jimmyt
(Greg)
June 4, 2018, 12:46pm
1
I was able to get the openhabian imaged and installed properly.. but for the life of me I cant ssh into the pi.
The webserver is working and I can get to the start and log pages. I can even get to the smb sharers - openhabian/openhabian works for those..
when I ssh into the pi using putty and port 22 - it connects to the login page but then it says access denied with openhabian / openhabian.
login as: openhabian
openhabian@192.168.0.78 ’s password:
Access denied
what am I missing? Any help would be appreciated! thanks
mjcumming
(Michael Cumming)
June 4, 2018, 1:29pm
2
I just had that happen. I closed putty and reconnected and the error went away. Weird.
Yes sometimes I get this error if my known_hosts file is messed up. I just delete the file and reconnect.
Also, did you change the default username in openhab.conf? I have some that and forgot.
jimmyt
(Greg)
June 25, 2018, 5:12pm
4
so just to follow-up.. I ended up re-imaging the sd card and it worked fine. I ended up doing that before seeing the post on the known_hosts file, so I will keep that in the back of my mind for next time
