I am slowly migrating my DSL rules over to Jython and been fairly successful so far with basic rules (if this happens, then switch that, etc).
On a more complex level, I have an alarm panel which interfaces through TCP. Using NodeRed I monitor for changes in the alarm panel (using Elk_Bridge item) and then update another item (Elk_Text). The Elk_Bridge item contains around 14-16 characters. The rule has 148 lines and is a series of nested IF and switch statements which interpret certain key characters within the Elk_Bridge item. While I can convert this to Jython based on what I have learnt so far (except for the switch statements) I think it can be done better, but I’m not actually sure of the recommended approach.
After some initial research I think my options may include either a hash map (don’t know much about this, yet) or possibly using a transformation map. Before I choose one and go further down the rabbit hole, I just wanted to know if either of these options are straight out wrong, or if there is a better option I haven’t yet considered. This will allow me to target my research a little better.
Any advice is appreciated
rule "Update Security"
Item Elk_Bridge received update
if (Elk_Bridge.state.toString.substring(0,2) == "82"){ //Status Report Data
switch Elk_Bridge.state.toString.substring(8,10) {
case "11" : { //Zone Detector Low Battery
switch Elk_Bridge.state.toString.substring(10,14) {
case "0000" : Elk_Text.postUpdate("Zone Detector Battery Normal")
case "12" : { //Miscellaneous Alarms
case "0000" : Elk_Text.postUpdate("No Zones")
case "0100" : Elk_Text.postUpdate("Zone 1")
case "13" : { //Miscellaneous Alarms
case "0001" : Elk_Text.postUpdate("Duress Alarm")
case "0002" : Elk_Text.postUpdate("Panic Alarm")
case "0004" : Elk_Text.postUpdate("Medical Alarm")
case "0020" : Elk_Text.postUpdate("Install End")
case "0040" : Elk_Text.postUpdate("Exit Tamper")
case "0080" : Elk_Text.postUpdate("Keypad Tamper")
case "0100" : Elk_Text.postUpdate("Pendant Panic")
case "0200" : Elk_Text.postUpdate("Panel Battery Low")
case "0400" : Elk_Text.postUpdate("Panel Battery Low")
case "0800" : Elk_Text.postUpdate("Mains Fail")
case "4000" : Elk_Text.postUpdate("Unknown Status 4000")
case "5000" : Elk_Text.postUpdate("Unknown Status 5000")
