Ive no idea whats happening, no changes have been made but I’m getting loads of errors. Some functions of OH2 work, alot dont.
Spotify script isnt doing anything. Zwave rules arent working correctly but the UI’s load.
Ive no idea where to start as the errors are so big:
openhab> log:tail
18:40:42.081 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'at tic.sitemap'
18:40:42.113 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'ya mahaavr.sitemap'
18:40:42.351 [WARN ] [core.common.registry.AbstractRegistry] - ItemChannelLink w ith key 'OpenHAB_Storage_Available -> systeminfo:computer:OpenHAB:storage#availa ble' already exists from provider GenericItemChannelLinkProvider! Failed to bulk -add a second with the same UID from provider ManagedItemChannelLinkProvider!
18:40:42.358 [WARN ] [core.common.registry.AbstractRegistry] - ItemChannelLink w ith key 'KitchenNum1 -> zwave:device:512:node5:meter_watts1' already exists from provider GenericItemChannelLinkProvider! Failed to bulk-add a second with the s ame UID from provider ManagedItemChannelLinkProvider!
18:40:42.364 [WARN ] [core.common.registry.AbstractRegistry] - ItemChannelLink w ith key 'OpenHAB_Network_DataSent -> systeminfo:computer:OpenHAB:network#dataSen t' already exists from provider GenericItemChannelLinkProvider! Failed to bulk-a dd a second with the same UID from provider ManagedItemChannelLinkProvider!
18:40:42.372 [WARN ] [core.common.registry.AbstractRegistry] - ItemChannelLink w ith key 'KitchenNum2 -> zwave:device:512:node5:meter_kwh1' already exists from p rovider GenericItemChannelLinkProvider! Failed to bulk-add a second with the sam e UID from provider ManagedItemChannelLinkProvider!
18:40:42.376 [WARN ] [core.common.registry.AbstractRegistry] - ItemChannelLink w ith key 'LivingRoomNum1 -> zwave:device:512:node6:meter_watts1' already exists f rom provider GenericItemChannelLinkProvider! Failed to bulk-add a second with th e same UID from provider ManagedItemChannelLinkProvider!
18:40:42.396 [WARN ] [core.common.registry.AbstractRegistry] - ItemChannelLink w ith key 'KitchenDim1 -> zwave:device:512:node5:switch_dimmer1' already exists fr om provider GenericItemChannelLinkProvider! Failed to bulk-add a second with the same UID from provider ManagedItemChannelLinkProvider!
18:40:42.402 [WARN ] [core.common.registry.AbstractRegistry] - ItemChannelLink w ith key 'LivingRoomDim1 -> zwave:device:512:node6:switch_dimmer1' already exists from provider GenericItemChannelLinkProvider! Failed to bulk-add a second with the same UID from provider ManagedItemChannelLinkProvider!
18:40:42.403 [WARN ] [core.common.registry.AbstractRegistry] - ItemChannelLink w ith key 'LivingRoomNum2 -> zwave:device:512:node6:meter_kwh1' already exists fro m provider GenericItemChannelLinkProvider! Failed to bulk-add a second with the same UID from provider ManagedItemChannelLinkProvider!
18:40:42.404 [WARN ] [core.common.registry.AbstractRegistry] - ItemChannelLink w ith key 'OpenHAB_Cpu_SystemUptime -> systeminfo:computer:OpenHAB:cpu#uptime' alr eady exists from provider GenericItemChannelLinkProvider! Failed to bulk-add a s econd with the same UID from provider ManagedItemChannelLinkProvider!
18:40:42.785 [INFO ] [nal.protocol.xml.DeviceInformationXML] - Found zones: [Mai n_Zone, Zone_4, Zone_2, Zone_3], features: [BLUETOOTH, SPOTIFY, AIRPLAY, USB, NE T_RADIO, DAB]
18:40:42.898 [INFO ] [.internal.protocol.xml.ZoneControlXML] - Zone Zone_4 - the dialogueLevel channel is not supported on your model
18:40:42.929 [INFO ] [.internal.protocol.xml.ZoneControlXML] - Zone Zone_3 - the dialogueLevel channel is not supported on your model
18:40:43.104 [INFO ] [.internal.protocol.xml.ZoneControlXML] - Zone Zone_2 - the dialogueLevel channel is not supported on your model
18:40:43.264 [INFO ] [ding.zwave.handler.ZWaveSerialHandler] - Connecting to ser ial port '/dev/ttyACM0'
18:40:43.484 [INFO ] [ding.zwave.handler.ZWaveSerialHandler] - Serial port is in itialized
18:40:43.500 [INFO ] [ave.internal.protocol.ZWaveController] - Starting ZWave co ntroller
18:40:43.501 [INFO ] [ave.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
18:40:43.664 [ERROR] [oftware.os.linux.LinuxOperatingSystem] - Couldn't find any running processes, which is odd since we are in a running process. Process time values are in jiffies, not milliseconds.
18:40:43.738 [ERROR] [oftware.os.linux.LinuxOperatingSystem] - Couldn't find any running processes, which is odd since we are in a running process. Process time values are in jiffies, not milliseconds.
18:40:43.931 [WARN ] [core.common.registry.AbstractRegistry] - NumberItem with k ey 'OpenHAB_Cpu_Load' already exists from provider GenericItemProvider! Failed t o bulk-add a second with the same UID from provider ManagedItemProvider!
18:40:43.935 [WARN ] [core.common.registry.AbstractRegistry] - NumberItem with k ey 'OpenHAB_Storage_Used' already exists from provider GenericItemProvider! Fail ed to bulk-add a second with the same UID from provider ManagedItemProvider!
18:40:43.947 [WARN ] [core.common.registry.AbstractRegistry] - NumberItem with k ey 'OpenHAB_Cpu_SystemUptime' already exists from provider GenericItemProvider! Failed to bulk-add a second with the same UID from provider ManagedItemProvider!
18:40:43.954 [WARN ] [core.common.registry.AbstractRegistry] - NumberItem with k ey 'OpenHAB_Network_DataSent' already exists from provider GenericItemProvider! Failed to bulk-add a second with the same UID from provider ManagedItemProvider!
18:40:43.954 [WARN ] [core.common.registry.AbstractRegistry] - NumberItem with k ey 'OpenHAB_Memory_Available' already exists from provider GenericItemProvider! Failed to bulk-add a second with the same UID from provider ManagedItemProvider!
18:40:43.955 [WARN ] [core.common.registry.AbstractRegistry] - SwitchItem with k ey 'KitchenReset' already exists from provider GenericItemProvider! Failed to bu lk-add a second with the same UID from provider ManagedItemProvider!
18:40:43.955 [WARN ] [core.common.registry.AbstractRegistry] - SwitchItem with k ey 'LivingRoomReset' already exists from provider GenericItemProvider! Failed to bulk-add a second with the same UID from provider ManagedItemProvider!
18:40:43.955 [WARN ] [core.common.registry.AbstractRegistry] - NumberItem with k ey 'OpenHAB_Storage_Available' already exists from provider GenericItemProvider! Failed to bulk-add a second with the same UID from provider ManagedItemProvider !
18:40:43.955 [WARN ] [core.common.registry.AbstractRegistry] - NumberItem with k ey 'OpenHAB_Memory_Total' already exists from provider GenericItemProvider! Fail ed to bulk-add a second with the same UID from provider ManagedItemProvider!
18:40:43.955 [WARN ] [core.common.registry.AbstractRegistry] - NumberItem with k ey 'OpenHAB_Memory_Used' already exists from provider GenericItemProvider! Faile d to bulk-add a second with the same UID from provider ManagedItemProvider!
18:40:43.956 [WARN ] [core.common.registry.AbstractRegistry] - NumberItem with k ey 'OpenHAB_Storage_Total' already exists from provider GenericItemProvider! Fai led to bulk-add a second with the same UID from provider ManagedItemProvider!
18:40:44.266 [WARN ] [.eclipse.jetty.servlet.ServletHandler] -
javax.servlet.ServletException: A MultiException has 1 exceptions. They are:
1. java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_0,1,10131 36368) has been shut down
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.ja va:489) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22. 2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:4 27) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContaine r.java:388) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2 .22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContaine r.java:341) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2 .22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContaine r.java:228) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2 .22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.ser vice(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1 .201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848 ) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java :584) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.do Handle(HttpServiceServletHandler.java:71) [183:org.ops4j.pax.web.pax-web-jetty:6 .0.9]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.j ava:143) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.jav a:548) [82:org.eclipse.jetty.security:9.3.21.v20170918]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandl er.java:226) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandl er.java:1180) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle( HttpServiceContext.java:284) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java: 512) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandle r.java:185) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandle r.java:1112) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.j ava:141) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection .handle(JettyServerHandlerCollection.java:80) [183:org.ops4j.pax.web.pax-web-jet ty:6.0.9]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper .java:134) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [84:org.eclip se.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [84 :org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.jav
