &&
!vars.selectedPeriod) ? true : false"
outline: true
round: false
style:
--f7-button-border-color: var(--f7-card-outline-border-color)
text: =loop.period
Despite my best efforts with CSS styles like margin: 0, padding: 0, and even tweaking height, the block is not aligning snugly to the top of the parent container.
I’d appreciate any suggestions or insights on:
Possible hidden margins/padding applied by f7-block or parent components.
Debugging tips to identify where the extra spacing originates.
Yep, that’s the trade-off with using all the f7 components. There’s a lot of styling under-the-hood which means that you have to do less most of the time, but when you have something specific in mind you have to sort through all the extra.
In this case the margin is on the block itself.
All I ever use when I can’t work out css issues is the elements tab in the browser console. I start with the element that looks like it is having the problem and then work my way up the tree. In this case you don’t have to go far. Inspecting the block itself you see:
Which shows you that there in, in fact, some directive setting a 16 pixel top margin. So looking in the full styles list it is easy to find:
Now we know that because this element is 1) on a page, and 2) an f7-block that is the first child of it’s parent it gets a top margin value. So, margin: 0 or margin-top: 0 on the block itself will remove the gap at the top.
