Hardware: Intel i7 16GB 2T
OS: Win10 home 1803
Java Oracle 1.8.0_181-b13 and Zulu 8.31.0.1
openHAB version: 2.3.0
Issue of the topic: Installed openHAB using Chocolatey
- Now want to install add-on MiOS bindings/Vera Plus
Newbie:
Per installation, guide installed Zulu via @ Zulu.org 1](http://zulu.org/)
Created and unzipped Zulu 8 into
C: Program Files (86)\Zulu\zulu8.31.0.1-jdk8.0.181-win_i686 folder
Sub folders here: bin,demo,include,jre,lib, and sample
The install did not create zulu_jdk\bin\
Again, Installed with Chocolatey;
Chocolatey put Folders and Files here:
C:ProgramData\chocolatey\ bin,config,helpers,lib,logs,redirects,tools, ……
Q1 MiOS Add-on Bridge documentation doesn’t seem to help when openHAB installed using Chocolatey; openHAB starts ok, Paper UI open ok.
Q2 any idea what directories to use to install the MiOS add-on using the Documentation on this site?
Example: where to put openhab.cfg, where to put MiOS transformations, where to put MiOS Item Generator ?
Summary:
Is there a step by step to install the MiOS add-on Bindings when
used Chocolatery as the main installer for openHAB ?
I want to use openHAB to manage my Vera Plus and other devices can you help?
