Hey guys,
Looking for help to troubleshoot an error in a rule I made that is causing an error regularly, and I think is causing openhab to become very resource heavy. The rule still works fine, but the error tells me I made a bodge of the code…
Could someone show mehod I can troubleshoot a rule based on the error in the openhab logs, and or show me how to correctly write the rule.
I am running openhab 2.4
A little background on the rule and its super practical function is here
Thanks,
Here is the rule:
var Timer timer = null // global variable usually
rule "timer"
Item KitchenEchoNextTimer changed
timer = null
timer = createTimer(now, [ |
// Timer Date and time 2019-10-20T21:58:35.870-0600
val timerString = KitchenEchoNextTimer.state.format("%1$tY-%1$tm-%1$tdT%1$tH:%1$tM:%1$tS")
// parse String to Date Time
var DateTime timestring = parse(timerString)
// find out time left in minutes
val timeleft = (((timestring.millis + 60000) - now.millis) /60000)
// null the timer if time left is 0
if(timeleft <= 0) timer = null
else {
// update the timer Item with time remaining
CurrentTimer.sendCommand(timeleft)
// Switch the Dashboard to the Timer Dashboard Holding the Timer Template Widget
Pin_String.postUpdate("Timer")
// reschedule the timer for 1 minute
timer.reschedule(now.plusMillis(60000))
rule "Update Display Timer Iterm"
Item CurrentTimer received command
// Give the item a half second to register the change in time left
Thread::sleep(500)
//Log the time left
logInfo("alexatimer", CurrentTimer.state.toString + " time left on the Echo Timer")
// create a second timer when the first timer has reached 1 minute left to switch the dashboard when the timmer reaches null
if( receivedCommand == "1" ) {
createTimer(now.plusMinutes(1), [ |
// Switch the Dashboard to the Home Dashboard
Pin_String.postUpdate("Home")
And here is the error:
2020-03-03 21:28:41.187 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2020-03-03T21:28:41.156-07:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
val timerString
var timestring
val timeleft
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@7d49a515
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
Caused by: java.util.IllegalFormatConversionException: Y != java.lang.String
at java.util.Formatter$FormatSpecifier.failConversion(Formatter.java:4302) ~[?:?]
at java.util.Formatter$FormatSpecifier.printDateTime(Formatter.java:2835) ~[?:?]
at java.util.Formatter$FormatSpecifier.print(Formatter.java:2740) ~[?:?]
at java.util.Formatter.format(Formatter.java:2526) ~[?:?]
at java.util.Formatter.format(Formatter.java:2455) ~[?:?]
at java.lang.String.format(String.java:2940) ~[?:?]
at org.eclipse.smarthome.core.types.UnDefType.format(UnDefType.java:34) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1086) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1061) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1047) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:992) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:772) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:220) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:827) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:264) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
