djuscha
(Djuscha)
1
It all worked great and so did
var Cam = "pic" +".jpg"
executeCommandLine("wget http://user:pass@selfhost.eu:58081/cgi-bin/video.cgi?msubmenu=jpg -O /tmp/" + Cam",5")
Thread::sleep(1000)
sendMail("openhab@gmail.com","Besucher","Besucher hat um "+now.toString("HH:mm:ss")+" geklingelt","file:///tmp/"+Cam)
The update from Samsung, http access is no longer just RTSP stream
That looks so
rtsp://user:pass@192.168.178.129/profile5/media.smp
But this is not supported by Openhab
Who could help me with the implementation
Rtsp stream as image in the open and save it
Your can use ffmpeg to get a image from your web cam :
ffmpeg -i rtsp://user:pass@192.168.178.129/profile5/media.smp -s 640x360 -f image2 -vframes 1 pic.jpg -y
djuscha
(Djuscha)
3
How do you think that? How should I write this in the rules?I’m still a beginner
Same as your code. Using the call to the command line.
djuscha
(Djuscha)
5
Do you mean that??
executeCommandLine("ffmpeg -i rtsp://user:pass@192.168.178.129/profile5/media.smp -s 640x360 -f image2 -vframes 1 pic.jpg -y /tmp/" + Cam",5")
Thread::sleep(1000)
djuscha
(Djuscha)
7
pi@raspberrypi:~ $ ffmpeg
-bash: ffmpeg: Kommando nicht gefunden.
pi@raspberrypi:~ $ ?
I still have something to install??
yes. the whole “ffmpeg” application.
maybe this would help :
djuscha
(Djuscha)
9
Thank you. I will now test
djuscha
(Djuscha)
10
@AV_HomeAuto
executeCommandLine("ffmpeg -i rtsp://admin:pass@192.168.178.128/profile5/media.smp -s 480x300 -f image2 -vframes 1 pic.jpg -y /tmp/1.jpg")
Thread::sleep(1000)
sendMail("openhab@gmail.com","Besucher","Besucher hat um "+now.toString("HH:mm:ss")+" geklingelt","file:///tmp/1.jpg")
executeCommandLine("ffmpeg -i rtsp://192.168.178.124/ch0_0.h264 -s 480x300 -f image2 -vframes 1 pic.jpg -y /tmp/3.jpg")
Thread::sleep(1000)
sendMail("openhab@gmail.com","Besucher1","Besucher1 hat um "+now.toString("HH:mm:ss")+" geklingelt","file:///tmp/3.jpg")
This works!!!
thank you !!!
