Help me please with zigbee2mqtt
Can you use the code fencing for your configuration file.
Have you started zigbee2mqtt???
I would also suggest adding a frontend to your configuration that and setting the port to one that does not interfere with openhab. That way you can view the logs and settings in your browser
